lol this is exactly why I explored this option in the first place! Not many people have reflow ovens or stations either.
I probably can carefully solder the components alright, and have already ordered some boards, so probably will end up doing that at some point just for the exercise i guess!
The main benefit is that doing a bulk order is actually still cheaper than assembling by hand and you dont have to worry about damaging anything, testing, troubleshooting etc.
Building this driver yourself can easily cost over $40USD, by the time you take shipping for components into account.
I will keep it standard spec, per loneoceans guidelines.
You can change a few options through the jumpers or tweaking values in the firmware.
If I end up having to program them all manually, I guess I can do custom settings if people request it.
Well most of the settings people would want to change can be done themselves with the soldering iron and shorting out the jumper pads.
the default settings will be fine for most users I would imagine. Some who want to run different voltages may need to change the firmware.
If there is a specific firmware change required, Im sure this can be done at extra cost.
Any single cell host that accepts a 17mm driver.
I expect most of us will be putting them in a convoy S2+ or similar host, as they are the most popular.
The tailcap board is also designed for the Convoy S2+
I dont think many people would be doing this, technically the driver can pull 50W, but with the default settings, max output is 5.5A which means just shy of 20W
Is nothing new, common as apples or donuts. Of course, use a cell with enough power delivery/continuous discharge rating, namely if maxing out the driver's output power. A 30Q cell is just shy of this, although an acceptable or 0K choice in responsible hands. In any case, a high discharge cell is a must (Murata VTC5/VTC5A/VTC5D, Samsung 20S/25R/25S, LG HE2/HG2, Sanyo NSX, Molicel P26A/P42A…).
This is going to be super unpopular, but you really need to build in extra costs for things like lost packages, returns, failed boards, shipping, etc etc etc, and don’t forget your time as well. Just my take. Still in for 4 at 17mm.
