Nice. I've always wondered what percentage of BLFers are strictly flashlight guys/gals verses EDC gear hoarders. "T.H.Cone" BTW. Only because "cone" by itself was already in use and I signed up there after here so... Oh, well.
tritium is good, glows all the time, and therefore can always be read in the dark, even without external charging. the better gitd is brighter when charged, but does fade. luminox uses t25 tritium, which until fairly recently, is all that could be brought into the US. now however, ball, deep blue, and most recently one model by android use t100 tritium, and the difference is amazing. MUCH brighter than luminox, or any t25 tritium tubes.
Well, they also sell Glowrings where the tritium vial is encased in clear acrylic (it's kinda hard to see because the picture is so dark, but the row at the bottom consists of glowrings).
There is also this glow fob, and the same shop also sells a kit to konvert it from GITD to tritium vial:
Rather pricey though, and no guarantee thet a 4x25 mm vial will fit.
You could build a casing yourself, for example with some acrylic tube from ebay and a bit of clear epoxy to seal the tube. Take a keyring from a fauxton, drill a hole through the tube and your done.
If you want to get fancy, you can fill all the interior of the acrylic tube with Norland 61, a one component UV-light activated mil-spec glue for lenses and optical components. Very expensive (1 ml about 10$ at cpf marketplace), but cures crystal clear (or so they say, haven't bought any of the stuff yet).
Wait till they discover the many packages you are receiving. Sharp aluminum pieces, stainless steel tubular canisters, dangerous explosive material encased in cylindrical cells, and suspicious electronic chips. You're in big trouble now.
He ships worldwide but the site is not really clear, you can pay with paypal only with insurance postage and shipping cost are quite high. Not a big deal...
The amount of tritium in these tubes is not completely harmless, if you were to break them open and breathe in all they contained. The T100 tubes contain between 25 and 100 millicuries of tritium, which is a surprising amount compared to the doses of other radionuclides you might receive in a nuclear medicine study. For example, most people get from 20 to 40 millicuries of Tc-99m for a stress test used to measure the health of their hearts. However, the chances of breathing it all in accidentally are pretty slim, and you would never know the effects. In a heart study, however, you're getting a good benefit from the exposure, and you're getting nothing (but giggles) from the tritium.
In the old days, they used radium for luminescent watch dials, etc. That stuff is nasty, and cost many people their health and lives. Not the people that wore the watches, mind you, but the people who painted the radium and phosphor mix onto the watches. They needed fine points on their brushes to paint the small numbers, and would put the brushes in their mouths about six times for each watch they painted. Unfortunately for them, radium seeks out bone when ingested, and emits alpha radiation, which can be more damaging internally than the betas from tritium. These ladies, now called the Radium Girls, received large doses, especially to their bones, causing many cancers and deaths.
Tritium, though, is a totally different creature. It will not make you into Spiderman, but is pretty cool. I have a tube coming that should arrive any day!
Read that tritium was used as a stretcher to increase yield in A-bombs. What size vial & color would one need to increase the yield of a ”Black Cat” firecracker?
No amount of tritium would ever increase the yield of a firecracker, and could be hazardous to your health to try.
Tritium needs massive neutron bombardment from a primary nuclear reaction to start it's fusion reaction. It's use as a "stretcher" is actually as a fusion fuel for multi-stage nuclear weapons. It's also used in experimental fusion reactors as fuel, again under extreme conditions.
The only thing that puting Tritium in a firecracker would likely do is vaporize the tritium allowing you to inhale it. And as mentioned above, that's a really bad idea.
Being very mildly radioactive, there are some shipping restrictions on trit vials, esp. over international borders. And expect to get funny looks at the post office for receiving packages marked with the radioactive symbol.
But wait, I have another thought what if those flashlights with tritium inserts had a li-ion cell short out and reach critical mass before venting? And if someone had firecrackers and this device in their pocket at that exact moment. Could this cause a major disaster on a cataclysmic eotwawki scale? Quick dthrckt call NGEO and warn them. I'm getting my bugout bag and supplies ready and want to be on next seasons ”DOOMSDAY PREPPERS”.
I've calculated the odds of this happening at 1 in 85900584, assuming 12 trit inserts per light, each light running 2x18650 at max charge, and 60 flashlights arranged in a buckyball configuration, each with 8 firecrackers attached, and all fuses time synced, to provide optimal heat and shockwave interaction needed to achieve the needed 1.21 gigawatts of power to trigger a cascading neutron chain reaction.
