You need to press & hold the number slot button until it recognises the cell it will then charge as normal.
But it’s your job to tell it how low to discharge it ,is it a protected cell? If so don’t go lower than 3volts because protected cells usually trip at 3volts.
Not exactly. The DW01 protection IC, very often used in single cell BMSs, trips at ≈2.4 V. Cell voltage then quickly raises above 3 V (with high to moderate discharge loads) or close to 3 V (with low loads). Related: Discharge protection test @ lygte-info.dk
Oh geez. Super annoying I have some cheap 18650 battery holders with wire leads which I connect in parallel to the battery in the MC3000 to get the charge started.
I’m hoping to find some kind of decent charger online that will give a low voltage liion cell a charge without giving a damn about the starting voltage, since this practice of encountering low voltage cells is rather uncommon, but a huge pain in my ass when it does!
On the skyrc mc3000 you have to hold down the number slot button of the bay that the cell is in, it will then activate that cell.
This is copied & pasted from the manual,
I’ve placed a flat top protected 18650 battery in the bay yet the slot info is stilldisplaying NO BATTERY. How to proceed?- Check if the battery is inserted with correct polarity. Check if the battery terminals do makeproper connection with the slot metal contacts; shift, suspend, or tilt the battery, if needed forsecuring the connection. 0V-batteries are displayed as NO BATTERY, so check if the batteryprotection is tripped; click the slot number button to release the protection
Isn’t that just a feature to reset a tripped protected cell? I’ve tried this on a unprotected 2v 18650 and it just doesn’t work to charge that battery, the charger still aborts with some kind of voltage warning.
I need help. I just received my new MC3000 a few days ago. I’ve saved six charging programs, and I can see why this charger is so highly regarded. The charger seems to be charging NiMH and Li-ion cells correctly. I have a problem, though: I can’t get the charger to copy the program saved to one slot to all of the other slots.
I have tried the following procedure several times: 1) saving one of my programs to slot 1; 2) clicking the Slot 1 button and the up arrow button at the same time. When I complete steps 1 and 2, above, instead of copying the program saved to slot 1 to the other three slots, the charger saves “Program 12” to three slots I have not programmed. I have not created a Program 12. I have no idea what I’m doing wrong, and I have no idea why the charger is doing this. Can someone help?
Merci bocoup! Neither the instruction manual nor the “Cheat Sheet” on the SkyRC website explain that! They seem to say you can copy any saved program selected for a slot to the other slots - which is apparently not true, unless the program is the default program for one of the four slots. I appreciate your help.
Edit: looking at the instruction manual discussion of the Global Settings View, I can see that it does talk about setting up the automatic copy and paste of up to eight saved favorite programs with the slot number buttons and up and down arrows. However, in the section on using the Total Overview, it says you can copy and paste programs stored under a shortcut. When I read that, and I looked at the Cheat Sheet, I had the impression that it was possible to cut and paste any program saved to a slot. Not true! Now, thanks to the help you provided, I can see how the process works.
Thank you. I have the cheat sheet, but it doesn’t explain that you can only copy a program that is the default program for that slot - you can’t copy a program that is just assigned to that slot and not saved as the default for that slot. I’m grateful for the quick responses on the forum to my request for help.
Edit: now I can see in the instruction manual the separate Global Setup View section where the default program selection and copy/paste method are discussed. I was confused by the Cheat Sheet and the other section in the instruction manual discussing the copying and pasting of a program from one slot to other slots, neither of which make clear that you can only copy programs set as the default for one of the slots. Thanks again for responding to my plea for help.
The way to access “graphs” view has been changed in FW 1.14 compared to previous versions — you now have to hold down (longer) either the Up or Down button to access Graph View.
I believe there are a few minor changes in accessing some other stuff in FW 1.14 compared to earlier versions. Can’t remember exactly which were changed — I also had to find out those information by reading the FW 1.14 documentation or check online to figure that out though…
Hello,
I have just received my Skyrc MC3000 from Banggood.
There is one problem. Some strange sound. When ventilators spinning faster it disappears.
I have done video of it:
As I understand MC3000 doesn’t display SoC percentage after accumulator insertion. But my Ansmann Energy 8 Professional shows this information and it’s very convenient. Are there any tables for accordance Voltage-SoC% for LiIon and NiMH types?
