Can we get the ft02 with sbt90.2 soon? I want that.
Big +1!!
Sick of more and more bigger hosts...
interested, thanks,
olles
Interested
interested
Ordered, Can I purchase the new driver for my older FT02 that drains the battery ???
Interested
Has anyone got a code yet? Thinking they have not been sent yet.
Edit- Maybe I have not received mine yet. Maybe tomorrow.
Interestd
It is not the breathing led on the first version that uses so much power, with led-breathing off the parasitic drain is still dramatic. But I hope that it is the language problems that tells you the wrong thing and they indeed fixed the parasitic drain of the FT02.
Just received the FT02 XHP70.2 awhile ago, haven’t had time to test it much, but I did some simple measurements — and was mostly underwhelmed by the result…
Ceiling bounce with lux meter, I estimate the max brightness is around 3000 lumens only (far from the claimed 4600 lumens). Again these are just my rough estimates comparing with other flashlights (if I compare with my ceiling bounce lux meter reading of FT03 with XHP50.2 has a significantly higher reading, or even a Convoy M3 with XHP70.2 also gives a higher lux reading). Again, my lux meter reading and ceiling bounce are not accurate, but hopefully gives some idea…
(my unscientifically-controlled ceiling bounce test in a small enclosed room with a lux meter:
FT02 XHP70.2 ~ 3000+ lux
FT03 XHP50.2 ~ 4000+ lux
M3 XHP70.2 ~ nearly 4000 lux)
I measure only about 7-8 Amps tailcap current (how much lumens approximately would 7-8Amps tailcap current on an XHP70.2 flashlight give out)?
(I’m using a fully-charged Liitokala Lii-40A 4000mah 21700 battery only when I measured the tailcap current; it’s not a very high-drain 21700 battery… but still…)
Also tried measuring the parasitic drain, and it has indeed high parasitic drain — I measured 4-5mA (0.004-0.005A), even though the LED is not “breathing” pattern. So that means it does have a high parasitic drain.
I was affraid this could happend...
Bummer. I guess I will need to find another 12v host
Your battery dead empty in a month without notice, the FT02 will be the cause of many ruined batteries around the world
Mine has said shipped for a while and was one of the first orders. I’ll update when received.
I’ll get mine tomorrow. Will see if i keep it or post WTS
Interested.
Checked mine today, in OFF it also draws 0.005A and on tail i have 5-6A...
It sure as hell doesn’t look bright for 4600lumens claimed.
Will try with different battery but at first glamce this is hardly updated FT02.
Freeme please take some steps about this GB or edit your first post. A lot of crap in this one
Doesn't sound good to me. I have already forwarded your findings to Banggood.
Well, looks like my driver went POOOOF few hours after i got this.
Swaped mcpcb with emitter for Rngwn’s GT-FC40 and all i got is this on turbo:
