Another great project. I love your build threads
Cool work. Interested to see how this turns out too.
āThe 17 mm driver will be soldered to a 17-to-20mm brass ring, that is silver soldered to a copper washer, that has a 16 gauge piece of copper silver soldered to it, that will be screwed to the wood blockā
That lives in the house that Don builtā¦
This will have an onboard USB charger. A TP5000 2 amp board. It needs a heat sink. So I cut off a length from a longer stick and used arctic alumina thermal epoxy adhesive to mate the boad and the sink. That is a lot of wires, yes; 2 for power input, 2 to the cells (2 x 18650 in parallel) and three to extend to the red/green led indicator.
This morning I wired the mcpcb to the driver and installed the driver with a couple of leads left dangling. That is a Qlite 105C driver with only 4 of the 7135 regulators, for a max output of 1.5 amps.
Hereās the photon end of it. A triple mcpcb from kaidomain and three XP-G3, 2700K LEDs that I reflowed myself. I know many do not like the G3ās because of the greenness. However, I donāt see green at all when these 2700K LEDs are used in a light-diffusing mode as compared to a more or less focussed or concentrated beam. I used a triple set of ledās, not for maximum output, but for slightly greater efficiency as compared to a single led at the same current.
This lens/diffuser from Ledil will be cemented in place over the leds.
The charger with its heatsink fits into the slot and the heatsink with leds is centered in the well hole.
The view from the bottom. A 1/4ā thick wood plate will cover the bottom and be secured to three threaded aluminum bosses that are pressed and glued in the block. There will be some grooves carved for the wiring.
There will be some short legs secured to the underside of the bottom plate. This will elevate the block and permit air flow. The theory is that when being charged, or when the light is on, convection air flow from the bottom and up through the central well with the heatsinks, will provide cooling.
A view from the top, looking down with the glass shade temporarily in place.
And another perspective.
Jaggy wee diffuser
Really nice work MD. Love the grain shape on the end of the timber.
A perfectly contest-worthy project that delays the contest project :party:
Nice progress sofar!
Small progress.
Drilled holes to mount a clicky switch with a boot that will be glued in place.
Everything was just trial fitted and now placed back in the work-in-progress bin.
I think I mentioned that this light will have some legs to elevate it for proper airflow through the āchimneyā.
A tripod-like affairā¦
Mounted temporarily to the main block
Itāll look more or less like this when doneā¦
The USB-C charge port (focus is a little off. Sorry but the phone camera seems to have a mind of its own)
Iām using a Dremel with a mini router bit for some of the wood removal.
And a chisel
It fits in the main block okay
A recess carved into the bottom plate
There will also be a voltage meter readout. A momentary contact switch will allow activation just long enough to check. The driver has LVP of around 2.9 volts.
I chopped the mount ears off as they are useless in this application
The meter fits in the side of the main block. At times an āoopsā becomes a design feature. The Dremel bit caught the wood and slipped, making a chamfer on one side of the notch. It being easier to remove wood, rather than replace wood, I did the same on the other side.
I dug through some switch adds ānā ends the other day and found the momentary switch Iāll use to enable taking a voltvage reading. Itās 6 x 6 mm. I drilled a 1/4ā flat bottom hole, then squared it with a chisel
I also did some carving for wire channels
I drew a rough plan for the wire runs. I hope have not forgotten anything.
I more or less completed this project today.
Sorry, the focus is off and the lighting could be better. Soldering the twin color led to skinny wires was a PITA. No way around it as I needed more length than provided by the led leads.
The three leads were soldered and shrink wrap slid up to cover the joint. Then the leads were pressed into the speces between some fins. A test showed that this slight blockage of the fins has no effect at all on cooling the 2 amp charger. I could probably have done with a much smaller heat sink but this provides a nice spot for the led.
Just to be sure the led didnāt fall loose, I used some kaptan tape.
The charger board and heat sink assembly is cemented in place.
The USB port was cemented to the main block too. Here it is well hidden by the myriad rubber bands and a pencil used to hold it in place while the cement cured.
ā¦ sans rubber bands.
The main led heatsink mounted to determine needed wire lengths.
Cells loosely placed and some more wiring soldered up. The cells are NCR18659GA.
More wires, more soldering. Kaptan tape to hold wires in place while the work proceeds.
Wires done. Scraps of foam cut to hold cells in place when the bottom plate is fitted.
Here we have the Ledil diffuser cemented in place
The on-off-mode switch is fitted witha black silicone cap. Thatās the right front coener.
The charge indicator ledā¦
The voltmeter, set in the rear of the block. My thumb is on the momentary switch that activates the meter as wanted. The yellow stick thing is a pencil. Not important to the picture, it was just there.
I said more or less completedā¦ the glass shade is not fixed in place. I have though of using 3M double sided tape to secure it. I am also going the look for a large o-ring at the hardware store tomorrow. There is a gap between the glass and the wood base. If I can find a suitable o-ring or cut an o-ring and simlpy stuff the material in the gap it will (a) look better than having the trench around the glass and (b) that may be sufficient to keep the glass in place in normal use. Normal use being the light sits there on a shelf.
Yes, the block is stained black. It is quite a departure from the light and dark woods that were used. My reason is quite simple. The home where this is being gifted to, has ebony stained woodwork; the door and window casings are ebony, as is the base trim, bookshelving, etc. There is some rust stained wood and this light will be placed on a rust colored entertainment center top.
The wood I used just happened to be small pieces from the odds ānā ends shelves in the shop. I did kind of like the light / dark but, itās not mine and I know our son prefers the ebony.
Three illuminated shots
The first two on one of the low levelsā¦.I forget which
And the last shot is high level.
High is 1400 mAh split between the 3 parallel XP-G3ās (2700 K).
It wonāt fit the orifice of my lumen-sphere.
Awesome work!
This could very well be an entry for the contest.
Wow. Fantastic.
Things like this are why I enjoy this site so much. I wish I was 1/10 as creative.
Well done!
Looks great, truly inventive and nicely executed.
In lieu of an o-ring, cut a black wire the proper length then push the covering back slightly at each end and solder the ends togetherā¦ voila! A copper wire re-enforced silicone o- ring! If you need it to have more expansion/compression simply remove the wire.
Good idea on the wireā¦ weāll see. Thanks.
Orsm light MD. turned out really nice and practical to boot.
This was awesome to see how you built it Don! your craftsmanship to details and building a very unique project is amazing.
Thanks for the very kind and encouraging words. Much appreciated.
It took me a while to decide on how to heat sink the driver and the charger board. The answer was right in front of me but I didnāt see it at first. Weāll be gifting it to our son this weekend and Iāll take some photos of it in its new āin situā location.
