[New Release] Mankerlight E05 II AL/Cu 1300 Lumen Highest Output Pocket EDC Flashlight in 14500/AA Class
After some searching I found reference to “Manker upgraded driver, UI, switch…”
The UI has definitely changed, Turbo has moved to the blinky mode group. And it no longer allows you to choose 1,2,3 for each level. Can only configure moonlight level.
OLD:
NEW:
As for driver and switch upgrade, I can find no extra details. But indeed there were many reports of unreliability in 2016 so perhaps the changes were warranted ?
The ‘upgraded version’ is not actually new, it appeared in 2018 best I can tell from wayback.
I received my CW E03H that was 1/2 price on clearance from Manker and it has the new mode sequence listed above - same a the Folomov “wave” mode sequence, which I don’t like.
I prefer the sequence to go to low from turbo, rather than going to high from turbo.
The headband can’t hold the light stable - the light bounces when I walk.
The diffuser does glare down into my eyes and glasses - might be reduced by applying black marker to the bottom edge.
I like the beam pattern.
The CRI appears to be adequate for EDC use.
It seems heavier than a AA headlamp needs to be, but it might survive being ran over by a tank.
Mine goes to moonlight after cycling out of the turbo group. Or if double pressing into and out of turbo, it goes to whatever mode it was on before.
Agreed, the diffuser, whether engaged or not, can shine some light into the eyes especially when on the headband, if the light is pointing low enough.
Mine, also, but it goes to medium from high, rather than going to ml or l. ml-l-m-h-m-l-ml.
Yes, mine too in the normal mode group. But you mentioned turbo which is in another group and that behavior is different.
Yes, I erred in my first post.
I received my E02 and E03. Both seems OK.
E02 came in retail package, E03 has a simple cardboard box.
The E04 clip is a trash. Diffrent than advertised and not fits to the groove well. It tends to pop out. Simply not designed to this light. I wrote the seller asking for a good one.
The E02 clip is original and fits perfectly.
E14 II 50% OFF:
https://www.aliexpress.com/item/4000821929621.html
MK34 50% OFF:
https://www.aliexpress.com/item/4000804743531.html
MK34 bundle 47% OFF:
https://www.aliexpress.com/item/4000805543646.html
E14 II 50%OFF / MK34 USD50.00 OFF:
http://www.mankerlight.com/clearance-sale/
That E14 needs to be at least 50% off, $69.99 for that is madness when you look at what it’s competing against.
New model Striker Mini is released.
Striker Mini the Longest Range Pocket EDC Flashlight in Its Class, also the Smallest Tactical Flashlight on the Market.
Key Feature:
  1. Compact Size, Lightweight for Perfect Everyday Carry
  2. High Efficiency Performance in its Size
  3. Multi-fuel (14500 li-ion, Ni-MH AA, Alkaline AA etc)
  4. Single Tail-switch Control for One-handed Operation
  5. High-cost, Durable Construction & Engineering (Dual constant current driver design)
  6. Unique Two-way Strike Bezel
  7. Well-made Two-way Pocket Clip
  8. Full Metal Tactical Ring
  9. Additional EDC Element (Tritium Glow Bar Slots Design)
  10. Versatile Usage Applicable
More info, welcome to http://mankerlight.com/striker-mini-pocket-edc-flashlight-tactical-flashlight/
Mini size for perfect everyday carry.
You can see the photo as below:
Striker Mini VS iPhone 14 Pro in size comparison.
Ultra Compact Size, length is less than 4 inch
Lightweight, weigh 81.6 gram
Palm size is perfect for everyday carry.
Unique Two-way Striker Bezel
high material + high cost surface finish
Striker Mini use the classic tactical user interface. You can control it by one hand easy.
Light modes are very simple, high, low + hidden strobe.
tail is tactical forward-clicky switch. slightly tap to turn the light, release it the light will go out. Full press till a click sound is heard to constantly turn on/off the light. quickly double half-press activate hidden strobe. If you want constant strobe, full press it. The strobe frequency is 20Hz, full power, enough to blink
Striker Mini is positioned as longest range edc flashlight in its class. utilizes a high efficiency osram nm1 led, adopts dual sided AR coated 99% transmitteance toughened glass lens and SMO aluminum reflector with vacuum plated to get a max. 635 lumen output, max. 430 meters about 1411 feet beam distance.
Striker Mini is Multi-Fuel pocket EDC flashlight. the circuit design a wide working voltage: 0.9 v - 4.2 v
the package included one piece Mankerlight type-c USB 920mAh 14500 lithium battery. of course, also accept other brand 14500 lithium battery, Ni-MH AA battery, Alkaline AA battery and other AA-size batteries on the market.
and Striker Mini adopt mechanical switches, no electronic switch, different with the competitors on the market.
turn it off, no drainby, ideal as PSK, or emergency using etc.
Mini size & lightweight is perfect for every day carry. it is ideal as personal EDC gear.
Please also consider other variants - body color for Manker Striker Mini
RED
Emitters
519A
possible quad E21A or E17A
For Manker Striker
Body Color RED and Green
LED
XHP 50.2 and XHP 50.3
XHP 70.3
Thanks for your advise. Now it is second batch. next batch we will consider other emitters but need some time to test.
If we make other color body, any advise to make which surface finish of stainless steel striker bezel we should.
black body, we make stainless steel natural color, anti-fingerprint.
army green body, we make PVD black on stainless steel striker bezel.
Red body, which color surface finish is better match?
REd Body can be paired with natural stainless steel color.
Thanks for your advice. We will consider it.
