Welcome!
Thank You
Thank you. welcome to BLF.
I think so. not sure if they can fullfill the orders, just 4 days left before holiday.
Hi Rey - any update on the 14500 Mini Dawn? I had ordered a Pineapple from banggood several weeks ago, and just today they told me that it had been returned to them and wouldn’t be getting delivered. Since I spent several weeks waiting for the Pineapple, now I figure I might as well wait for the Mini Dawn if its going to be out in the next month or two… If not, would I be able to order a Pineapple or Lan with the 219B R9080 direct from you?
Hi,
Sorry to hear about the waiting. The stock Pineapple and Ti LAN use 219C 4000K. I might be able to swap it to 219B for your order. But holiday begins tomorrow.
Yeah, I have the plan to make mini Dawn. AA/14500 with the new programmable driver. One or two months will def not enough for that.
Tested with the Texas Ace Lumen Tube calibrated with Maukka lights and Sekonic C-800-U Spectrometer
Reylight Copper Pineapple mini 219B | 181 lumens | 4709K | -0.0083 DUV | 96.5 CRI | 92.6 R9 | 74.6 R12 | 90 Rf | 102 Rg | Vapcell 10440 320mah green | ||
Reylight Copper Pineapple mini 219B | 39 lumens | 4753K | -0.0056 DUV | 96.0 CRI | 97.9 R9 | 74.5 R12 | 90 Rf | 103 Rg | Vapcell 10440 320mah green | ||
Reylight Copper Pineapple mini 219B | 7 lumens | 4616K | -0.0051 DUV | 94.7 CRI | 95.3 R9 | 72.2 R12 | 90 Rf | 103 Rg | Vapcell 10440 320mah green | ||
Reylight Copper Pineapple mini 219B | 1 lumens | 4551K | -0.0058 DUV | 95.8 CRI | 98.1 R9 | 77.9 R12 | 91 Rf | 103 Rg | Vapcell 10440 320mah green | ||
Reylight Copper Pineapple mini 219B | 86 lumens | 4737K | -0.0081 DUV | 96.3 CRI | 89.3 R9 | 72.6 R12 | 90 Rf | 102 Rg | Eneloop Pro AAA | ||
Reylight Copper Pineapple mini 219B | 7 lumens | 4603K | -0.0089 DUV | 95.9 CRI | Eneloop Pro AAA | ||||||
Reylight Copper Pineapple mini 219B | 1 lumens | 4540K | -0.0087 DUV | 96.1 CRI | Eneloop Pro AAA | ||||||
Reylight Copper Pineapple mini 219B | 0 lumens | 4594K | -0.0084 DUV | 95.8 CRI | Eneloop Pro AAA |
Hope these are available at end of the month when I get paid. Amazing looking wee light!
Thanks to SKV89 for running the # s on this unit !
181 seems quite low compared to the 300 max Rey mentioned
yes thats very low, it should go over 300 easy… ?
180lm with 10440???
What the...
Yea I thought it was too low too so I recharged the battery and tested it with another vapcell 10440 but same result.
could the vapcell be a bad battery? do u have another light that runs with that battery to rule out?
What mode is it programmed to? One of the modes maxes out at 50%
good point that would explain 180 lumens… so double u have 360 then if thats the case…
guess I’m too late for using the code, just tried it and doesn’t work.
It just came into my possession. That was fast!
Question: Why isn’t this LED no longer in production? Or is it? And why isn’t or wasn’t it used more often? The color is a dream, even more than the Yuji 3200K among 5mm LEDs.
I like this light very much, even if it’s not as bright as expected. Surely nowhere near 300 lm.
ReyLight can we get some clarification on the so called 300 lumens when using 10440 when users claim its no way near that?
I wouldn’t expect a response for a while since it’s a holiday in China for several more days. Really only one sample has been measured which could just be a dud.
