Can anyone tell me - when you are using the smooth ramping mode - can you set it at about 800 lumen and turn off. Will I be able to access moonlight, 800 lm and Turbo? I use these 3 levels a lot. Lights using NarsilM or Anduril lose their programmed level when you access moonlight which is a bummer.
On the V2 I can access all 3 levels any time I want which is nice.
Yes, but you can’t go from moonlight (long press) to the programmed/ramped 800 lumen mode (short press), as far as I know. Turbo is double press.
From moonlight, if you start ramping that will become your new programmed mode. If you turn off from moonlight and then turn on, your previously programmed (800 lumen) mode will be there.
Thanks, it’s got a big FET so it must use PWM, but I’m not seeing current regulators or a resistor bank for a second channel. I’ll see if I can make sense of the design later. The red glue looks to be hiding components.
Also applied a layer of d-c-fix self-adhesive Milky (aka Sand) film under the original glass cover lens to further smooth the beam, works like a charm.
Well I have no technical means of measuring output but these lenses are not significantly lossy. Of course diffusing a beam sacrifices throw, but that’s where my Epileptical ™ reflector shields come in. Just got new supplies so will be refabbing them with extended tubing; that should circumscribe cutoff and proportionally boost range. Will be updating my DIY thread on mtbr so stay tuned.
Well Jason there’s a white plastic gasket that fits around the emitter and the base of the lens’ shell meshes with that, just have to line them up. Easy-peasy.
Didn’t compare heights side by side; though initially I too was under the impression that the lens was shorter, once installed it came up to the correct height inside the lamp head so that when screwed back on over the silicone O-ring the bezel held it in place perfectly. Can’t tell you how surprised I was!
