My Vapcell S4+ Analyzing Charger photos and observations
Last night I did a capacity test session and I can confirm that the high rates I earlier posted as Discharge rates were incorrect but are indeed the Charging rates chosen on the Charging phase of the Capacity test (charge-discharge-portion). Sorry about it.
It should be noted that when the Manual mode in Capacity test is chosen, if you want faster Capacity test process, the charging rates selection can go as high as 3A on all 4 bays during the Charging phase and when the phase goes into the Discharge phase, the S4’s default .5A is used, regardless of the number of bays used.
Is it a good choice for Ni-MH batteries?
Quoted from HKJ’s review:
” With NiMH it worked perfectly for charging. It can also discharge, test batteries and repair batteries, but there are a few inconvenience in some of these modes. A slide switch is used to select between manual or automatic current selection, I like this solution.”
It’s here:
Thank you very much for your review :+1:
Happy New Year everyone
I got mine a couple days ago.
It seems to be working good.
The beeping sound is very subtle and not disruptive. It can be used in a working environment with no issues imo.
The big criticism so far for me is the display. Without the backlight on its almost impossible to read.
But we do have to press a button to cycle between the cells so that will turn the backlight.
The IR readings is super fast and compared to my opus bc700 not too far off so that’s good news.
The minimum charging current is 250ma, I wish it offered 100mah.
It’s the first charger that offers wh (watt/hour) readings, I’m still trying to think how i can use it to determine when it’s time to dispose a cell??
Overall so far it’s working.
Re: watt-hour readings, the SkyRC MC3000 can also display charged and discharged capacity in watt-hours.
But that seem still rare in chargers. Haven’t gotten a Vapcell S4+ charger yet (they don’t ship to our country in economical shipping rate for now)…
deciding between this, and XTAR Dragon .
I was thinking of ordering this charger from liionwholesale for $35.99.
USPS Priority Mail shipping to Texas is $11.26.....a bit high shipping cost
Anyone purchase one there?
It’s $35 shipped from nealsgadgets.com with tatas4
Yes,shipped from China in about a month.I buy as little as possible from China.I give a domestic seller the 1st grabs at my wallet.
Free shipping really means it's already included in the price.
Nothing is free.
I’m confused. I thought you were trying to find a cheaper price. If you want to buy domestic, $12 to ship via USPS Priority is a pretty fair price. Priority Mail shipping prices have gone up a ton over the past 1-2 years.
Can you tell me if it’s possible to fit there 4 x 26650 ?
The Vapcell S4+ could accommodate 2 26650 in the 2 outer bays and 2 21700 in the inner two bays:
Thanks
The Vapcell S4+ is now available at 18650batterystore for $34.99
USPS ground shipping to Texas is $5.61
I see some test that it draw 4.5A while charging 4 batteries at 3A, could be work with a proper car charger (12V 5A)?
Yes, it will work, IIRC, most car lighter 12v receptacles are rated up to 10A.
Thanks
The Vapcell 4+ is also available from Neals Gadgets - here
Whilst far more expensive, my XTAR Dragon VP4 Plus served me well for nearly 3 and half years now. It’s a solid bit of kit.
I feel when test battery capacity using Vapcell S4 Plus, the batteries are too hot. Is that normal?
When I test the same batteries using Lii-500, they don’t even get warm.
Both tests were set at 500 mA current.
