I am growing weary of Banggood. I’ve heard many reports lately of flashlights supposedly being rejected by customs, including a friend that was trying to order a MF01 (full size).
After not hearing anything for a couple weeks about my MF01 Mini order (that supposedly shipped right after I ordered it) and Banggood never providing a tracking number, I finally reached out to them and they informed me that it had been rejected by customs and that the light is no longer in stock and that they’ll have to cancel & refund my order. I don’t get what’s going on… I’ve ordered so many lights from BG, same shipping address, I didn’t order the one with the battery… ugh. And they never reached out to let me know that the light hadn’t made it through customs.
At first I wrote back calmly but firmly with my frustrations and urged them to find a way to ship out my order. But then I noticed that you can get the MT07 from Mateminco (the origin of the MF01 Mini) on Aliexpress for $47 including free ePacket. I guess for a few bucks more I don’t care if BG cancels my order and looses out on the business. Quite frustrating!
Freeme, if you have any contacts over at BG that can look at this, my order number is 78896759 EDIT: nevermind, I just went ahead and let Banggood refund my order. I ordered the MT07 instead.
The same thing happened to me for the FT03 XHP50 in green. What’s the point of having a group buy when Banggood can’t complete the order and then does not tell you, Frustrating to say the least
Well, apparently “ready to ship in 17 days” means “out of stock, we may eventually get more but we’ll happily take your order” according to the Banggood CS person I chatted with. FWIW, I was going for the Gun Grey 5000K.
It was clear to me from the beginning that I would take the Xpl Hi version, it is more expensive but has more lumens.
Since many spoke of a green tint in the SST20 version, it was off the table.
There is a 5000 and a 6500k version of the Xpl Hi version. I have now decided on the 6500k, hope it is not too white or blue, the 5000k would probably be better in color but not as bright.
By chance, who of you has a direct comparison of the 5000 and 6500k.
Is the 6500 really 6500k?
Or would the 5000k have been better?
Unfortunately it is too late, 6500 already on the way!
Any suggestions on where to get a new glass lens for it? I love the light, but dropped it and glass cracked. It is measuring 40mm diameter and 2mm thickness. I can’t find any of that size anywhere.
I think they are cheap generic cells. You’d need to measure the amps it pulls in your mini to get an idea how powerful it actually is. I believe that’s the cell that came with my Cometa. High capacity, but weak. I’m thinking of a different cell.
I dug up the green cell that came with my Cometa that I bought at Banggood. It’s the same exact color, but Vapcell Vappower brand 5200mah. That’s the weak one.
I really dont know much about the green HLY cell other than they are inexpensive. Hopefully someone can do some amp draw tests and see how it compares to known, tested cells.
The 26650 that comes with Cometa is Vappower (not Vapcell… lest they get angry…), I also have it, and appears to be a weaker cell (higher IR).
The HLY seems to compare similarly to the Liitokala Lii-50A (black) — at lower current drain (ie. when doing a discharge test @ 1A discharge current of a fully-charged Lii-50A alongside a fully-charged HLY 26650, they seem to track close to each other, at least at 1A).
Tried using the HLY and Lii-50A on MF01-Mini, seems to yield almost similar Turbo brightness (ceiling bounce, and with lux meter to compare).
The HLY 26650 comes in 2 types: beige and light green. I “guess” the beige one has a slightly newer date code than the ‘light green’ HLY (I’m just guessing the date code markings). I measure AC IR (using YR1030 resistance tester) of ~17mOhms for the HLY 26650. (for Lii-50A, I get different AC IR for different batch, but most are around 17-18mOhms AC IR when measured using the YR1030).
*re “date code” of HLY, only my “guess”, the last 2 digits of the 1st group of 8 alphanumeric characters is probably the year of manufacture (the ‘light green’ has “18” for 2018 and the ‘beige’ HLY has ‘19’ which probably means 2019 year of manufacture.
