Interested
Interested.
Reserved…
Interested, but not until shit gets figured out with Banggood. I’ve had to get 2 refunds in a row for “lights returned because they couldn’t pass customs security check”….
Interested
How might this compare to the SBT90? Same performance at a cheaper price?
With Led Osram CSL N M1.TG, Not interested,
If Led Osram CSL P M1.TG, If interested,
I know it’s less of a pitcher and little difference in lumen, but I still prefer it,
The 1 mm2 Led I see it almost as a laser beam
Interested
Interested depending on price. My FT03S is almost here. If the throw difference is big enough I might buy it but I’ll probably just wait for something with the Boost HX instead.
Interested.
Interested.
It will most certainly be the cheaper one so… take it or… not.
Interested
Interested.
Interested.
Will it be available in the green or blue also?
I agree. The SBT90 I ordered was cancelled.
Interested. I hope there also will be a version with the CSL P M1.TG
Interested
Apples and oranges. The SBT90 is a large die and puts out lots o’ lumens. That translates into a generous hot spot and lots of spill. The Osram is a small die, and lower output. It can’t be pushed as hard, but is a little more efficient. I expect that would translate to fewer lumens, but a more intense hot spot. The OSRAM will have a higher percentage of it’s output in the hot spot; the SBT90 will have more output. Depending on the numbers, the SBT90 might throw farther.
Ehhh, to say the FT03S MIGHT further throw is a tough pill to take with the performance of the W1 chip in a similar form factor the K1 can be used as reference with a similar reflector size and with the already published projected CD of 510k~ for the FT03S I assume the W1 in the FT03 form factor would have similar performance give or take a few thousand CD.
There’s no way that the SBT90.2 will outthrow the W1. K1 does 650kcd so I’d say 550-600kcd 800Lumens for the W1 FT03 makes sense. SBT90.2 should do 400+ kcd 4500Lumens. Haven’t test it but will once I receive it. This will undoubtedly be the furthest throwing light you can get for the money. The question is that is the Lumen trade off worth it for the extra throw.
