Ordered the GooLoo this morningā¦.they were just delivered with Prime same day delivery.
those car jumper things are SUPER BIG power banks!
Sure, but I think there is more to it. I think the car jumpers have additional capacitors in order to help deliver huge amounts of current to help crank the engine. Your typical power bank canāt do that.
Yes. I have a 30K bank that wonāt do it.
wle:those car jumper things are SUPER BIG power banks!
i took apart a $50 broken one, no caps, just 3 flat prismatic li iron phosphate cells
caps that size would not provide more than .1 sec of what a starter needs
the batteries have to do all the work
i was just saying, the power bank function is a side benefit of these things
wle
Absolutely! :+1:
Out of the box the GooLoo showed 2 out of 4 blue dots
The USB C port is the only port for charging the power bank.It's labeled IN/OUT
The 2 USB A ports are labeled OUT
The BLUE USB A port is for fast charging
I connected the GooLoo with the supplied adapter and the USB A to C cable.
The included adapter is rated at 2000mA output but charged at 4.65V/2.47A
After the full charge I used the power bank feature to charge my Google Pixel 3XL using the C to C cable.
Worked well.Took about 20 minutes to go from 74% to 100%.I didn't time it.
Was the phone indicating āCharging rapidly,ā like with a proper PD charger?
Thanks!
Yes,the phone showed the percentage and charging rapidly at the bottom of the lock screen plus time remaining till fully charged
GOOLOO 1500A Peak SuperSafe Car Jump Starter
$49.59 after current $12 off clip coupon and another 23% off with promo code Q4Q3YKM2 (entered at checkout).
The GOOLOO brand seems to be fairly popular in jump packs, but I have no experience with it personally.
Thanks! Just ordered one. Truck battery is 4 years old but struggles below 0 degrees F lately. Do need to replace it. Have older batteries on tenders which sometimes need help in very cold weather. Will report back when it arrives and gets used. Others I was considering are twice as much. Audew is what I was looking at. Amazon.com
I tried charging it with my own wall adapter. Itās pulling 2.9A @ 5.2V.
What mah rating is the Gooloo rated at? Didnāt notice what it was on the Amazon discription. I could have overlooked it I guess.
Edit- Itās 15000 mah. Just looked on their website. There isnāt a 1500a model but it looks like their gp1500 which is supposed to be a new release. Not sure if they are different. Specs look the same or close. I grabbed one just because they seem to get good reviews and āreallyā work.
It is the GP1500 model. 1500A is just a peak current rating.
By the way, does anyone know if the connector pictured below (in blue) is the industry standard EC-5 type? I wanted to pick up a cigarette lighter adapter for it. It looks like EC-5 to me, but some people said otherwise.
HONDARIDER:There isnāt a 1500a model but it looks like their gp1500 which is supposed to be a new release. Not sure if they are different.
It is the GP1500 model. 1500A is just a peak current rating. By the way, does anyone know if the connector pictured below (in blue) is the industry standard EC-5 type? I wanted to pick up a cigarette lighter adapter for it. It looks like EC-5 to me, but some people said otherwise. !{max-width:75%}https://m.media-amazon.com/images/S/aplus-media/sc/1b3b3f61-c9b3-44dc-b3c1-6fbb8cb9d8a0.__CR0,0,970,600_PT0_SX970_V1___.jpg!
There's a 15V, 10A female power tip plug on the other side.
No,it's not an EC5 standard connector.The positive side looks standard but the negative side is probably proprietary with the small pin inside.
If you roll over the image on Amazon of the blue connector you'll get a better view of it.
https://www.amazon.com/dp/B0748D8KT6/ref=psdc_318336011_t2_B0742BBS3W
Isnāt that an output only connector for the jump cables? You modding it for input charging?
I wanted to use it as an output to power devices with a cigarette lighter connector such as a tire inflator.
No,itās not an EC5 standard connector.The positive side looks standard but the negative side is probably proprietary with the small pin inside.
OK, thanks. I was going to order this adapter (Amazon.com) but it sounds like itās not going to work.
Iād need to get this one instead:
https://www.amazon.com/GOOLOO-Cigarette-Lighter-Adaptor-Compressor/dp/B06XFJWYY9
The power OUT barrel connection on the GooLoo GP1500 is 15V/10A
BTW, I wonder how that āpeak currentā is measured. The 400A figure written on the unit is probably more realistic.
Should be enough to jump a typical 4-cyl or 6-cyl engine. Not sure about a big V8.
Has anyone ever used this unit to try to start a vehicle with no battery, connecting directly to the battery cables?
