I agree. The SBT90 I ordered was cancelled.
Interested. I hope there also will be a version with the CSL P M1.TG
Interested
Apples and oranges. The SBT90 is a large die and puts out lots o’ lumens. That translates into a generous hot spot and lots of spill. The Osram is a small die, and lower output. It can’t be pushed as hard, but is a little more efficient. I expect that would translate to fewer lumens, but a more intense hot spot. The OSRAM will have a higher percentage of it’s output in the hot spot; the SBT90 will have more output. Depending on the numbers, the SBT90 might throw farther.
Ehhh, to say the FT03S MIGHT further throw is a tough pill to take with the performance of the W1 chip in a similar form factor the K1 can be used as reference with a similar reflector size and with the already published projected CD of 510k~ for the FT03S I assume the W1 in the FT03 form factor would have similar performance give or take a few thousand CD.
There’s no way that the SBT90.2 will outthrow the W1. K1 does 650kcd so I’d say 550-600kcd 800Lumens for the W1 FT03 makes sense. SBT90.2 should do 400+ kcd 4500Lumens. Haven’t test it but will once I receive it. This will undoubtedly be the furthest throwing light you can get for the money. The question is that is the Lumen trade off worth it for the extra throw.
Interested
Interested.
Interested in a blue one this time, chrome bezel
in for 2 if price is nice
Interested.
Interested.
Im interested
Interested
Interested.
I’d prefer just the MCPCB and driver as I’ve got a dented blue host out of the box (couldn’t be bothered doing warranty claim) that I wouldn’t mind swapping over. But if that first X is a 2, I’m down.
(edit: I see that the SST40 5700K in lower lux bin is $2.09USD each per thousand at Mouser, and the CSLNM1.TG is $1.34 with same MOQ, same place so fingers crossed on that 2.)
Interested
Freeme who is working on this project? Do they (Astrolux) know you can’t direct drive this LED?
Interested
Interested
