Zooming Model List (2018 Updated) Tell us about your newest zoomie!
Guys,
Agro or anyone else with zoomie obsession needed here! Detective work…
I found a small gem of zoomie flashlights host!
It is no name zoomie or no OEM zoomie light with 850nm emitter.
Small review of a host
Simple dissembling job; pill went out without any issues. Aluminum pill with retaining driver ring and build in o ring that enables flashlight head sliding… Pill design is fantastic! No soldering job is needed. Pill has aluminum driver retaining ring. But however it does not have led mcpcb retaining ring so it requires gluing method or adding simple small screws(if someone prefers thermal paste underneath of mcpcb).
Driver is toss in a trash thing… So just toss it in a trash… Simple linear current AMC7135 style driver or mosfet should fit fine. 17mm one of course.
Driver pill cavity is 11,6mm - 3,3mm(retaining ring) for total of 8,3mm of usable 17mm driver cavity. So if someone would like to place buck driver it could be questionable… Take measures first.
Switch is reverse clicky omten style of a switch. Te be more precise it is KAN 28! Another big plus!
It has 23mm diameter acrylic lens inside (usable convex part is 21mm). On top of the lens there is O ring which is pressed via front bezel.
It has exposed tail cap tube threads which is not that good because of safety reasons.With anodized threads we can lock out tail cap of our zoomie lights to prevent accidentally turning on while battery is in the light(uniquefire 1503,1504 for example has anodized threads so we can use that safety feature).
Build quality is very good… Tube, anodizing, knurling, lightweight… Fantastic! But however on mine light somebody forgot to put tail cap O ring although it has cavity for O ring.
The most interesting thing: Shortest head walk(or zoom action) I ever seen! Only 3mm! Very useful and solid reflector light feel with minimum, unnoticeable “head walk”.
I need detectives to find me(find us) manufacturer of this flashlight or cheaper cree LED or bare host version of this light.
I ordered from ali here:
But I also seen it on ebay(several selers) here:
I immediately modded it with vcsel 850nm laser diode(10min job) and it works fantastic. But since I used aa mcpcb glue down method i don’t want to redo and do Osram white flat 1mm for example.
Guys this is really really one solid budget light with just few disadvantages(non anodized threads) that could be fixed if we find manufacturer. Incredible short zoom action is something that need to be checked with classic Cree or Osram leds though.
I’ve seen this light before, I don’t have one. Thank you for reporting it as good. :slight_smile:
May I ask why do you need to know the actual manufacturer? This is typically not easy to find the OEM, even Sofirn indicated that they tended to have troubles with it. And what is usually the most interesting is the seller with the lowest price. At small volumes that’s often some reseller.
Well you can get OEM and even ODM service if you have manufacturer… They have MOQ for such service but if you make arrangement with them anything can be done.
But this really seems like strange non OEM light and as I said performance with real white led emitter should be reviewed. Because it looks quite impossible that this light can have good zoom in or zoom out with just 3mm.
For night vision it is ok. I checked…
Found another source:
I’ve seen Skywolfeye B16 being called MG-A02M by one of sellers.
Searching the model number has led me to:
https://www.ningbosymbol.com/led-flashlights/
Is that the real manufacturer? I have some reservations but maybe.
BTW, here it is in blue with UV LED, available from 1 piece:
The LED Flashlight Model No:AP06 is a pretty good car light.
This may be the OEM for a number of brands.
I did some rough measurements of Skywolfeye B16 lens. Rough because my calipers are plastic junk.
Outer diameter: 14 mm
Diameter of the convex part: 12 mm
Back focal length: 11 mm
The lens is press-fit.
How do you make a waterproof flashlight that zooms, and has a USB port?
I’d suspect hype …
The lens is not bad.
It projects a quite clear image of the LED.
…maybe get some Cree XQ-A and dedome it…
¼ die size of XP-E, or ½ die size of XP-C :laughing:
I’m looking to get my first SK68. Any suggestions on which should be my pick?
Pray.
Take a look at FastTech, there at least you can find some meaningful feedback and customer support pays attention to questions.
Thanks.
With the amount of deception going on on Aliexpress I’m increasingly using other sites. Fasttech has not failed me so far.
I need some more time to read through but I see that the cheapest model is recommended with the only review saying
I think I may splurge on something more expensive though because my gut says that it may be good for $2.81 light but probably not as good as the more expensive variants.
I can’t remember what name it was sold under, but probably 5 or 6 years ago I bought the cheapest standard (black) looking SK68 Fasttech had, and it was the best one I’ve come across to date. YMMV, but the price doesn’t correlate to quality on these it seems.
I’ve got my Skywolfeye B18 (the 14500 version). I expected it to be just as good as B16 (10440) but it’s not.
  1. The zooming action is not as smooth, rocking makes it get stuck sometimes. Not surprisingly zoom travel is larger and requires more force.
  2. Flood is quite narrow, too narrow for my liking
  3. B16 has a very clean throw beam. TBH I don’t understand why is it so, it shouldn’t be so good. B18 is very very ringy. A part of the difference is the plastic holder. With B18 it stays deeper, so LED illuminates it from the sides. B16 has the top of the LED dome just barely over the edge of the holder, so its white surface receives no direct illumination. B18 clearly shows the surface of the area that surrounds the LED. B16 doesn’t and I don’t know why. Die image has equally sharp to my eyes.
  4. B18 has no lanyard hole
  5. I’ve had a few misclicks with B18 shortly after I took it off but later it felt OK
  6. I don’t know how is it with B16 but B18 doesn’t accept flat top cells
I’ll EDC it for a while to get a better idea of how it feels.
Best SK68 I have is the UltraOK one I got from Mountain Electronics. Unfortunately it looks like he’s out of stock.
It has pill with a solid shelf, unlike many of the cheaper SK68s that have hollow pills. Also, its battery compartment is wide enough to hold a 16500 out-of-the box.
Thanks for the recommendation. I did a quick search and there’s UltraOK store on Ali. And they sell SK68…but branded Enjoydeal and very cheap. I won’t take the risk and my pick so far is the cheapest fasttech one. Though I’m waiting for a 15% off at least. :wink:
Good luck!
There are so many different variations of the SK68. I have ones with the following:
  • Original Sipik SK68 - Cree XRE led, single mode, solid pill, 18mm lens, metal C-ring instead of an o-ring under the sliding bezel giving the bezel action a grindy feeling that’s not at all smooth.
  • generic - with 3 modes XPE, o-ring under the sliding bezel instead of a metal c-ring for much smoother action.
  • generic - with 1 mode XPE, o-ring under the sliding bezel
  • generic - generic with XPE and 20mm lens (all the others have 18mm lens), o-ring under the sliding bezel.
  • UltraOK - solid shelf, interior of battery compartment is wider and can accomodate a larger cell, o-ring under the sliding bezel.
https://www.aliexpress.com/item/4000321611399.html
Asafee has a B158 clone and now this new HT line of zoomies with clean looks and interchangeable lenses/heads
B158 here for less than 1/2 the price, but in red or green: https://www.aliexpress.com/item/32831194642.html?spm=a2g0s.9042311.0.0.27424c4dAcJRJS
This is where I bought my last one. I got a SBT90.2 in a B158 now - not bad! Roughly ~300 kcd but it drops fast.
(oops! - corrected)
Asafee one looks way better and appears to have a better switch but who knows what you actually get. Maybe someone else will try and report back :slight_smile:
