SkyRC MC3000 help thread
85 posts / 0 new
klrman
klrman's picture
Last seen: 5 days 5 hours ago
I think you're right FlashTom, it's really more useful for NiMH cells than lithium since there is so much protection in this charger anyway.  I charged some eneloops on my VC4 the other day and they seemed to get too warm for my liking, so will play around with the MC3000 and see how it goes with the eneloops.  At least I can read what heat is coming out of the eneloops with the MC3000 and I think with the C4-12 too.
d_t_a
Last seen: 4 hours 56 min ago
klrman wrote:
I think you’re right FlashTom, it’s really more useful for NiMH cells than lithium since there is so much protection in this charger anyway.  I charged some eneloops on my VC4 the other day and they seemed to get too warm for my liking, so will play around with the MC3000 and see how it goes with the eneloops.  At least I can read what heat is coming out of the eneloops with the MC3000 and I think with the C4-12 too.
I find the default end voltage of Eneloops to be high (1.65v default). If the Eneloop is still a good working one, then it will likely terminate via negative-delta-v (-dv/dt).
But if the Eneloop is old (several hundred mOhms), then it just gets warm and won’t reach 1.65v (and doesn’t seem to reach negative delta v termination?). For now, I manually adjusted the end value to 1.53-1.55v (I think most other chargers are set to 1.48v), I wonder if it’s alright or not..
klrman
klrman's picture
So much for my favorite "reliable" charger!  My SkyRC MC3000 is failing badly.  A few weeks ago bay #1 failed and now Bay #4 is failing.  I had three MC3000's and sold two of them to my friends, which are still working fine,  and I got to keep the crappy one!  On a good note, GB is sending me a new one.  I went over my battery logs and it shows I've used this charger 34 times so far.
I'm starting to question the long term reliability of the mc3000 as others  have noted that the IR readings are starting to go all over the place.  This is how it started with bay-1 with totally out of the park IR figures and then it failed and now starting with bay-4.
d_t_a
When you mentioned bay #1 and #4 failing, can you describe in more detail what failed?
It’s not charging properly, or not showing correct discharge capacity test?
or IR test is now “unreliable”?
My MC3000 (just exactly 1 year old now), have did capacity testing on a lot of mostly 18650s by now, and I frequently use the IR test (press UP & DOWN arrow keys simultaenously).
I’ve noticed some things: the IR testing seems to be higher than before, and I have to do a lot of tries to get the “lowest” values (which is not as low as before) — for instance, my VTC5s used to read 20+ mOhms, now they are more like 30mOhms. I thought this could be my VTC5 becoming “old” and develop higher resistance, but then I bought several new VTC5 again and they also register the “higher” IR readings than before. I think the higher IR readings are for all my batteries (I have some that I kept in storage condition and barely used — I have recorded their IR readings before, and checked again on the MC3000 and they appear to have slightly higher IR reading.)
I think my MC3000 is now giving slightly higher IR readings than before. I have cleaned the contacts (positive & negative) of the terminals but they didn’t seem to improve the IR readings. (ie. slightly higher readings than before, maybe 10-15mOhms higher than my previous jotted-down-notes for batteries I’ve tested).
Another thing: slot #3 & #4 capacity discharge test appears to give lower capacity readings than my slot #1 & slot #2. Something like a variance of 50-75mAh difference in capacity test for the same batteries tested.
(eg. if slot #1 & #2 give reading of 2650 & 2670mAh, then slot #3 & #4 may give something like 2585 or 2595mAh for those same battery…
I have yet to do a more controlled testing though, but the above are my informal observations… I wonder if my MC300 is also failing..
My MC3000 is the single-fan version. Is yours the dual-fan version already?
klrman
klrman's picture
In  bay #1, not charging at all but mAh keeps going higher.  Voltage doesn't move as tested with dmm and giving false reading with mAh.  Sometimes voltage starts going in reverse on the screen too.    Crossed tested on other slots with several batteries and no problem, just bay #1.  Bay #4 has not fully failed yet but almost.  It's giving ridiculous IR readings and when inserting a 3.6V drained battery, often it will right away jump to 4.1V reading.  Slowly going screwy like bay-1 did and I need to keep an eye on it to make sure it's working right when I can get it to.
Your IR readings are still not bad at all, mine were waaay off, I'm talking a 30 IR battery displaying 358 IR and taking endless amount of attempts to bring it down before charging if I ever can bring it down.   Bay 2 and 4 still doing ok.
Mine is the dual fan mc3000 that I got in Feb of this year from GB.
antty7
Last seen: 2 years 9 months ago
So have another MC3000 question. Sorry if this has been answered but I couldn’t find it.
So bought it from Amazon. Newer two fan model. It came with FW 1.13 and everything worked fine, including Bluetooth and the Bluetooth LED on the side. After a day I upgraded it to 1.14, and again worked fine. About a day later the Bluetooth LED is now no longer on and no Bluetooth connectivity. I try a power reset, turning Bluetooth Off, then On, and then a reset to factory settings. Still no Bluetooth. So I return it to Amazon and get another. I receive it, and sure enough, Bluetooth LED not on and no Bluetooth. The setting for Bluetooth is On.
Are these things just faulty or am I doing something wrong?
Terry Oregon
Terry Oregon's picture
Last seen: 5 hours 13 min ago
Make sure you don't ALSO have the MC300 hooked up to your computer at the same time.  As I recall, this will disable bluetooth.
My reviews: , My personal collection of lights LINK,  J5 Tactical V1 Pro review LINK,  Thirteen Optical Sensors review LINKZebralight SC700d review LINK,  Ray-O-Vac Super Power Sportsman review LINK,  Convoy S2+ color combos LINK,  How To flash D4V2 LINK,  Convoy S21A LINK
antty7
The PC software does work, but the Bluetooth LED has never been on with this MC3000, even without the PC connection. Not the end-of-the-world but is nice to have.
Terry Oregon
No clue. I just checked my MC3000 (with two fans). As soon as I open the iPhone app, the blue LED lights up. That means both the MC3000 and the phone app have to be working.
The only thing I can think of - is to install the app on another phone, to see if it's related to the phone. You might try rebooting your phone, just in case the phone's bluetooth module is acting wonky.
antty7
Thanks I think you solved it. I could swear that on my previous one the Bluetooth LED stayed on, but maybe not. So when I had brought up the iPhone app, nothing, but it must have been looking for the old charger Bluetooth. I killed the app. then restarted it the app. and sure enough, I get a Bluetooth light and connection. Its weird that there is no pairing security, but it does work now. Thanks.
antty7
Yeah, even when I turn off the phone, the Bluetooth LED stays on, so maybe Bluetooth LED means it has found a phone and paired. On the MC3000 side, you need to turn off Bluetooth and back on to clear that. On the phone you need to kill the app. to clear the pairing. Not typical Bluetooth behavior but whatever works I guess.
Kajman
Last seen: 7 months 4 weeks ago
Anyone had problem that keys stopped working? All of them.
ChibiM
ChibiM's picture
Last seen: 16 hours 56 min ago
Nope.. I just noticed that my second bay terminates earlier than the others... Sad
ptim
why cant i save changes made in my windows software cycle from c/d/c to d/c to the mc3000 slots?
philco782
Last seen: 1 year 9 months ago
I have a multi-cell battery pack from a Shark cordless vacuum cleaner, has 15 or so NiMH cells in series. I want to build a rig to test each cell’s capacity, 4 at a time, non-destructively, by piercing the skin of the pack with needles. The batteries will still all be in a series circuit for this test, however.
So, I am curious if each of the 4 channels in the MC3000 is completely independent, and able to perform this test?
Kame Sennin
Kame Sennin's picture
I can't be totally sure as i don't have it at hand right now but i am 99% positive (*) that the 4 channel are NOT independent so you can't test several batteries from the same pack without disconnecting them.
(*) From a designer point of view it would add design and production costs with no real benefit for that kind of charger
Kame Sennin
Ok i have verified and while each channel use it's own converter for the charge they are not isolated converters and all use the same 12V input so i confirm that trying to charge batteries that are externally  connected would not work properly (worst case might be a short on 3/4 of the batteries)
philco782
One curiosity of this charger is that if a LiIon battery has been discharged to too low of a voltage, the MC3000 doesn’t want to charge it. What I have to do is connect a charged cell in parallel to the battery sitting in the charger, then start the charge cycle on the MC3000, then I can remove the “jump start battery”.
This is really annoying. Is there an alternate solution, or can somebody recommend a different charger that I can use to “jumpstart” these cells, or basically any high quality charger that will charge a flat battery?
Kevin Z
You need to press & hold the number slot button until it recognises the cell it will then charge as normal.
But it’s your job to tell it how low to discharge it ,is it a protected cell? If so don’t go lower than 3volts because protected cells usually trip at 3volts.
Barkuti
Barkuti's picture
Last seen: 15 hours 52 min ago
Kevin Z wrote:
… ,is it a protected cell? If so don’t go lower than 3volts because protected cells usually trip at 3volts.
Not exactly. The DW01 protection IC, very often used in single cell BMSs, trips at ≈2.4 V. Cell voltage then quickly raises above 3 V (with high to moderate discharge loads) or close to 3 V (with low loads). Related: Discharge protection test @ lygte-info.dk
philco782 wrote:
This is really annoying. Is there an alternate solution, or can somebody recommend a different charger that I can use to "jumpstart" these cells, or basically any high quality charger that will charge a flat battery?
Yup! From the article above:
Deleting a just published post causes the forum thread answer notification to fail. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your soul. Innocent
Keanu Reeves may need your help. Join his Telegram channel here.
Kevin Z
All of my protected cells trip at 3 volts.
philco782
Oh geez. Super annoying Wink I have some cheap 18650 battery holders with wire leads which I connect in parallel to the battery in the MC3000 to get the charge started.
I’m hoping to find some kind of decent charger online that will give a low voltage liion cell a charge without giving a damn about the starting voltage, since this practice of encountering low voltage cells is rather uncommon, but a huge pain in my ass when it does!
Kevin Z
On the skyrc mc3000 you have to hold down the number slot button of the bay that the cell is in, it will then activate that cell.
This is copied & pasted from the manual,
I’ve placed a flat top protected 18650 battery in the bay yet the slot info is stilldisplaying NO BATTERY. How to proceed?- Check if the battery is inserted with correct polarity. Check if the battery terminals do makeproper connection with the slot metal contacts; shift, suspend, or tilt the battery, if needed forsecuring the connection. 0V-batteries are displayed as NO BATTERY, so check if the batteryprotection is tripped; click the slot number button to release the protection
philco782
Kevin Z wrote:
On the skyrc mc3000 you have to hold down the number slot button of the bay that the cell is in.
Isn’t that just a feature to reset a tripped protected cell? I’ve tried this on a unprotected 2v 18650 and it just doesn’t work to charge that battery, the charger still aborts with some kind of voltage warning.
Kevin Z
It works with mine , maybe the charger is telling you the cell is no good!
Try pressing the number slot button repeatedly.
Edit
Did you hold it down for long enough until it recognises the cell?
NorthernHarrier
NorthernHarrier's picture
Last seen: 3 days 13 hours ago
I need help. I just received my new MC3000 a few days ago. I’ve saved six charging programs, and I can see why this charger is so highly regarded. The charger seems to be charging NiMH and Li-ion cells correctly. I have a problem, though: I can’t get the charger to copy the program saved to one slot to all of the other slots.
I have tried the following procedure several times: 1) saving one of my programs to slot 1; 2) clicking the Slot 1 button and the up arrow button at the same time. When I complete steps 1 and 2, above, instead of copying the program saved to slot 1 to the other three slots, the charger saves “Program 12” to three slots I have not programmed. I have not created a Program 12. I have no idea what I’m doing wrong, and I have no idea why the charger is doing this. Can someone help?
Thanks in advance.
"However vast the darkness, we must supply our own light." - Stanley Kubrick
Kame Sennin
This mean that the default pgm for slot 1 is pgm 12 instead of pgm 1
To set the default pgm for slot  1 you have to
  • press the stop button until you enter setting
  • scroll down with down arrow and find the "SNB# 1 Memory" line
  • press enter
  • up or down arrow until you reach the required pgm number
  • press enter
  • Long press enter to save and exit setting
klrman
klrman's picture
Google skyrc mc3000 cheat sheet and download the pdf.  The info you need is on the first page under "copy your favorite program"
Kame Sennin
The cheatsheet is very helpfull and i second downloading it if you haven't done that already but it doesn't explain that, iirc the full manual does
NorthernHarrier
  • scroll down with down arrow and find the “SNB# 1 Memory” line
  • press enter
  • up or down arrow until you reach the required slot number
  • press enter
Merci bocoup! Neither the instruction manual nor the “Cheat Sheet” on the SkyRC website explain that! They seem to say you can copy any saved program selected for a slot to the other slots – which is apparently not true, unless the program is the default program for one of the four slots. I appreciate your help.
Edit: looking at the instruction manual discussion of the Global Settings View, I can see that it does talk about setting up the automatic copy and paste of up to eight saved favorite programs with the slot number buttons and up and down arrows. However, in the section on using the Total Overview, it says you can copy and paste programs stored under a shortcut. When I read that, and I looked at the Cheat Sheet, I had the impression that it was possible to cut and paste any program saved to a slot. Not true! Now, thanks to the help you provided, I can see how the process works.
