I tried that, holding the 2nd screw with a Torx while unscrewing the 1st screw, then only the 2nd screw comes out, while the 1st still in same position. I’m unable to get the 1st screw both longer in and further out, its totally locket in that position. Think I will need to dismantle the knife, getting out the bolt with with that screw, and then try to get it loose.
Then you’ll need to disassemble the knife so you can access and hold the barrel while you’re untying the screw.
Although, if it is that stuck, there is a chance you will strip or break the screw.
Once dismantled, I would try to hold the screw in a vise and try to rotate the barrel using locking pliers maybe?
Odd, I have a few CH knives and never had any issue with them.
Use a soldering iron to heat up the screw so you can melt the loctite, still you may damage the barrel if you need to grip it with pliers, might want to try some thin leather on either side of the jaws
I had to get in on the TwoSun fun. I got the Ti handled TS38 quite some time ago. Found out it was really really slippery when my hands were a bit damp. To my surprise they have a G10 liner lock version as well. I had no idea. Grabbed it off of Ebay. Besides the pocket clip, I love it. Very grippy. I’ll have to work on that clip though unless, someone knows a clip that fits it. The tip of the clip just sticks out waiting to get hooked on something.
The Trident tactical knife consists of the main knife body, a tactical sleeve, and a tactical umbrella rope. It measures about 235mm in length while the blade length measures 98mm, offering a thickness of 4mm and weighing at 232 grams.
The company adds that the knife is made up to 440C Stainless Steel and has a titanium coating. It has three different kind of blades — tooth, cutting, and chopping. It also support one other functionality — bottle opening. Further, the company says that the tail hammer of the knife can break the glass, which can be helpful in a situation which needs escaping.
As for the ergonomic design, it comes with a K10 composite fiber handle having a non-slip pattern. It also has a three-dimensional grooves for the finger placement to ensure that the grip is tight on the handle.
Not all ef (Eafengrow) knives are junk. Like everything else, you get what you pay for. I got an EF906 for Christmas & it is a serious instrument. They do a lot of clones which a lot of people are apposed to.
My recommendation is to stick to the titanium handled models which start at about $40. Also look for reviews. LTK on Youtube & a few others review many of Eafengrow knives.
I own a couple of EF (Eafengrow) folders and I like them. They are not as refined as a SRM Land 910plus or 9103 but for less than $20 shipped they are solid performers.
I have an EAB & also recommend it.
A while back, my clip broke. I called Gerber & they sent me a new clip right away. It is a compact & extremely useful instrument. The value is definitely worth the cost.
