I tested my two new E07 additions with the Texas Ace Lumen Tube calibrated with Maukka lights and Sekonic C-800-U spectrometer. Lumens taken at 2 seconds.
E07 Copper XP-L HI 5A
Turbo
7,112 lumens
4252K
-0.0047 DUV
72.2 CRI
-17.2 R9
45.9 R12
67 Rf
98 Rg
30T
Mode 7
2,397 lumens
4157K
-0.0041 DUV
72.1 CRI
-17.6 R9
45.6 R12
67 Rf
99 Rg
30T
Mode 6
976 lumens
4067K
-0.0030 DUV
72.4 CRI
30T
Mode 5
373 lumens
3956K
-0.0010 DUV
72.8 CRI
30T
Mode 4
171 lumens
3958K
-0.0010 DUV
72.8 CRI
30T
Mode 3
66 lumens
3945K
-0.0008 DUV
72.8 CRI
30T
Mode 2
16 lumens
3947K
-0.0008 DUV
72.9 CRI
30T
Mode 1
3 lumens
3908K
-0.0004 DUV
73.0 CRI
30T
E07 SST-20 4000K FA3
Turbo
4,310 lumens
4120K
-0.0038 DUV
95.5 CRI
86.7 R9
84.3 R12
92 Rf
103 Rg
40T
E07 SST-20 4000K FA4
Mode 7
1,750 lumens
4165K
-0.0010 DUV
94.4 CRI
87.4 R9
82.0 R12
92 Rf
103 Rg
40T
E07 SST-20 4000K FA5
Mode 6
752 lumens
4159K
0.0001 DUV
96.0 CRI
40T
E07 SST-20 4000K FA6
Mode 5
324 lumens
4055K
0.0006 DUV
97.8 CRI
40T
E07 SST-20 4000K FA7
Mode 4
148 lumens
4045K
0.0004 DUV
97.8 CRI
40T
E07 SST-20 4000K FA8
Mode 3
58 lumens
4058K
0.0003 DUV
97.8 CRI
40T
E07 SST-20 4000K FA9
Mode 2
14 lumens
4072K
0.0001 DUV
97.4 CRI
40T
E07 SST-20 4000K FA10
Mode 1
3 lumens
4076K
-0.0001 DUV
97.0 CRI
40T
The FA3 tint bin is the rosiest SST-20 4000K I've seen to date and I've seen MANY! It's better looking than the FD2 in the FW3A, FB4 in the Emisars, FD2 in the Mateminco/Astrolux, FB4 in the Acebeams but it is still nowhere as rosy as the XP-L HI 5A tint, which is perfection. The copper E07 is gorgeous! It's a must own for any flashaholic! Goes really well with the Red Aux light IMO. Also this time around UCL lens didn't improve the tint much. Only dropped DUV by about -0.0003 to -0.0004, which is not noticeable at all. The UCL lens improved tint much more in the older E07 batches. I guess the lens used in the recent batches are improved from the older batches.
Edit: I just realized that the optic used in my latest two E07 is narrower throw than the optic used in the older E07. Comparing my new E07 SST-20 with older E07 SST-20 and comparing my new E07 XP-L HI with older E07 XP-L HI, it is very obvious that the hotspots from the newer E07 are smaller compared to the hotspots of the older batch of E07 using the same emitter. However, I cannot tell a visual difference in the optics.
So my (new to me, bought used) e07 has crushed the top of my Sofirn 21700…was there any resolution to fixing this issue? As far as i can tell, my version is one of the newer models…
do u have maybe a 40t or something ? i know in my old e07 that one fits barely but it does, my vapcell 20a doesnt too long… but if the sofirn isnt protected it makes no sense…
I bought one of the first batch produced. It was pre-Anduril. It had a simpler ramping interface. The one you have sounds like an early version. Could it be these, above, are ‘new old stock’ for sale?
Recently I received a Fireflies E01 with 5000K SST40 and was surprised to find that it no longer has the simplified version but the ‘real’ Anduril with candle, lightning storm and all the blinkies.
Ok, so, now that I’ve read this entire thread, I’ve learned a lot. The only thing that I still don’t understand is the debate on a 30T battery vs. 40T. Without getting really technical, which one is the best for the E07?
30T is for lumen testing only. No noticeable output differenc e in reality. 40T and P42A is best for XPL HI and SST20 std cri versions. Lishen LR2170SF best for SST20 hi cri and 219b
*SKV89, I’m having a MF01 Mini 4000K SST-20 FD which is going to be modded with the copper heatsink, so it’s also a opportunity to swap the leds.
In the beginning I was opting for the 219B SW40 but someone told me they are too violet under clear narrow tir optics. Besides I’m not thrilled to loose both output and range.
Do you consider swapping the FD2 SST-20’s to FA3 worthy?
The tint of the FD2 is okay-ish but far from decent imo.
From what I know, only Fireflies have the FA3 tint. Where do you plan to buy them from? Personally, I think DUV even on the BBL still appears kind of yellowish to me. You can see my test results in the Fireflies thread. I prefer DUV –0.02 to –0.06. Makes whites look whiter. Where did you get your SW40 from? Usually the SW40 is on the BBL unless you bought it from Clemence which is rosy but not as rosy as SW45K. I like the tint on the Clemence sw40 alot. Much more so than the SW45k. Btw, only the K versions are guaranteed rosy. With 4000K, I never think it looks magenta even if it is very rosy. With 4500k, it can get slightly magenta with very negative duv depending on how your eyes are adapted because 4500k contain more blue than 4000k.
What I think would be awesome is if you mix the SST-20 2700K with the SST-20 4000K. Should end up about 3500K but with decent rosy tint. Another possibility I was just dreaming about is mixing LH351D 2700K with LH351D 5700K 90CRI.
