can you post your code that you have now with the PWM output working?
Heres a link, it wouldn’t post correctly in the forum Dropbox - flashlight attiny85.txt - Simplify your life
Ok, now I got ya. Here we call “driver” the entire schematics with microcontroller and everything, not just what you call led “driver”.
Without a specific cap for offtime, the method tterev3 mentions is your best bet. Timing can vary a little, but RAM in older generation ATtiny’s (13a/25/85) usually decay within a second or so. The newer series 1 don’t decay for ages even with 1uF input cap. My “no_init” RAM lasts over 10 minutes, I havn’t bothered testing further.
you can also use parts of Bistro HD OTSM code without an OTC
It has the MCU powered during off time in a low drain state from a 47uF capacitor
I can help you with hardware all the way from design, to prototyping and final production in small quantities
I am pretty familiar to use existing BLF firmware but I can’t program much mainly config the settings code
if you once tried Bistro HD OTSM you may consider rather modify it that writing something on your own
Can you provide an example of a more modern processor Mike C?
Try this. Not sure where your source came from - appears to have some Arduino-based I/O functions? Are you doing this in Atmel Studio with the compiler or in Arduino?
#include <avr/sleep.h>
#ifndef cbi
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#endif
#ifndef sbi
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
#endif
//**here you set brightness of modes
int mode1 = 255;
int mode2 = 8;
const int ledPin = 0; // setting LED pin
unsigned int key __attribute__ ((section (".noinit")));
unsigned int mode __attribute__ ((section (".noinit")));
void setup() {
if(key==12345){ //check if RAM is still valid from last time
mode++; //yes, advance to next mode
if(mode>2) {mode=0;}
else{ //long power loss. default to first mode
mode=0; //default mode after long power off
key=12345; //initialize key for next power loss
pinMode(ledPin, OUTPUT); // Sets LED as output
sbi(GIMSK,PCIE); // Turn on Pin Change interrupt
sbi(PCMSK,PCINT1); // Which pins are affected by the interrupt
//mode one: LED is set to 100% brightness by default
int modeone() {
analogWrite(ledPin,mode1);
//mode two: LED is set to your preference of brightness (my default is about 30% = 76)
int modetwo() {
analogWrite(ledPin,mode2);
//mode three: strobe light, I set it to be the most disorienting in darkness but feel free to change on and off times (in [ms])
int modethree() {
digitalWrite(ledPin,HIGH);
delay(15);
digitalWrite(ledPin,LOW);
delay(100);
void loop() {
switch(mode){
default:
case 0:
modeone();
break;
case 1:
modetwo();
break;
case 2:
modethree();
break;
//loop end
void system_sleep() {
cbi(ADCSRA,ADEN); // Switch Analog to Digital converter OFF
set_sleep_mode(SLEEP_MODE_PWR_DOWN); // Set sleep mode
sleep_mode(); // System sleeps here
sbi(ADCSRA,ADEN); // Switch Analog to Digital converter ON
ISR(PCINT0_vect) {
Newbie here
What coding language is this?
Yes I am using Arduino IDE.
I’m using the ATtiny3217 for all of my own projects, ever since BLF user gchart paved the way with the 1-series: Adventures in TinyAVR 1-Series
I don’t know of anyone else here using the 1-series but I haven’t been keeping up much lately.
Also for what he is aiming of firmware functionality the 25 should be well enough space and connectivity
Maybe even the 13a is enough for ultra cheap build
there we have BLF firmware he can partially use or modify
Newbie here
C / C. So you’re thinking of starting with C?
BTW - There’s an ATTINY85 dev board that plugs directly into USB and is supported by Arduino. Unfortunately, the bootloader takes up ~2K of ROM.
Can someone refer to me more about this, what light is used and how to you “hook the light up to each voltage”? This is in the Bistro-tripledown code -
CALIBRATION
* To find out what values to use, flash the driver with battcheck.hex
* and hook the light up to each voltage you need a value for. This is
* much more reliable than attempting to calculate the values from a
* theoretical formula.
* Same for off-time capacitor values. Measure, don’t guess.
The light that is used is the one you’re writing the firmware for! You hook the light up to one voltage at a time by connecting it to a regulated supply, and write out the ADC result for each voltage you care about.
you don’t need to do any voltage calibrations if the code you are using is the one you posted - it has no battery measurement functions in it
I’ve been working on this all week, can seem to get a working hex file. I’ve tried it in AVR Studio 7 and Arduino, no luck. In Arduino, I get errors that end with “#include nested too deeply”.
Can someone help me out with a hex file?
Trying to use Bistro HD firmware here [UPDATE:v1.7.1,Q8&1chanOTSM]bistro-HD, bistro your way. OTSM, eswitch(devel), Vcc reads, safe_presses, turbo timeout...
I thought you said the file you posted before was working to output the pwm you needed. Did you try the modified version I replied with?
tterev3 yes I tried it and couldn’t get it to compile in arduino. It did build in AVR Studio, but couldn’t get it to load due to signature differences (yes the correct chip ATtiny25 was selected.
I set the fuses to
Low: 0xd2
High: 0xde
Ext: 0xff
It threw a warning and I proceeded with programming the fuses, and it has bricked 4 chips so far. I’ve overnighted more chips so I should have them tomorrow.
What compile errors?
Arduino: 1.8.10 (Windows 10), Board: “ATtiny25/45/85, ATtiny25, Internal 1 MHz”
In file included from sketch\tk-delay.h:24:0,
from C:\Users\pops\Documents\Arduino\sketch_jan21a\sketch_jan21a.ino:164:
tk-attiny.h:11:5: error: redefinition of ‘int mode1’
int mode1 = 255;
In file included from C:\Users\pops\Documents\Arduino\sketch_jan21a\sketch_jan21a.ino:58:0:
sketch\tk-attiny.h:11:5: note: ‘int mode1’ previously defined here
int mode1 = 255;
tk-attiny.h:12:5: error: redefinition of ‘int mode2’
int mode2 = 8;
sketch\tk-attiny.h:12:5: note: ‘int mode2’ previously defined here
int mode2 = 8;
tk-attiny.h:15:11: error: redefinition of ‘const int ledPin’
sketch\tk-attiny.h:15:11: note: ‘const int ledPin’ previously defined here
tk-attiny.h:17:54: error: redefinition of ‘unsigned int key’
unsigned int key attribute ((section (“.noinit”)));
sketch\tk-attiny.h:17:14: note: ‘unsigned int key’ previously declared here
tk-attiny.h:19:55: error: redefinition of ‘unsigned int mode’
unsigned int mode attribute ((section (“.noinit”)));
sketch\tk-attiny.h:19:14: note: ‘unsigned int mode’ previously declared here
sketch\tk-attiny.h: In function ‘void setup()’:
tk-attiny.h:21:6: error: redefinition of ‘void setup()’
void setup() {
sketch\tk-attiny.h:21:6: note: ‘void setup()’ previously defined here
void setup() {
sketch\tk-attiny.h: In function ‘int modeone()’:
tk-attiny.h:38:5: error: redefinition of ‘int modeone()’
int modeone() {
sketch\tk-attiny.h:38:5: note: ‘int modeone()’ previously defined here
int modeone() {
sketch\tk-attiny.h: In function ‘int modetwo()’:
tk-attiny.h:43:5: error: redefinition of ‘int modetwo()’
int modetwo() {
sketch\tk-attiny.h:43:5: note: ‘int modetwo()’ previously defined here
int modetwo() {
sketch\tk-attiny.h: In function ‘int modethree()’:
tk-attiny.h:48:5: error: redefinition of ‘int modethree()’
int modethree() {
sketch\tk-attiny.h:48:5: note: ‘int modethree()’ previously defined here
int modethree() {
sketch\tk-attiny.h: In function ‘void loop()’:
tk-attiny.h:56:6: error: redefinition of ‘void loop()’
void loop() {
sketch\tk-attiny.h:56:6: note: ‘void loop()’ previously defined here
void loop() {
sketch\tk-attiny.h: In function ‘void system_sleep()’:
tk-attiny.h:74:6: error: redefinition of ‘void system_sleep()’
sketch\tk-attiny.h:74:6: note: ‘void system_sleep()’ previously defined here
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:30:0,
from sketch\sketch_jan21a.ino.cpp:1:
sketch\tk-attiny.h: In function ‘void __vector_2()’:
tk-attiny.h:81:5: error: redefinition of ‘void __vector_2()’
ISR (PCINT0_vect) {
sketch\tk-attiny.h:81:5: note: ‘void __vector_2()’ previously defined here
ISR (PCINT0_vect) {
In file included from sketch\tk-voltage.h:23:0,
from C:\Users\pops\Documents\Arduino\sketch_jan21a\sketch_jan21a.ino:166:
sketch\tk-attiny.h: At global scope:
int mode1 = 255;
int mode1 = 255;
int mode2 = 8;
int mode2 = 8;
void setup() {
void setup() {
int modeone() {
int modeone() {
int modetwo() {
int modetwo() {
int modethree() {
int modethree() {
void loop() {
void loop() {
ISR (PCINT0_vect) {
ISR (PCINT0_vect) {
In file included from C:\Users\pops\Documents\Arduino\sketch_jan21a\sketch_jan21a.ino:166:0:
sketch\tk-voltage.h: In function ‘void ADC_on_temperature()’:
sketch\tk-voltage.h:42:20: error: ‘V_REF’ was not declared in this scope
ADMUX = (1 << V_REF) | (1 << ADLAR) | TEMP_CHANNEL;
sketch\tk-voltage.h:42:44: error: ‘TEMP_CHANNEL’ was not declared in this scope
sketch\tk-voltage.h:47:44: error: ‘ADC_PRSCL’ was not declared in this scope
ADCSRA = (1 << ADEN ) | (1 << ADSC ) | ADC_PRSCL;
sketch\tk-voltage.h:47:44: note: suggested alternative: ‘ADC_CRIT’
ADC_CRIT
sketch\tk-voltage.h: In function ‘void ADC_on()’:
sketch\tk-voltage.h:55:20: error: ‘ADC_DIDR’ was not declared in this scope
DIDR0 |= (1 << ADC_DIDR);
sketch\tk-voltage.h:55:20: note: suggested alternative: ‘ADC_on’
ADC_on
sketch\tk-voltage.h:57:20: error: ‘V_REF’ was not declared in this scope
ADMUX = (1 << V_REF) | (1 << ADLAR) | ADC_CHANNEL;
sketch\tk-voltage.h:57:44: error: ‘ADC_CHANNEL’ was not declared in this scope
sketch\tk-voltage.h:59:44: error: ‘ADC_PRSCL’ was not declared in this scope
sketch\tk-voltage.h:59:44: note: suggested alternative: ‘ADC_CRIT’
ADC_CRIT
C:\Users\pops\Documents\Arduino\sketch_jan21a\sketch_jan21a.ino: In function ‘void save_mode()’:
sketch_jan21a:234:27: error: ‘EEPSIZE’ was not declared in this scope
eepos = (eepos+1) & ((EEPSIZE/2)–1); // wear leveling, use next cell
C:\Users\pops\Documents\Arduino\sketch_jan21a\sketch_jan21a.ino:234:27: note: suggested alternative: ‘EEPE’
EEPE
C:\Users\pops\Documents\Arduino\sketch_jan21a\sketch_jan21a.ino: In function ‘void save_state()’:
sketch_jan21a:240:24: error: ‘EEPSIZE’ was not declared in this scope
#define OPT_firstboot (EEPSIZE-1)
C:\Users\pops\Documents\Arduino\sketch_jan21a\sketch_jan21a.ino:251:34: note: in expansion of macro ‘OPT_firstboot’
eeprom_write_byte((uint8_t *)OPT_firstboot, firstboot);
C:\Users\pops\Documents\Arduino\sketch_jan21a\sketch_jan21a.ino:240:24: note: suggested alternative: ‘EEPE’
C:\Users\pops\Documents\Arduino\sketch_jan21a\sketch_jan21a.ino: In function ‘void restore_state()’:
C:\Users\pops\Documents\Arduino\sketch_jan21a\sketch_jan21a.ino:270:39: note: in expansion of macro ‘OPT_firstboot’
eep = eeprom_read_byte((uint8_t *)OPT_firstboot);
C:\Users\pops\Documents\Arduino\sketch_jan21a\sketch_jan21a.ino: In function ‘void set_output(uint8_t, uint8_t, uint8_t)’:
sketch_jan21a:406:5: error: ‘FET_PWM_LVL’ was not declared in this scope
FET_PWM_LVL = pwm1;
sketch_jan21a:407:5: error: ‘PWM_LVL’ was not declared in this scope
PWM_LVL = pwm2;
sketch_jan21a:408:5: error: ‘ALT_PWM_LVL’ was not declared in this scope
ALT_PWM_LVL = pwm3;
C:\Users\pops\Documents\Arduino\sketch_jan21a\sketch_jan21a.ino: In function ‘uint8_t read_adc_8bit()’:
sketch\tk-voltage.h:31:25: error: redefinition of ‘uint8_t read_adc_8bit()’
#define get_temperature read_adc_8bit
C:\Users\pops\Documents\Arduino\sketch_jan21a\sketch_jan21a.ino:482:9: note: in expansion of macro ‘get_temperature’
uint8_t get_temperature() {
sketch\tk-voltage.h:70:9: note: ‘uint8_t read_adc_8bit()’ previously defined here
uint8_t read_adc_8bit() {
C:\Users\pops\Documents\Arduino\sketch_jan21a\sketch_jan21a.ino: In function ‘uint8_t read_otc()’:
sketch_jan21a:501:20: error: ‘CAP_DIDR’ was not declared in this scope
DIDR0 |= (1 << CAP_DIDR);
C:\Users\pops\Documents\Arduino\sketch_jan21a\sketch_jan21a.ino:501:20: note: suggested alternative: ‘CAP_MED’
CAP_MED
sketch_jan21a:503:20: error: ‘V_REF’ was not declared in this scope
ADMUX = (1 << V_REF) | (1 << ADLAR) | CAP_CHANNEL;
sketch_jan21a:503:44: error: ‘CAP_CHANNEL’ was not declared in this scope
sketch_jan21a:505:44: error: ‘ADC_PRSCL’ was not declared in this scope
C:\Users\pops\Documents\Arduino\sketch_jan21a\sketch_jan21a.ino:505:44: note: suggested alternative: ‘ADC_CRIT’
ADC_CRIT
C:\Users\pops\Documents\Arduino\sketch_jan21a\sketch_jan21a.ino: In function ‘int main()’:
sketch_jan21a:524:20: error: ‘CAP_PIN’ was not declared in this scope
DDRB |= (1 << CAP_PIN); // Output
C:\Users\pops\Documents\Arduino\sketch_jan21a\sketch_jan21a.ino:524:20: note: suggested alternative: ‘CAP_MED’
CAP_MED
sketch_jan21a:528:19: error: ‘PWM_PIN’ was not declared in this scope
DDRB |= (1 << PWM_PIN); // enable main channel
C:\Users\pops\Documents\Arduino\sketch_jan21a\sketch_jan21a.ino:528:19: note: suggested alternative: ‘M_PI’
M_PI
sketch_jan21a:529:19: error: ‘ALT_PWM_PIN’ was not declared in this scope
DDRB |= (1 << ALT_PWM_PIN); // enable second channel
C:\Users\pops\Documents\Arduino\sketch_jan21a\sketch_jan21a.ino:529:19: note: suggested alternative: ‘NOT_A_PIN’
NOT_A_PIN
sketch_jan21a:532:19: error: ‘FET_PWM_PIN’ was not declared in this scope
DDRB |= (1 << FET_PWM_PIN); // enable third channel (DDB4)
C:\Users\pops\Documents\Arduino\sketch_jan21a\sketch_jan21a.ino:532:19: note: suggested alternative: ‘NOT_A_PIN’
NOT_A_PIN
exit status 1
This report would have more information with
“Show verbose output during compilation”
option enabled in File -> Preferences.
That does not appear to be generated from the file I posted
