I’m interested what 2700+5700 would look like… can’t decide if I wanna go mad scientist or play it safe
If you can solder, H04RC is unlike ZL or AT, it’s very mod friendly. You can simply swap the LED modules later.
[Clemence]
Ah, I didn’t think of that. Would I be able to have the spare emitters be shipped with this purchase?
Edit: phrasing
Yes, price is $10 for each additional quadtrix E21A LED module, and $8 for each quadtrix E17A.
[Clemence]
You’re more than welcome. I should’ve worked with Skilhunt before, they’re more flexible than the other company. This mod is driven by popular demand.
[Clemence]
Is the 75$ with shipping included ? the crossed out makes it a bit ambiguous.
Yes $75 includes shipping
[Clemence]
Looks like I missed out on the early bird as well
Can someone kindly catch me up on E17A vs E21A? e.g. is there much difference in beam profile / throw, runtimes etc.
Roughly:
The E21 has an XP-G / 219C size die, and the E17 has half the mm² surface area die of the E21, so E17 is comparable with XP-E die size.
The E21 can safely handle max. 2 Amperes and the E17 can safely handle max. 1 Ampere.
So a quad of E21 can handle 8 Amperes and a quad of E17 can handle 4 Amperes.
So i think a quad of E17 would be more than enough to handle the power of the H04.
A quad of E17 is also much smaller so it will be less floody (tighter beam) and probably have less ‘donut hole’ effect.
But the donut will be evened out by the optics anyway (i assume)
Probably the E21 quad will have better efficiency because they will have an easy job, below half of their maximum recommended current.
But they cost twice as much as the E17, but the LED boards for both are equally priced and not cheap, so for the total price of this modded Skilhunt, the difference is negligible.
The driver of the light will determine the current and thus the run time, wich will be about the same, but maybe a bit longer for the E21 because it will work on a slightly lower Vf because they run at less than half the max. recommended current.
So in all, it seems the quad E21 is the most attractive option for buying this light.
Well said Jerommel, thank you :+1:
For CW and WW, I suggest to use E21A unless you need throwy confined hotspot. Or if you need pure RGBAL color headlamp.
[Clemence]
I decided to go with E17a. The slight drop in efficiency/output is more than compensated by the much higher intensity in the beam. I think it is easy to get a floody beam using a diffused wide optic, but its harder to get a throwy beam. I think the E17a quad board will give me a better range to chose between throwy and floody. The higher intensity in the beam means I will likely use the headlamp in a lower mode, another reason why I won’t worry about the efficiency difference.
If I had more money, I would probably get one of each
Awesome, exactly what I was looking for, thanks guys. I’ll look into them a bit more before committing.
Quote from another thread:
… the tint shift from low mode to high is very pronounced in E21A (neutral to pinkish)…
Is that how they will behave in this H04 as well? (I’m not sure what power levels were being referenced and how that compares to this H04).
Do we have any sense on what the optical efficiency of these two quad die setups are? Is this something maukka can measure? I’m under the impression that the larger the LES, the more losses there are OTF in these TIRs. If this is true, does the gap between the 17 and 21 close?
clemence wrote: … the tint shift from low mode to high is very pronounced in E21A (neutral to pinkish)…
Yup, just like any normal LED. But 4P setup means 4 times less tint shift
Quadtrix E21A gap = 0,2mm. Total LES = 6,22mm
Quadtrix E17A gap = 0,1mm. Total LES = 4,95mm
I’m sure Maukka will do a thorough test about this
[Clemence]
I received several questions about my Skilhunt H04RC modification. But today I received an interesting question:
Only around 200 lumens with 4 x E21A 2700K appears quit useless to my eyes as far as I can get 195 lumens OTF with my Xenon Seraph SP-6 in 9volts configuration for 50 minutes without any kind of overheat and a perfect rendering.
Is it due to the host termal regulation limits (for the M200) ? Do there is any option to get at least 300 OTF lumens with a single 18650 and, of course, the E21A 2700K ? Maybe a larger body host like a Convoy S12 for example ?
Le 22/01/2020 à 12:47, ViRenCe a écrit :
Honestly the Seraph SP-6 has very good dissipation, I know it because the first time I used it with the HO-4 incan module (which is not 9v but only 4v with 150lumens out of the bulb) for a long time (45minutes) I disassembled the head to be sure the module wasn’t burning as I didn’t feel the head really warm, but the module and the bulb were totally cold so the termal dissipation seems to work well on this light at least for incans modules. The head for 9v is even bigger and can handle brighter incan module like 320 or 380lumens from the bulb without any overheat issue.
That’s why I’m wondering of the efficiency of LEDs… which doesn’t seems to be a lot better than incan xenon when we speak about very high CRI.
What’s the Maukka’s test result ?
If there is no solution I would probably go for the incans for high output high CRI, but in this case would it be possible to get a M200 with 4 x E17A in Amber color ? What kind of output can we get with ?
Le 22/01/2020 à 13:36, ViRenCe a écrit :
I understand, but if only one LED can do approximately the same, why putting 4 ?
Better lifespan ?
But anyway, I will wait for the final results as well.
Thanks you for your time.
Le 22/01/2020 à 14:06, ViRenCe a écrit :
- Incandescent lights generates the heat outwards towards the emission direction, unlike LED, which generates most of the heat downwards. This is why you can make powerful incandescent lights body from plastic.
- Skilhunt limit the max current (then output) to only 2,5A and then stepping down to 800mA in 2 minutes for very good reason: this is one of the most compact 18650 headlamp with powerful output, there’s just not enough surface area and mass (for temporary heatsinking) for continuous max mode. At 800mA (mode 7, next lower mode) the headlamp is already very warm after 10 minutes of continuous use. Restarting the max mode every time it stepped down makes it scorching hot in few minutes.
- LED efficiency is inversely proportional to the current. The higher the current, the less efficient it becomes. By using 4 LED instead of one, we reduce the input and increase efficiency. Using 4 LED in 4P like on this H04RC also lowers required voltage - longer regulated runtime (about 30 minutes extra in case of H04RC). This headlamp uses constant current buck driver. A buck driver can only regulate preset current as long as there’s still enough voltage uphill. When the battery voltage gets lower than the voltage needed by the LED at preset current, the current also goes down - no more regulation. The output will now follow the battery voltage until there’s no meaningful voltage to drive the LED. Any CC buck driver requires certain minimum voltage to work, in H04RC there’s internal protection at ~2,8V to save the battery from over discharge.
I don’t know about those Xenon bulb but, my gut feeling tells me it’s still less efficient than most high CRI LED. As for the output, make sure it’s real measured out the front after all optical losses.
Condition Tj = 85°C
Bare LED
At 2,5A a single XML2 - U2 CRI 70:
LED output = 919,2 lm
LED voltage (4P) = 3,24 V
LED power = 8,089 watt
LED efficiency = 113,64 lm/watt
Condition Tj = 85°C
Bare LED
At 2,5A (625mA/LED) 4x E21A D320 CRI 70:
LED output = 1094,3 lm
LED voltage (4P) = 2,8575 V
LED power = 7,144 watt
LED efficiency = 153,12 lm/watt
Condition Tj = 85°C
Bare LED
At 2,5A (625mA/LED) 4x E21A D220 CRI 9080:
LED output = 744,5 lm
LED efficiency = 104,2 lm/watt
From the calculation above, you can see why I don’t trust advertised Skilhunt (and most manufacturers) number for 1200 lm output out from a single XML2. Even using XML2 with U4 bin (the brightest available), at 3A (with 2x 18350) you can only get 1197 lumens before those plastic lens transmission losses. And that at junction temp 25°C, which is very unrealistic. Your LED can still overheats in –16°C air environment
[Clemence]
I don’t know about those Xenon bulb but, my gut feeling telling it’s still less efficient than most high CRI LED. As for the output, make sure it’s real measured out the front after all optical losses.
I don’t know much about it either, but according to wikipedia it’s between 30 and 55 lm/W.
Looking at the charts I’m surprised the output loss is so severe. According to TA tests, E21A CRI9080 at 2.5A has the same output as XM-L2 U2 (912/910 lm). At 1A XM-L2 is 7% better.
Skilhunt uses U4 bin and you used D220 which is a little lower.
This would make me expect ~18% lower output at peak and ~23% lower at 1A. I’m not sure what’s the current at the steady state but it must be quite close to 1A.
At peak I see ~22% lower output which is can be accounted for by test variation.
But at the steady state the difference is ~43% and that’s definitely too high.
Any explanation?
But at the steady state the difference is ~43% and that’s definitely too high.Any explanation?
IMO, TA measurement is too optimistic. Brightest E21A is D320 at R70 = 320lm at 700mA (Tj=25C). It’s comparable to XML2 U4, 320lm at 700mA (Tj=25C). Skilhunt use U4 bin for the CW version, mine is NW version. And I pretty sure it’s U2 bin. I measured H04RC using D220 E21A R9080 which means 220lm at 700mA (Tj=25C). Thus, 4x (4P) E21A D220 at 700mA produce only 245,4 lm - still much lower than a single XML2 U4.
I can’t explain the big difference in output either, my measurement device is not as sophisticated as Maukka’s. Let’s wait for his result.
[Clemence]
