Question: Why isn’t this LED no longer in production? Or is it? And why isn’t or wasn’t it used more often? The color is a dream, even more than the Yuji 3200K among 5mm LEDs.
I like this light very much, even if it’s not as bright as expected. Surely nowhere near 300 lm.
I wouldn’t expect a response for a while since it’s a holiday in China for several more days. Really only one sample has been measured which could just be a dud.
Coaster is right, my estimation might be wrong. I can only compare with lights that have a different beam and color, unfortunately. There’s not so much difference between 180 and 300 lm that everyone would see it immediately without direct comparison. And maybe I am influenced by the reported measurement.
Try changing modes. Lexel’s Bistro drivers i’ve got had to be programmed otherwise they deliver only 50%.
not reprogrammed but correct group should be chosen from options menu
I noticed the trit is glued, but not covered by the glue. Is it advisable to apply some extra UV curing glue to completely cover the vial? It seems quite fragile.
Edit: I did, and I’m happy I did Looks much better.
I just received mine and did a very rough test with freshly charged AAA batteries. Using the Android ceilingbouce app I get 8 lux/lumen for the Reylight and 9 for my Prometheus Beta QRv2.
Switch to a freshly charged Efest 10440 and I get 28 lux/lumen, although it does drop quite quickly. This seems promising in regard to the claimed performance figures.
