Interested
Thought I had replied but guess not. In for at least one. Thanks djozz et al.
HMM I might be in for 4.
at 500 lumens, what kinda run time on a 3500?
( I just found this 350 post thread)
If a high CRI led is used like the LH351D, I estimate about 1.5A to get 500 lumen, so runtime will be a bit over two hours on the highest setting.
Interested in 1
Maybe I’m misunderstanding the concept, but will this kind of be like a larger, High CRI version of a Jetbeam RRT-01? If so, I am very interested!
Good question, it depends on how Sofirn picks this up. If they decide for the infinitely variable ring (it requires a different fairly expensive, more than a dollar, magnetic sensor component, and designing the control for it what they have not done before), it is not far from a 18650 version of the RRT-01, albeit with a bit lower output. If they stick to distinct modes (which is electronically different, probably cheaper and already known to them), it may not look to you like the RRT-01. Mind that the distinct modes outcome is still very much within the scope of this project, for the project I would be happy with that (but I do hope a bit for the variable control because that attracts an extra category of buyers). I hope for a few answers after chinese newyear.
Please add me to the list as a possible buyer.
I am interested in 4.
Interested for 2
I'm already in for one, that remains unchanged.
Just wanted to say; the heck with the kids & Grandma!
Mine! Mine!! Mine!!!
That is all.
Carry on.
slmjim
Put me in for 2
I’m interested in 3, please!
We are at 250 units on BLF, plus 153 on TLF, that makes 403 total.
That should get us at least into the design phase I think, and once a design can be shown (assuming it is good) that will boost interest again.
I hope that China will soon recover from the Corona virus shutdown so that the design phase can get going
Sign me up for 2. Thanks!
That’s incorrect.
251
Count me in for 1
I’m interested in one at least
Personal want from wishlist
Magnetic ring, color not black, magnetic base, holster
Thanks
O S
I’ll take two pieces.
Hi,
Can you please clarify:
- TIR optics?
- does it have pocket clip and a lanyard?
- OK to have a small indicator LED flashing/solid red when voltage is low (instead of simply dim)? This, of course, in addition to the shut off function when voltage is too low.
Also, can you please explain what is a magnetic control ring ?
It might be easier to understand if you look up reviews of a light such as the Jetbeam RRT-01.
But basically there is a portion of the flashlight body that you turn to access the different modes. In some designs, it can be infinitely variable so you turn the ring like a faucet and it will slowly brighten or dim depending on the direction. In other designs, the ring clicks into indents as you spin it and it has specific lumen levels like low, medium, and high. This is more like turning the knob on a pedestal fan.
