In your tests UT383 did way better than other cheap meters. If UT383S performs as well, it’s probably significantly better in the cool region HS1010A that TA uses.
If you look into the table I made of how the different meters measured a number of different flashlights, you will see that while it performs better than some others, the U383 depending on light source, measured from 5% too low to 15% too low so a 10% variation on top of the calibration error, which does not make it a great luxmeter, just better than the worst ones. That is quite a range of error to consider. There seems to be a performance in between, the one Extech meter that I tested differed only a few percent from the reference luxmeter, which also shows in the wavelength response.
Unfortunately no, this is not for you. This H04RC steps down in 2 minutes to ~50% max output. Less than 400lm continuous with R9080. You better look for bigger light, not a headlamp.
But TA calibrates with reference lights which should cancel this error.
And I think $370 for Extech is way too high for an average enthusiast. At least I keep it out of my scope.
I think we need to keep in mind that this would not be just an standard 90 CRI headlamp. The LED’s provided for this Group Buy are 9080 LED’s, with a very high R9 colour rendering.
From my experience, your pupils will dilate to adjust to the light provided by a headlamp/flashlight. A small compromise in brightness can easily be adjusted for with your eyes and brain, but not so for colours. Having the super high 9080 LED’s bring out colours that you would otherwise not see as well with a lower CRI option, regardless of intensity or lumen output.
True! I use 4 different calibrated lights from Maukka: 6600K R7O, 5000K R9050, 6500K R9585, and 2700 R9580. They all have different calibration values. I use value closer to the light tested
I understand the spectral errors but misunderstood your previous post.
UT383 is the only cheap meter that you tested which doesn’t significantly overread the blue peak of cool low-CRI lights.
It loses at the far red. And the sensitivity peak is shifted. I don’t claim it’s great but to me it looks significantly better than anything up to several times its price.
As an owner of so many Virence modded Tiara Pros with the same emitter, even the 200+ lumen mode is VERY bright. It’s much brighter than I imagine at that lumen level and I’m a fan of lumen monsters. You can see everything very clearly. Probably the ultra HI cri helps. Most of the time I use the sub 10 lumen modes as that is already real bright at night when my eyes are adjusted and even at that lumen level you can make out all the details and colors. For anyone who is hesitating to buy this because of the low lumen rating, trust me you will not be disappointed and you will be using it everyday, likely on the very low levels.
I’m interested in this group buy, just checking that the buy occurs after 200 orders? Only asking because there are currently 100 rows in the google doc.
If we can hit 200pcs then we can request Skilhunt to make us custom mode/output (no timed step down). Otherwise, we will order any quantity but, with normal mode/output like OEM.
