Welcome to club, YossiD.
Of course as soon as word gets out that the Btone batteries are good, the next thing will be . . . fake Btones!
Look again - the eBay ad is for 8 Camelion batteries, so the price for four comes out to less than $14, which is over $4 less than the Eneloop XX I bought.
I suppose I won't know if the Eneloop XX I bought are genuine until I've used them for a while. They do have the date code impression stamped on each battery, which is supposed to be a good sign. Impression stamping is more trouble than printing so I am hopeful.
OK, however I have paid less than 10$ for 4x Btone 2100 and 11.99$ for 4x Btone 2500. So there is a significant difference in price, and you must to buy the pack of 8.... what happens if you only need 2 or 4?
However, thanks for the heads up. I am searching not very expensive ones to test. Still nothing found except for the Turnigy
Thanks to God (at least for me) I already own 18 Btone batteries (6 AA and 8 AAA). And no need to buy more Btones, but more other brands specially in the 2200-2500 range.
Before anyone jumps on the Camelion bandwagon:
http://www.candlepowerforums.com/vb/showthread.php?239520
Some pictures. Looks like batteries exploded in a camera and the charger:
There is no way Im going to pay 10$ for 4xAA/AAA Chinese LSD batteries, Id rather spend 15$(or less if I can manage to avoid VAT 22%) on locally available genuine 2000mAh Eneloops.
Make them 6-7$ for 4xAA and 4$ for 4xAAA and Im in tho :)
HC Turnigy's seems like a good deal, but their shipping is too high for me to consider them in quantities I require, its the same as those "cheap-expensive" Chinese LSD's, makes locally available Eneloops so much better option.
Even if some "Chinese" batteries (Btone and Turnigy LSD) are actually better or at least equal (bigger capacity, about the same self discharge) to 2000mAh Eneloops?
The BTones are available at about 9,xx$ 2100mAh version and at about 11,xx$ the 2500mAh version
Yes, UDO, even then. I cant justify spending 70-100% of the price of Eneloops on Chinese equivalents knowing how easy it is to get a lemon or fake ones and the hassle it takes to either get your money back or wait for re-shipped items.
Its risky business+when I buy locally I know there will be some kind of warranty and I will be able to contact either seller or manufacturer and try to adress the concerns, thats not possible with any of those Chinese copies when they offer month or two of warranty I believe?
Cheap lights=no problems, but not batteries at the price of branded ones.
As I mentioned - make them cost 4-7$ shipped for 4 pack and Im all in :)
TX for the info brted. I am not very likely to buy Camelion...
I think in places where Eneloops are priced astronomically, the Btones sound like a good alternative. But I can find 4-packs of Duraloops for around $8 when I find a good sale. And that's why I have more Duraloops than I really need.
Where I live I can not get eneloops for less than 30$... (a pack of 4x eneloop 2nd gen 2000mAh is in this moment about 25euro where I live... too sad)
That´s why I have to purchase all kind of batteries via Internet, and, also, there is a significant difference in price when purchasing eneloops vs others: the cheapest price for 4x 2000mAh eneloops is about 14$ (manafont), where 4x BTone 2100, which performs about equal, cost 4-5 dollar less...
Also there is a big risk of receiving fake eneloops when purchasing at ebay from chinese sellers. That´s why I prefer brands like BTone, Pisen, Turnigy..... they are know to be OK. Cost less than eneloops, and perform quite good.
Added results for the Pisen AA 2000
6) Pisen AA 2000mAh
Link - http://www.dealextreme.com/p/pisen-hr15-51-1-2v-2000mah-ni-mh-rechargeable-aa-batteries-2-pack-18317?r=43033281
FYI, no load voltages were:1, 2, 3, 4, 5 and 6 months (1.321v, 1.314v, 1.306v, 1.303v, 1.297v, 1.295v)
Measured capacity - 1853mAh
Remaining after six months - 1577mAh
So it has about 85% of it´s capacity still available after 6 months.
Also, I have emailed Camelion several times with questions about flashlights and batteries, but I have never received a reply.
Not a good sign.
If I may request, can someone test the Harbor Freight LSD AAA/AA's that they sell. I am getting good results based on the usage I put them through, but do not have a way to test their performance in a more scientific manner.
harbor freight = conus only?
There's a short thread about the Harbor Freight batteries here:
Thanks. I don't go over to CPF. I believe the HF batteries are a pretty good value when on sale.
IMPORTANT UPDATE
Dont buy the PISEN AA batteries (unless you are going to use them on low load applications).
I dont know if my 2 units are bad or what happens exactly.
All my tests on all batteries where done at 500mA, both charging and discharging.
Today, I charged these batteries at 500mA (as in the tests) and then made a discharge test, this time at 1.0Amps instead of the 500mA of the tests (to test them at 1.0Amps to see how they perform)
Results were more than dissapointing.... I have no words.
Measured capacity: 2mAh on one battery and 5mAh with the other battery.
I mean, when you put a load of 500mA to them, they perform very good. They hold the voltage and the voltage decreases over the time very slowly (is normal, as the other batteries I have tested)
But, when you put a load of 1000mA to them, the voltage drops from 1,4volts to below 0,8volts in less than 10 seconds!!!!!
This behaviour is not present in any other of the batteries I have. So the PISEN AA that I have seems to be designed for low load applications (or they are defective...)
I am not a battery specialist, but.... seems that they have a high internal resistance.
And the problem is not the charger, because I took a BTone 2100 and discharged at 1.0Amps and the behaviour was normal (the voltage didn´t dropped so fast).
OK, only that. You are warned. Removed temporarily from the "good batteries list".... until more tests are done
