HI Rey,
Do you shipped in the Philippines.... does the USD 5 shipping cost still in effect?
Thank you
HI Rey,
Thank you
That made complete sense and worked flawlessly. Thank you for your help!
Mine arrived earlier this week…….really happy with the build quality and the colour rendition.
I thought about this… Need some norlan now… Might as well get some trits too… Dammit $50…
Mine appears to have been sitting in Shenzhen with the airline carrier since the 15th (ordered on the 9th). Does the CNY affects air travel too? Maybe I just missed the window…
I heard that the "slow boat from China" is a myth and that the vast majority of stuff coming from China comes via air.
I believe that's true, and that CNY affects air travel.
the whole country is shut down more or less during their holidays, its crazy but thats how it works there dont expect any movement until early next month.
Mine got here relatively quickly (upstate NY) , about two weeks. Great looking light but it’s malfunctioning. Won’t come on unless I unscrew the head a few turns, then works for a bit then goes out again. Emailed Rey but like many in his country it’s vacation time. Anyone else experience this or any ideas on a fix?
Wait for a week for celebration end. Rey will be available only then.
Can you take a picture of the driver PCB? Maybe the ICs are not seated properly on the PCB, or the whole PCB came loose.
Something similar with the unit I received. No LED but the copper heats up with enough clicks.
After about two minutes on 10% mode the light turned off, leaving me in the dark. I tried an AAA but it won’t came on. Re-inserted the LiIon and it was alive again. Cannot reproduce it. It didn’t get hot, there were no mechanical impacts. I can slighty unscrew the head and retighten it, shaking the light, whatever, it works continuously.
I will take it apart if there’s time. For now, it is suspended from its EDC duties.
Shortcut between driver output and copper caused e.g. by solder could explain it.
I don’t have any li-ion in this size, only AAA Eneloop and AAA alkaline. They both exhibit the same behavior...by the way...shouldn’t there be an O-Ring between the lens and the reflector?
The oring between the lens and reflector is gitd so it may be hard to see in daylight.
I don’t have any li-ion in this size, only AAA Eneloop and AAA alkaline. They both exhibit the same behavior…by the way…shouldn’t there be an O-Ring between the lens and the reflector?
There’s a GITD-ring.
I took it apart...there is no o-ring anywhere in the head.
What causes the glowing?
There is no glowing...a GITD Ring was supplied in the box it came in but no ring is installed in the head. Could this be causing the odd behavior?
Could be. Mine had a gitd oring in the head already and one in the box. I would also check the the retaining ring is tightened sounds like yours was built at the end of the day.
