I placed a small smooth reflector on top of the bare led that made a decent hotspot on my ceiling. I measured the tint of the hotspot at 4 currents.
current
CCT
duv
CRI
0.1 A
5100 K
+0.0164
67
0.5 A
5140 K
+0.0152
67
2 A
5270 K
+0.0122
67
10 A
5620 K
+0.0061
67
The colour temperature is fairly neutral, at lower currents even significantly lower than Neal listed, and despite the high duv at lower currents I do not judge the tint as disturbingly green. The tint at 10 A looks quite perfect.
thank you. i sent an inquiry to lantend. i’d really like a couple of these to try out. my concern was the position of the tint bin which is depicted in the data sheet as well above the bbl.
Lantend charges you the shipping, DHL at $35. So unless you’re getting several of them the shipping makes the price point pretty high. And of course, China is shut down between Chinese New Year and the Corona Virus, it would be very surprising if you got any response before Feb 8th as the government has instructed businesses to stay closed until then. Getting a package out of China may take quite a while with all that’s going on over there…
I made other changes that pretty much make a before/after irrelevant, couldn’t know how much effect the window had as compared to the other changes.
For example, I filed off the corners of the base of the reflector to be sure the reflector didn’t short against the lead wires. I changed from 18ga Teflon coated lead wires to new 18ga Superworm leads. The missing frame and window allowed the reflector to seat further down and rest on the substrate, changing the whole scheme of things.
FWIW, it made 352Kcd before, now it makes 358Kcd. It was making 4240 lumens at start, now it shows a very brief 5180 before falling. This is in the 53mm reflector of the Crelant 7G5. It makes 4200 at 30 seconds now, cell down to 4.05V.
I removed the window from another 90.2 that’s in my SS/Cu X6, switched to an Eagle Eye X6 reflector (not threaded as this lights reflector was). When I built it the lumens at start was 5190 from 25.5A at the tail (Samsung 25S cell, Bistro driver) Lux was 106Kcd.
Now it makes 5630 lumens at start through an UCLp lens and 4880 lumens at step-down (almost 30 seconds) hot little mamma jama coming off the light box! About to get a lux reading, cell is recharging…
Edit: Now reads 116.5Kcd at start, 112.5Kcd at step-down. Serious heat being made, the big copper head on this X6 do get HOT!
It has always been that way, when removing the dome from a normal die the bond wires are exposed and easily broken. The difference here is that a normal LED has 2 bond wires, these have 24! I have crashed the bond wires on a $70 SBT-70 before and wanted to cry, it takes just one small slip.
So yes, once that thin window is gone and the surrounding plate is removed, the bond wires are out there in the open and easily damaged. djozz has a good idea in cutting the reflector to seat around the plate (the frame the window sits on), as it really helps to focus the beam profile in most reflectors. But again, it requires some care not to twist the glued assembly off and still arrive at the same result, damaged bond wires. But this level of care is always necessary, whether it’s your first mod or your thousandth….
So I did do the mod, a D80V2 was the host, and as Dale predicted, the reflector sitting around that frame got me the correct focus, it makes a very pretty beam now.
Anyone know if the ~10% bump is about right for de-windowing?
I did my first - modded a Luxstone X30 with a SBT90.2 de-windowed. almost sliced thru a bond wire or 2, but they appeared to be bent not broken. Wow! It's tricky. What happened to me was I used a surgical knife and seemed to be making progress, then it just gave way on a corner - should have supported the blade better - it was unexpected.
The X30 is supposedly 10 amps to the LED - had an original luminus LED in it, not sure what model. Was an easy mod, keeping the stock 2 mm thick rectangular MCPCB.
Lumens is about 3800 at start. The driver had a bank of 4 R025 1206 resistors in parallel just before the LED- wire. I added one R030 resistor, but probably didn't do all that much. Think'n of just jumping them out.
The X30 has a 2S3P battery pack using Samsung 2600 cells, so it's a buck driver. The LED wires are a nice 16 AWG. Was think'n of upgrading to 14 AWG, but not sure it will make a difference. The X30 is built like a tank, over built actually, here on Amazon, Robo819 review here. It was $600 originally!
My #'s before:
Hi: 2,632 @start, 2,560 @30 secs, throw: 152 kcd (780 meters) taken at 5 meters
Lo: 228 lumens
My #'s after:
Hi: 3,820 @start, 3,650 @30 secs, throw: 530 kcd (1456 meters) taken at 5 meters
Lo: 340 lumens
Not bad but could be much better at full power for a 94 mm head diameter light. It's a big reflector for sure.
Yep 10% or better seems about right. I de-lensed 2 of them… FT03 and a TM36 seen gains in both out put and throw… but was told I was full of it by a couple German Experts.
But then I never really gave a shit what the experts say or think, I do this for fun…
