Thank you very much Blackout for your input but I’m afraid you’re a bit mistaken. Emisar DVSV2 and all variants are long time on the list with the correct UI guide. The original Emisar D4S however has different (familiair) firmware called RampingIOS and logically has a different UI guide (actually one could choose both firmwares for the D1 Mini). All UI Sheat Sheets are strait from ToyKeeper website and always up-to date
—————————-end of quote————-
Hey Sam. I looked again and now see that the list is categorized by the firmware each light is running and not by the brand of light. When I originally looked at the list and saw all of the Emisars grouped together under the RampingIOS, I thought that was the entire list of Emisar lights and was asking you to add the D4SV2. Now I see that the D4SV2 is further down and appropriately located with the other lights running Anduril.
The amount of the information on this site is incredible. Thanks for taking the time to organize this list and to all the others who share their knowledge with us.
All Convoy flashlights on the main list are available with the new 17mm SST40 driver with Biscotti firmware.
(20 and 22mm drivers with Biscotti will be available after Chinese Spring Festival)
None yet that I know of… which is why there is an “Interest List” for such a light (Anduril AA/14500 flashlight).
(I believe the GT Micro’s NarsilM firmware might be flashable to Anduril. GT Micro uses 14500 only but not AA)
No idea what’s “new” in Anduril vs Narsim, but I’ve been getting a kick outta my ’micro lately. Aside from the rather limited-use pencil-beam, it’s a hoot to do momentary mode and other tricks.
I've tried to determine some Anduril firmware versions (or a guess) of a few Anduril flashlights that I've checked out:
Meote FM1 copper = has version check: 2019-09-28
FT03-Mini = has version-check: 2019-09-28
Sofirn SP36 BLF Anduril, Sofirn IF25A, Astrolux EC01, Astrolux EC03
= I think it has been determined by TK that they run the same old version of Anduril:
all of them do not have the 2-level brightness in lockout mode, nor manual memory mode. So firmware has to be earlier than 2019-05-22 (this firmware date added the 2-level lockout). The button blinking is a "breathing" pattern, which is added in Anduirl firmware date 2018-12-14. So the firmware used by these flashlights would be somewhere between 2018-12-14 and 2019-05-22.
Astrolux HL01 = has 'factory reset' function, but no 'version-check' function [between 2019-06-27 & 2019-09-24]
Astrolux FT03S = has 'factory reset' function, but no 'version-check' function [between 2019-06-27 & 2019-09-24]
('factory reset' added in firmware version 2019-06-27, 'version-check' added in 2019-09-24)
which would mean these 2 flashlights have Anduril firmware version dated between 2019-06-27 and 2019-09-24
Haikelite HK04
- Anduril version 2019-06-02 (has manual memory via 5H); but no factory-reset function
(firmware 2019-06-02 added 'manual memory' function; 'factory reset' added in 2019-06-27)
I tried to check some functions of Anduril (in the Anduril repository change log) to help determine which functions added in which date (for Anduril versions that didn't have the 'version-check' function yet)
2018-12-14: fancy aux-LED (button switch LED) blinking mode (like heartbeat breathing effect) on BLF Q8/SP36
2019-05-22: 2-level lockout brightness (4-clicks); momentary strobe mode possible (go to strobe modes before going to momentary mode)
2019-06-02: manual memory option (5H) ; button-release time-out is a bit faster
2019-06-27: factory reset function (hold button while tightening the tailcap)
2019-09-24: version-check function (15C) ; safety ramp-down if button held too long
