Interested
Interested
Interested
I hope this project doesn’t die out.
Interested!
Interested but would like to see the side switch ditched in favor of a tail clicky.
Unfortunately that rules out Anduril unless it’s a special (read: “complex”) tailcap set up like the FW3A family. Anduril requires an e-switch.
You’re killing my dreams here lol.
Interested. I don’t care what battery as long as it has Andúril.
This project has had persistent interest with not a lot of updates for months. AA/14500 may not be the height of flashaholic fashion (flashion?) but it seems a durable and timeless choice for every day needs.
i just received these, ordered them in anticipation of this flashlight, don’t let me down Sofirn
Where did you get them with shipping to Belgium? I’m trying to find who ships them to Bulgaria, no success so far.
Thanks, doesn’t work for me
So are these the same as the black Shockli 14500 1000mah cells that previously said 3A max on them? The listing you linked still says 3A, and the ones I ordered from Amazon say 3A, but the cell testing shows they obviously perform above 3A… I’m assuming they just changed the wrap? Maybe Simon from Shockli can comment… interesting.
You have to understand what the amp readings mean. Normally when a battery is rated with a number it will either be max continuous or max pulse. Max continuous means it’s put on a special machine that applies a 3A load and constantly maintains the same 3A from 4.2v all the way down to 2.8v and the temperature of the cell never exceeds it’s safe max temperature (typically 60°C-70°C. Each model cell has it’s factory specs).
What this means is that the cell can pull more than 3A, just for a shorter amount of time or if the temperature is monitored.
Looking at the Shockli picture it says Max: 5A
It does not give any real details if that is max continuous or max pulse.
I see HKJ has tested the version that says 3A max and found it to handle 5A max continuous. I’m guessing Shockli changed the wrapper to 5A since the 3A rating was too conservative.
I’m sure the actual manufacturer of the batteries stated 3A when they were selling in bulk to Shockli, then they saw the review by HKJ and decided to update the wrap
Still no idea who the manufacturer is, and why are they selling these nice cells to only 1 company.
Interested.
I got them from the Shockli aliexpress store
2 weeks to Belgium
Does it come with the clear plastic case?
Yes it does,the batteries are wrapped in plastic wrap, and put in a plastic box. same as my shockli 26650
Interested for sure
