Thank you guys for your feedback, I’m happy to hear that it works well for you.
Now enjoy your lights in the way they was originally thought/designed.
Oh and I forgot to mention something. The copper plate fitts perfectly on the aluminium ones, but the copper and brass seem to have slightly different tolerances or dimensions. The brass one was abit “snug” but I managed to press it in with my fingers, but the copper one was harder. I resorted to using plastic rod and a small screwdriver head as a hammer to gently tap it in. It didnt take long and wasnt destructive, but I couldnt just press it in with fingers. So if you have the copper/brass ones you might have to use some gentle tap tap.
Oh, sorry I was not aware of this fact, that the aluminum, brass and copper versions have different inner dimensions.
Maybe it is only the coating of the brass and copper one, that slightly increases the surface volume.
My copper version is on the way, as soon as I get it, I will analyze this fitting issue.
Maybe it is just the surface coating, it was not really an issue. Nothing a person who resorts to modding couldnt do. It didnt require any ajustements or any changes to components, just some force. It works great on brass and copper as well, no other issue.
INTERESTED in 2.
Thanks man of light!
I’m interested in one.
I’d like a few
Interested in 4
Hi guys, a short update of the shipping status of the 2nd batch.
Yesterday I shipped the first half of the 2nd batch, just not yet sent the information via PM, cause of time troubles. I go in the order of payment.
Today I already prepared the shipping labels for the rest of the 2nd batch and will bring the to post tomorrow or monday.
I will also update the list in post #2 with the names of all interested.
I did not measure but I put mine on and it lasts at highest ramp for over a minute. Probably longer but that is good. I did not convert F to C in the beginning so I thought it was no better but once I set room temp and thermal limit correctly it is now as expected and I really like this light even more. Thanks man of light!
P.S. I used MX4 on sides of plate and everywhere as shown By man of light, and I have a copper head with Aluminum body. I did not have any tolerance issue getting my plate to slide into the copper head. I was generous with extra MX4 on the sides and so MX4 gets on the head’s inner threads a little as you slide it in but that’s ok I just leave it there. this way I have a good thermal path to the the head. I read the MX4 works even better after several cycles on/off. Lining up the screws is really the hardest part and would be same for all minis. Put your screws into the plate first and it’s easier to line up.
Thanks for your feedback ghost face
@All interested, I’ve just updated the OP (post #1) and post #2 with fresh information on the status of the 2nd and 3rd batch, please take a look.
Hi MOL
Do you also consider to produce another heatsink copper for the FFE07? it is also getting hot....
Please explain in detail. It’s 7135 chips are heating the MCU prematurely?
Payment and details sent
Shame the flash light didn’t come like this!
Pleased you have offered them as the light was a bit of a let down though luckily it was bought at a _reasonable _discount.
Payment and PM with details sent.
Thank You very much!
Can i get in for 2?
Thought you were only doing one batch? I finally installed mine. Works perfectly. After the drop down it sheds the heat rather quickly for another run at turbo
Very interested!
Hi there, I’m interested in one. Thx.
Yes, that’s what I thought. Since I have never organized something like this, I didn’t know what the effort is. When I realized how much work it was, I thought only the one batch, not more.
But after the first batch was delivered and I was asked whether I would do more, the effort seemed manageable and I decided to continue for the community.
