It’s a great light, my Grandad is currently using it and he loves it, he’s got a lot of lights to choose from too!
I am not a flashlight expert, actually I am far from it, I just got into this hobby, but I was also thinking that this light is really easy and safe to use by older persons. It comes up on Turbo everytime you press the button (so a lot of light), it came with a battery (I think it is a protected one) and it has a USB-C charging port. And it is bright! I like a lot that it is a combination between throw and flood. This is my brightest flashlight for now, and I got to test it on the countryside (my mother in law lives next to a forest) and this is bright!
Your review made me buy this light right away after I watched it, you have great reviews!
But why plastic instead of glass ?
I ordered one from Banggood, and got lucky to get one of the last three they had available from their USA warehouse. So, it should be arriving by Saturday. That would be this coming Saturday, not the third Saturday in March, LOL.
Anyways. I am excited to be getting my first NexTool torch.
The NexTool is a very well made torch. It feels very solid and smooth, and is rather classy looking.
But, I don’t like that it always comes on in the brightest light level every time it is turned on. No memory. And, I think the O.E. NexTool labled 26650 5000 mAh battery is defective, because the run times are not good. I am guessing it is the cell, because I have not heard any complaints online about run times on this light.
I really like it overall. It will give it to my elderly dad, so he can spot coyotes in the canyon behind his house. He won’t use it a lot, so the battery run times shouldn’t be a problem. It is a very simple, straight forward torch to use, perfect for him.
It’s Charles BridgeTec. He likes everything…
Thanks everybody!
What would be the best battery available from:
https://www.nkon.nl/rechargeable/li-ion/26650.html
Thanks in advance for the input
I measured mine over 500m throw and 3300lm at start
it has a timed stepdown, it starts with 1:30 min over 3100lm, then starts to throttle down to 1000lm but it takes like 6 min to get to 1000lm. (At 4 min is over 2000lm)
Mode spacing: 33lm/254lm/768lm/3300lm
It has USB C charging and includes a great quality 26650 cell (I have good blue liitokala and the performance and runtimes are the same
the Only drawback is that the lens is plastic instead of glass
The UI is very simple and I really like the switch, it’s like a mix between mechanic and electronic switch
From OFF:
-Half press= momentary on (turbo)
-Full press= constant on (turbo)
From ON:
-Half press = change mode
-Long half press= SOS
I think it’s a great muggle light!
Beware that Charles BridgeTec’s review points out that the battery is protected and IT’S NOT.
I bought the light because I thought that I could use 21700 cells (same length as a protected 26650) but this light cannot accomodate cells longer than 65mm
Just got mine from Drop yesterday. Totally impressed with it so far.
This one is definitely going in the car’s centre-console compartment.
How does this compare to the C8+?
Compared to which C8+ ? (there are various LED options for Convoy C8+, and also other C8 from Astrolux & Sofirn)
Nextool XHP50.2 beamshot
Astrolux C8 (XHP50.2) beamshot
Convoy C8+ (SST40) “ramp driver” variant
Astrolux C8 (XPL-Hi) beamshot
Wainlight C8+ (Osram NM1) beamshot
Amutorch XT45 (SBT90.2) beamshot (not “C8” but head-size is similar to “C8” flashlights)
Hi there,
I need to ask you a question.
Just recently, I received a brand new Nextool 2000 lumens flashlight but when I put my own 26650 battery (Xtar 5200mAh, 3.6V, I think it’s protected cell), screw back in the tailcap, but it would not turn on.
Here’s the twist, just as I was unscrewing the tailcap to remove the battery, towards the end of the thread, the thing would light up.
I wonder why… Have you tried other brands of protected and unprotected 26650 cells?
What do you think? Or the spring at tail cap is the culprit? I hope to hear more from you soon.
Thanks!
Hi there,
Thanks!
I can’t be sure why, but my guess is that the longer protected 26650 may be preventing the tailcap from touching the body tube (the tailcap portion needs to connect with the body tube to connect power to the flashlight.
Have you checked if the tailcap is fully screwing in properly when using the longer protected 26650, compared to using the included unprotected 26650 battery?
Hi everyone,
Does anyone here know what’s the measurements for the rubber O-ring used by this NexTool 2000 lumens flashlight? It seems that NexTool doesn’t sell replacement O-ring for this flashlight, which is very strange as these things can wear out quickly.
Many Thanks!
Hi everyone,
Many Thanks!
I measure around 31mm for the screw thread (tailcap portion), so I suppose the o-ring size should be 30mm or 31mm in diameter?
Ok, thanks for the information. I can try 31mm since rubber is stretchable.
Hi guys, i have a few question,
i just bought 26650 trustfire protected battery, it hasn’t arrive yet,
26650 trustfire protected battery is 67MM in length , will it fit in this flashlight ?
Thanks a lot.
It could be because of the price. I recently bought this great torch from Aliexpress for approximately £21. I personally don’t think that for the price it can really be bettered.
