Product Page and Info here:
Well I feel silly now. According to Rey’s site a button top shouldn’t even work yet here we are using them!
Edited my post from before.
Patina is starting to develop on mine and I love it.
And the tail switch feels good too.
Hmmm...I took the info on the website to mean that some button top 10440 are too long as illustrated in the photos. Regular alkaline, Eneloops and Energizer lithium’s are all button tops ( at least the ones I have) but not in the extreme as illustrated. I don’t think he meant to exclude the use of all button top batteries...at least I hope not!
PM coming.
There are some troubleshooting or fix.
1. tighten or loose the pill a little bit. there might be some bad contact or short somewhere.
2. unscrew the head a little.
3. remove the tailcap and try again.
The switch is press-fit into a copper thing, the switch body is usually at a lower surface. picture below.
Received mine today, beautiful light!
Mine also won’t turn on with any NiMH battery I have, just the 10440 that came with it. Tried tightening/loosening the pill and that didn’t work. It won’t come on with the head loosened a bit either, like it is for some other users.
That’s strange, I will dig it out.
Ordered one
I played around with loosening and tightening the pill some more, and found a spot where it seems to be working fine with NiMH cells now. I got it by loosening the pill a lot, tightening down snug (not tight)and then backing off just a hair.
Can anyone confirm that the LVP works for the 10440? I just found mine at 2.1V and I can’t be certain if I didn’t accidentally click it on and run it down. But even if I did, I would’ve expected it to stop around 2.8V or so.
And i also got mine at last.
sadly NiMh is not this light favorite... :(
Looks like voltage is too low for the driver. Alkalines work great and Liion but NiMh is a no go.
sadly NiMh is not this light favorite…
That’s odd, NiMh is what I use without any issue
I did manage to get it lit on NiMh but only up to 2nd or 3rd mode then it just went OFF.
First batch of drivers... Rey will fix it with second one.
Oh yeah i forgot to mention i’ve placed Lumintop IYP365 with 219B and 2xEneloopAAA next to Pineapple Mini with Efest 10440 and guess what, it’s not nearly brighter than on Alkiline.
So yeah, max is not nearly bright as it should be on 10440
Sorry for late reply. The Coronavirus is delaying everything. I have asked the factory to retest the output. Then I have realized there was a mistake, the sample was 219C LED, which had 300 lumens.
Will post the pics for 219B soon.
Yeap, that’s more like it. This emitter is pushed hard if it’s 300+lm.
What about NiMh issues?
Going to post about this. Some of the NiMH battery has high inner resistence, the low voltage might not active the MOS and not work prefectly.
We might need a lower threshold for future.
We also need updated present batch of mini’s.
