[Review] 77 Outdoors D25 Headlamp (18650)
257 posts / 0 new
R0tten
Sorry to ask this question again…. but I plan on getting one. Has anyone officially determined if these XM-L2 LED’s are not a real cree? I played with a wowtac a2s then a sofirn sp40 and I was thinking of getting one of those for myself. I then ran into the D25 and thought it would be within 1-2% difference between them, since they all have XM-L2’s. I would actually expect the D25 is better because it has 2 XM-L2’s? I’m not sure I understand.
Agro
Agro's picture
Last seen: 2 min 23 sec ago
1. I don’t know if the LED is genuine, considering low price I suspect it’s not.
2. Regardless if that’s the case, performance is not within 1-2%. Let’s assume for a while that the LED is genuine XM-L2…
  • For the same CCT and CRI, the difference between top bin and bottom bin is ~25%
  • Within bin there’s about 7% difference
  • Any CCT differences add variability
  • Driver and optics are not the same, driver has huge effect on performance while optics has quite minor but still way more than 2%
  • D25 has unregulated driver while the other 2 are regulated. This means that D25 output drops as battery deplates which is not the case with the other 2. It may be better at full cell but worse at near-empty
EDIT:
Scratched info that the 2 lights that you’ve seen have regulated drivers as I’ve got notice from RD that this is incorrect w.r.t Sofirn SP40
JasonWW
JasonWW's picture
Last seen: 7 hours 48 min ago
I see people assume this a lot. Cree lists +-7% which is a potential 14% difference within a single bin. I guess they try to stay within 7%, but allow 3.5% extra on each end just to cover themselves.
The bottom line is it’s probably about 7% like you said. Just thought I’d mention it.
Agro
Agro's picture
I was talking about different 7% and missed this one. Wink
You’re talking about “Cree maintains a tolerance of ±7% on flux and power measurements”.
I was talking about bin width, f.e. T5 is 260-280 lm (7.7% width) and U3 is 320-340 lm (6.3% width).
So…there’s even more variability than I listed above.
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 3 months 1 day ago
They has XP-Footprint and I think they are no genuine Cree LEDs.
They looks similar to XP-L LEDs.
alpg88
Last seen: 2 weeks 3 days ago
i’m pretty sure those are LB leds, not cree
RD
Last seen: 1 month 6 days ago
The Sofirn SP40 driver is also unregulated. Brightness decreases as the battery runs out.
Sorry for my bad English.
gchart
gchart's picture
Last seen: 19 hours 42 min ago
Strange. It must vary from source to source. Mine had the 5050 (XM-L2) footprint:
Agro
Agro's picture
Thanks for the correction.
gchart
gchart's picture
Yes, that is correct… the SP40 is unregulated
pc_light
pc_light's picture
Last seen: 18 hours 1 min ago
I got my first D25 from 77Outdoor on Amazon and they clearly stated in their ad at that time the emitter was Cree-like and confirmed in an email that they were not Cree. Since that time their D25 model has been updated to SST-40 (similar to the Sofirn D25S offering.)
However the D10/D25/D20 based headlamps are apparently offered by many different vendor house brands and the emitters used by each may vary.
There seems to be more consistency with the Sofirn and/or Wowtac headlamps but that’s my assumption.
Seeking the light.
Wieselflinkpro
You are right, I checkt my lights.
The older one, with the driver-pics in this thread has XP-LEDs. This is from Xanes, ordered from Banggood.
The newer from Aliexpress has XM-L2 – Style LEDs, with “LMP” written on the LED.
R0tten
EDIT:
Yeah, thanks for the info. It really seams that (I guess even for a fake XM-L2?) this D25 headlamp keeps up with the sofirn pretty decent for the first 2 hours (judging by the run time/output graphs)? Am I right? Does having 2 of the LED’s over just the version with 1 actually make it brighter? I was thinking about getting the single LED with the zoom feature, but I want more brightness over zoom.
Never heard of LB.
Really great information from everyone.
I assume that these are still pretty great to have for the price and come close to wow and sofirn, so I have 3 choices; Sanyi D10, Boruit D10? & Sanyi D25
What do you guys thinK Question
JasonWW
JasonWW's picture
The only advantages of using 2 leds, with a limited amperage driver, is slightly better efficiency and slightly higher output. Let’s say the driver has a 3A limit. A single xml2 running at 3A is let’s say 1000 lumen. The same led running at 1.5A is 600 lumen, not 500. LEDs are more efficient at lower power levels.
So if you have only 3A total, a twin xml2 light can output 1200 lumen (2 leds running at 1.5A each) instead of 1000 lumen. Higher total output and better efficiency.
So 2 leds are better, but there are downsides as well. The special oval shaped mcpcb makes it hard to swap a new led in. If you reuse the oval shape mcpcb you are forced to reflow new leds on it which is harder to do and your limited to 5mm leds.
In my opinion, I’d rather have the D10 with its single led. It’s far easier to swap in a new led and round mcpcb just by soldering 2 wires. I can use whatever 3v led I want. (I chose a very nice tint with good color rendering) It’s also easier to swap in a plastic optic to replace the reflector. I really don’t mind the small loss of efficiency and brightness as I rarely run the battery fully down or use max brightness.
So it’s up to you to decide what’s more important as to which model is best for your needs.
alpg88
Funtastic
Funtastic's picture
Last seen: 11 hours 48 min ago
For anyone interested just get the Sofirn D25S which they have installed SST-40’s and updated the firmware.
On/Off – Single click
Hold – Stepped levels – Release and hold within 2 sec changes direction
Double click – Strobe, Beacon
Texas Ace Lumen Tube calibrated with maukka lights
New Zealand store – https://www.piercingthedarkness.co.nz (NZ customers only)
YouTube channel – https://www.youtube.com/channel/UCIUWi2vYp4CWrRkOJM70t_w/videos (Demos for my customers, and reviews)
alpg88
does it focus correctly with sst40?
Funtastic
Funtastic's picture
I got 5pcs and all of them look great, all centered perfectly. Doesn’t look anything different than any other light using a SST40 and smooth reflector. Nothing that annoys me.
Solid deal for this price point
alpg88
both of mine have very poor beam profile, due to leds not focusing correctly, mine have l2 leds
JasonWW
JasonWW's picture
Have you tried raising or lowering the reflector heights to improve focus?
alpg88
nope, i was planning on replacing leds, and reflectors, got them from kai, deeper reflectors, leds, and spacers, but did not get to it yet.
mine came with xml2 clones, maybe with actual xml2 leds, or other leds, focus would be correct, idk, but in my case, out of the box it is pretty lousy, as far as beam profile, it does illuminate, and vast majority of people would not even notice it, but we are “special” here, lol
alpg88
fixed the issue of a donut hole, i replaced leds with xpg3 on 16mm mcpcb,, and centering gasket, got leds and gasket from kaidomain, reflectors left stock, due to ticker mcpcb had to put a gasket under lens holder\cover, about 1mm, i used silicone rubber from iphone holster. now beam is much better no holes, and it seem narrower. i also got rid of cold\blue oem leds, xpg3 are 4000-4500k, according to kaidomain, (i guess that means a tint lotto) i like the light much better now,
scitzz
Last seen: 1 year 4 months ago
I just bought one, seems decent. I am a mechanic so I thought it would be useful while under a car, but I am concerned that I could break the holder on the band, anyone know where to get replacements for those?
JasonWW
JasonWW's picture
You can’t get replacement holders. You can either buy the rubber universal types or print yourself a new one. People have the data and will share.
scitzz
VERY cool! I did not know there were universal rubber ones! Any chance you have a link handy? I like to be prepared ahead of time.
Also, I took mine out in the dark tonight and was pleasantly surprised. I have a Thrunite TN12 as part of my EDC. Although a different tint, they were very comparable. I did note the cheap feel of the threading on the battery cap, and hope I can get away with charging more often than replacing the battery in it. Overall extremely happy with the purchase.
JasonWW
JasonWW's picture
There a lot of universal ones like this for $2.
#Aliexpress US $1.94 31%OFF | Headlamp Headband head Belt head Strap Mount Holder for 18650 Headlight Flashlight Lamp Torch
https://a.aliexpress.com/_dZ6SQuG
Some are higher in price and might be better quality. You can also get the ones with the extra strap over the top.
scitzz
I got one to have as a spare, thanks so much!
mitsuki08
Last seen: 34 min 46 sec ago
Does anyone with the D25S have issues when using click and hold to cycle high to low? Any click or click and hold just cycles from high to low and doesn’t want to cycle low to high unless turned off.
JasonWW
JasonWW's picture
I thought the D25S had the same UI as the D10. On the D10 it only cycles from high to low and never the other way around.
mitsuki08
I have the same UI as Funtastic. It’s not really a bother but it does have memory mode so it would be nice to go down when in the medium modes rather than cycle through high. I also can’t seem to go down in modes immediately after turning it on. Just seems like a weird behavior. Though at it’s price I can’t really complain much. I knew I should have gotten more than one Quadrupel driver Facepalm
