Yeah the pill-end of the spring probably could be soldered. Although that might not be necessary, if its firmly attached to the pill by its own force exertion. Its the other end that looks more more troublesome, with a larger gap to bridge over. The OP might be able to bend the spring to get it to contact both ends reliably. There are some more detailed pictures of another members light in this thread here...
What I have in bold is exactly what I told Tmart. Their customer service is top notch, but this is just a poorly designed light. I don't know how to work on lights, not only that, I didn't expect to get a light that would REQUIRE modification just to get it to work normally.
Again that said, I am going to send this light back, with instructions that if their tech support can fix the spring problem, send me the light back. Other than that, I don't want to go through a 3rd copy and the same thing happens again.
To be truthful, it would be hard for me to solder or some way make that spring stay stationary. BTW, even though I am a newbie, I got other lights, and none of this is happening. They work all the time on the bicycles or off. I understand in the course of getting a lot of lights, sometimes I wll get a dude. That's normal, but this is the second one. IMO, a poor design..
The feedback you get around here is super AWESOME..
Here is a picture I got from that other thread. The spring is wrapped around the pill. My spring looks much bigger, that is why it hangs loose. My spring tries to grip itself to the walls of the casing. Whereas, this one does it differently, and clings to the pill as shown in the picture!! ???
Can you bend the spring (ie. twist it into a tighter circle) so that it does grip against the pill tighter? Not a great design, but this fix might make it an acceptable light.
I think you just have to rack this up to the "Lottery" we all play with buying Chinese budget lights, unfortunately. I am ecstatic if I get a budget light that doesn't need any attention. I just come to expect they'll need something done (at least thermal compound added).
cehoward, in my opinion, you should not have to be able to solder to use a light (I certainly don't). Many on BLF do enjoy the fixemup lights, but I for one do not. You've tried this one twice, and I think we all agree it's poor design - spring should either be soldered or grip the pill very tight. I say see if they will credit towards another light, as this one is probably not going to work for your purposes.
Which allowed me to see the spring around the pill.
And tadpolPilot for suggesting to tight the spring around the pill.
Okay, me and my all thumbs, went took the light apart, the bottom of the spring, I squeezed it until it was a tight fit on the pill. Didn't do this before, the spring was hanging loose all the time.
Anway, with the spring tight around the pill, I put it all back together. The light came on, and then I held it in my hand and shook it hard! No mode changes. With the light in my hand, I bang it on my leg about 10 times. (hurt too), as to simulate rough riding on the bike, NO MODE CHANGES. Going to put it on bike tonight, and ride over the roughest ground I can find, if no mode changes, and no more on one day, and off the next, this light is a KEEPER..
Here are pics of the SUGGESTED FIX!!
Here I am picking up the pill by the spring and the pill is staying attached to the spring, this was never like this before..
As in this picture, the spring is not moving around,
Right now, you all should see the smile on this 72 year old kid!! Can't wait until nighttime to try this out. I am almost sure this is going to work.
One more thing, not trying to plug Tmart, but they have been SUPPORTIVE from day one on this. No return shipping, and at every instance, I get an apology, and and offer for a refund, with a return label. IMO, if the other companies were just 1/10 as good with their customer service, it would be super good in Flashlight World.
I am going to say BIG THANKS TO ALL, you guys/gals are GREAT/SUPER/AWESOME!!
That is exactly what I did. It looks like that was the fix too. (thanks to all on this forum) Going to ride tonight over bumpy ground, and I should not have no more mode changes or not working stints..
That has been my experience with Tmart also and why I was eager to work with them on a group buy for the SR King. Unfortunately they have been slow to react to my suggestions on what needs to be done to make anything happen with the King. I haven’t heard from them in a few days after trying to contact them about it. It’s a shame but I will continue to buy from them when the price is right and often it is. It’s worth the fast US shipping and great service.
Johnny, in all my dealings with Tmart, their regular reps are great, but I always cc the same message to Sherry Ye, who is on this board. She comes and backs up the already good customer service.
If you get the time, email Sherry your concerns, and see if that helps. In the meantime, I am happy as a lark over this light. Can't wait to go outside..
After two test rides on the bicycle, and the ride this morning, once in a while it will change modes on a bump. That is a long way from not working at all, and when working it would change modes on almost every bump. Now, if I can find out where it is contacting to change modes, I might be able to fix that.. I hope. But, I am keeping the light. The way it lighted up the way for me this morning in the dark, I want this..
Funny thing too, I used to be super expert at casting bullets (hot lead), but can't do jack with a little hot tin!!
However, I am moving foward on this. Now, I know what it making the light chang modes, will try to see if I can make the battery chamber a little tighter to stop the movement..
