Ha Martin! Used your code on a brass MF01 mini with 4000K SST20's and it came today, 13 days from ordering w/free shipping. It's outstanding!! I have an olive green MF01 mini w/5000K SST20's and these 4K's are way much better - milky white on the white wall while the 5K's match the body color, olive green ().
Popped in a Shockli 5500 26650, then in Anduril:
set the AUX LED to max
cal'ed the temp (it was ~10-12C high)
cranked up the temp regulation to the max of 70C (40 clicks)
set the ramp max to the turbo/max
and now it's all set . Batt voltage so far is dead-on as well.
These 4K SST20's in this light look great to me, as consistent as XPL-HI's and no noticeable tint shift in the spill or corona, and no signs of green.
Bras does ok. Think I heard about the copper shimes - is someone selling them? I don't like the 70C limit. I already modded Anduril to max at 85C - much better for a light like this, just need to find out how easy/hard it is to re-program. I already maxed out at 70C on this mini and can still hold the light in my hand fine, but it gets hot for sure but I've held hotter.
The shim only effects max ramp. The 7135 chips overheat the MCU causing it to thermally step down after 20 seconds or so. With the shim, this changes to several minutes like it should be.
No - much better when the firmware supports it. Again, compiled/built the latest released Anduril (464) on Atmel Studio 7 (latest), and tweaked the max allowed temp. Dnld'ed and tested a Anduril Q8 build on a Sofirn Q8 - works great!
Not sure bout the version # - now I can't find it in the repository - it's so confusing.... Think it's the latest "sandbox" version, not released.
Think at the time, the other day I pulled 464 dated 2019-12-18, and that's what I built and modified.
Sorry for off-topic. Markets have been expecting coronavirus to have little impact on global economy because everyone would come back to work only a week late. This looks like wishful thinking at this point.
Woah, the Nitecore CI7 has a rotatable head to switch between 4 regular led and 4 IR leds? That’s cool! I’ve never seen that before. Just pull the head out, rotate 1/8 turn and drop back down.
