Are you interested in trying out some of the Minus Green filters to kill that nasty green tint in your newest LED flashlight ?
Looking for a RED colored filter to preserve your night vision?
Want to take a 6500K light and turn it into a 3800K warm white tint ?
Interested in trying out Zircon filters exclusively made for high temperature led lights ?
#F1 - 1/8 Minus Green filter ... to reduce green tint.
#F2 - 1/4Minus Green filter .. " " " "
#F3 - 1/2Minus Green... " " " "
#F4 - LEE FILTERS 205 SHEET 1/2 C.T. ORANGE CONVERTS 6500K TO 3800K
#F5 - Colored filters- Red,
T1 - 3000k - 2600k
T2 - 3000k - 2700k
T3 - 4000k - 2900k
T4 - 4000k - 3000k
T5 - 5500k - 3000k
Zircon >Zircon sheets take high temperature better than regular Lee filters advertised as 200x tougher /definitely thicker
Z1- Zircon Minus Green -slightly less than a 1/8th minus green ( hard to find)
Z2 - Zircon 1/8th minus green
Z3 - Zircon 1/4 minus green
Z4 - Zircon 1/2 minus greenR4- Rosco 1/2 minus green in their Cinigel tough filter series
#F1 ~ #F5 - $3 sheet
#Z1 ~ #Z4 + #R4 + T1~ T5 - $4 sheet
Continental U.S. shipping - 50 cents
International -1.50
wwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww
wwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww
***EDIT Combining the two threads only makes sense . here's info on the diffusion film as well .
2 - 3 " x 6" sheets of "The Famous Dc-Fix" shipped to your door only $3.50
Add $1.50 for extra sheets
+$1.50 - international shipping
Dc-fix will take a really bad beam and turn it into soft buttery smooth delight with amazingly low light loss (3.2% ) I've found myself using more and more diffuser film to soften artifacts ,cancel out ugly rings and create a floody smooth beam . If you've wanted to try it ...
PM me with your address,...hit my paypal and I'll ship you some. Thanks !
#1- The original Dc-fix single sided adhesive . 3% loss...Selfbuilt on CPF measured it at only 3% loss..Great stuff ****
#2- ///Sold out/// (#2 and #3 are almost the same )about the same thickness as #1 little different pattern ..still more of a frosted ****
#5- :) FREE ...a non adhesive thin material that flattens out the beam so it can be positioned horizontally or vertically . my thoughts are use as a bike light to spread out the beam left and right and cutting off beam that needlessly blinds oncoming traffic.***FREE -> added to every sale !!
#6-///Sold out // non adhesive double sided pattern that is about twice as thick as Dc fix . flexible ****
#7- Non adhesive double sided very fine frosting similar to #2 but more flexible .works great 4 stars****
#8- Thickness is close to #4 no adhesive ,two sided (pattern on both sides) a little bit better than original number 4 ....****
#9- " " Same but different /two sided non adhesive " " " .... ****
#10- Same thickness but different pattern /two sided non adhesive " " " .... ****
#11- Same but different /two sided non adhesive " " " .... ****
#12- Close to same thickness but again a different pattern and different diffusion
#13- ////Sold out ////
