Yes, I am want 3000K too. Hope, Sorfin will done it.
Once the C01 is running, the LED just keeps converting electrons in photons with much lower voltages (down to an OCV of 0.2-0.3 Volt), although the output is just much less bright (“moonlight mode”). This means that once you turn off your C01 and the cell voltage has decreased below 0.8V or so, the C01 will not light up again. However, with alkaline cells if you let the cells rest, the voltage of the cells will slowly rise up again. With alkaline cells you can even see this happening when measuring with a DMM. So, wait and after a while you can then turn on your C01 again. No need to keep it on continuously. The same is also true for lithium primaries to some extend, although it takes much more time for the cells to rise up in voltage again.
I guess I should have searched for this before doing my own testing, but here it is. I put a 1.5 ish Volt alkileak cell in a C01 (neutral white output) yesterday. When I got home today, it was much dimmer. After taking the cell out, I measured 0.55V. A bit later I created a setup to measure the voltage and current out of the cell into my C01 with gravity, some props and a bit of tape. After running with this measurement setup for over an hour, the light seems to have stabilized (for now) by drawing about 6.5mA from the cell. The cell voltage is down around 0.3V. When my DVM measuring voltage shuts off the display, the light from the C01 flickers as the lead going to my DVM measuring current touches it, so it slightly disturbs the setup. After one such event the voltage of the cell is up to 0.39V and stable, with still 6.6mA of current. I’ll let it run overnight to see if its still running tomorrow. It been almost 2 hours since I started the test back up, with the cell at 1.0V or less the whole time. Certainly a vampire light if I’ve seen one.
Update 1:
good morning. 9h40m since I started this run, my 5000K C01 is still putting light out. 0.24V on the cell, 4.5mA being delivered, and the brightness is about the same, (slightly brighter) than moonlight on my Manker E01. I never imagined it would run all my sleeping hours on a cell down to 0.4V already.
Update 2:
Nighttime: 25h since the CO1 drained this cell below 0.6V, and started it on again. Still at 5mA level, I have seen the voltage as low as 0.24V, but typically its at 0.35V. Right now its at 0.4V and 5mA. How many more days like this? The light output is brighter than my Manker E01 on moonlight mode, maybe 3-4x lumens. Noticeably brighter.
Update 1:
good morning. 9h40m since I started this run, my 5000K C01 is still putting light out. 0.24V on the cell, 4.5mA being delivered, and the brightness is about the same, (slightly brighter) than moonlight on my Manker E01. I never imagined it would run all my sleeping hours on a cell down to 0.4V already.Update 2:
Amazing.
Thanks for reviving thread with this interesting data. I always run Eneloops/Duraloops in my lights, which is not recommended for this experiment. It could damage the battery.
But I need to find some dead low voltage alkalines laying around the house (that I am ready to throw away) and try this in one of my C01’s.
This is great to know during a power outage that I can use any old dead battery laying around and still have some useful light! Think of how many alkalines we throw away when they decline to about only 1.0 volts!
Vampire!
But first try to sort out the almost-dead batteries from the really-really-dead batteries.
Just in case your family has to survive whatever disaster that’s waiting for you in the pitch dark.
It just keeps going, it was still running this morning, 34 hours into this test, which started with a depleted battery. As I mentioned, my setup is a bit rickety, and this morning one of the leads moved a tad and the light went out. Eventually I realized this and tweaked it back into position. It came on and after a few seconds the battery was at 0.75V and delivering 14mA to the light, so presently it fairly bright. And the test keeps going . . .
I was hoping I would see where the light turned back on (if it would on its own). Maybe sometime later during the test.
48 hour update. After the bumbling in my last post, I decided to just put the battery in the light and let it run. It seems like the cell continued to deliver about 5mA at whatever voltage it is. The pic above shows my Thrunite Ti-3 on the left, Sofirn C01 in the middle, and Manker E01 on the right. 48 hours after the battery was spent, the C01 is still brighter than my Manker E01, but not as bright as my Ti-3.
Thanks for posting this. We are on the edge of our seats……
I know people will laugh at this low level of light, but it is actually plenty to navigate around a dark house without falling or bumping a toe, and has the even more important advantage of not waking a sleeping spouse or baby.
R.I.P. It was still lit when I went to bed, 74 hours, albeit close to the output of the manner e01. Just to clarify, the LED is producting light still, but you can barely see the illumination looking at the LED in a dark room. Its no longer useful. But it would be interesting to see what level of current (and voltage from the cell). I’m away from home, so another day.
Glad some folks are interested, it’s sort of fun to see the realm of possible
Thanks for your tests sbslider ! I wanna do something alike with some of my lights but I still didn’t have the patience and time! But this is quite nice data
Thanks again
Any chance of a new batch this year using the new led source?
Any chance of a new batch this year using the new led source? :question:
It sounds like there is a good chance of it, but it is not confirmed yet:
I will ask Barry when a new batch of C01’s will be made. Sofirn is going to use the rngwn-sourced leds for this new batch, and I hope that the host version can be added to the production batch. I get the impression that new things at Sofirn start happening only after chinese newyear so maybe patience is still needed.
I don’t know how many people still want C01 with this new 5mm HCRI led
The 5mm led has two options 3400K and 5800K. The body color of C01 can be Black, Red, Blue, DesertTan, Green, Orange, Bare-Aluminum
Maybe it can be 5000pcs in total.
I’d be interested in another 3400K, but even more interested in some hosts and drivers if you do another batch.
I would be interested in a couple more 3400K C01 single mode lights.
I’d like a couple of black C01 hosts.
I do not think you can find interest on BLF for another 5000 pieces Barry, it is just way too many, maybe 2000 but not 5000.
But that said, the concept of an unbreakable 1xAAA light with good quality 5mm led for just a few dollars will not easy grow old, they will keep selling for many years, not just via BLF. So a batch of 5000 still sounds good.
I’m in for a couple of desert tan ones in 3400K.
And as a reminder, as said above and in the host thread, it would be nice if a few hundred C01’s will be made as a host: with driver but without led and without potting compound. Is that still a possibility for Sofirn?
I would be in for some of those, my friends have kids that want lights and this is the perfect gift for them to start playing with flashlights!
And I agree with djozz, this is probably a concept of a light that will sell for years, either for “collectors” or “users”!
Fenix has recently ceased production of the E01. It was found in nearly all outdoor shops, maybe Sofirn could step in. HCRI could be marketed as natural light with extremely little power consumption using ubiquitious AAA batteries or something like that. I mean, that’s what it is. Customers just need to know :-).
I’m in for a couple of desert tan ones in 3400K.And as a reminder, as said above and in the host thread, it would be nice if a few hundred C01’s will be made as a host: with driver but without led and without potting compound. Is that still a possibility for Sofirn?
I didn’t expect 5K interests on BLF, 2000pcs is good enough. And I just hope to bring the cost down. More quantity in one batch, lower cost it will be. Then a better price will be possible.
If the whole light with new 5mm HCRI led is ready to made, host with driver but without led will be possible too. And both No potting. Potting cost too much time to do. I believe it will tough even without potting.
Also, I think offer one tint choice will be better than two tints choices. One tint is easier for fast assembling and keep cost low.
It seems 3400K is a better choice? That will be a great comfortable beam for kids.
i would definitely add a bunch of these to a future order.
wish you would do the sp10s in more colors, love the old sofirn champagne lights
