You misspelled Sofirn otherwise Great write-up!
And BLF.
Great review! :+1: I will certainly bookmark your website and share the review with others asking about it.
Thanks for the corrections sbslider, dealgrabber2002, and raccoon city, I’ve updated the review to correct the spelling mistakes and blinking behavior.
Also, the manual says the LEDs are 2700K and 5000K, not 3000K and 4000K like I originally wrote which I have updated in the review as well.
hi, guys.
i`m working on review of this gem, will compare it to CL30R.
and i faced question - what is manual and automatic memory in 5 clicks? tried to search , but couldnt find answer
IIRC
Manual : You set the level you want, set the memory to manual and after that the lantern will start with this level at each power On.
Auto : When powering On the lantern will start at the same lvl it was at last power Off.
grand mercy,
red manual several times, found nothing. strange.
btw, manual (at least the one i got from sofirn) contains lots ot copy-paste from regular Anduril UI, which dont refer to LT1 -)
English manual is here: https://drive.google.com/drive/folders/1HIFCFcBus5XRjKMfgkjAR7nH1R62qp_5
While the LT1 is on, 5H clicks (not releasing the 5th click, but hold) sets it to manual memory, or where it was last turned off. This is the default. 5C (just 5 clicks) from on sets it to auto memory, where it turns on at the level it was at when you set auto memory.
So with the drive current being 16ma on level one it appears we could reasonably assume 600 hours run time before the first stepdown?
That would make the output on level one like 6 lumens?
His measurements were close to that i was getting too when i was testing the amp loads. (with the 5-AMCs default per channel) 6 lumens average seems to be about that output on the lowest of the stepped ramp setting.
On the bottom of the driver I see the solder brides to enable more 7135 chips. I also see a screw. What is the screw for?
correct, there are two extra bridges for enabling up to 7 of the AMC regulator chips for each channel of the tint ramp, (meaning it is even possible to have a lower maximum output on one channel than the other, ( as in a brighter 5000K N/W end and a dimmer maximum 2700K W/W ramp end, or have both equal to increase the total outputs (but loose some run time) I believe Lexel mentioned the varisistor (adjustable resistor as some control of the side switch glow operation, (which has its own mode selections from low, high, candle flicker, off, etc.
Great review, thank you!
The Sofirn LT1s with 1x 21700 is now out on the market
Well, this is new. A shorty, single 21700 LT1 with a red channel and a wider adjustable CCT range? Also looks like you might be able to individually control left and right side emitters. [image] [image] Here’s what I could gather Emitters: 18x 2700k, 18x 6500k, 4x red (all unknown manufacturer/model/CRI/duv, but they’re referred to as CSP—perhaps Nichia E17A, E21A or Luxeon HL1) UI: Unknown, but features suggest a customized Anduril with triple-click for red. Battery: 1x21700 (onboard US…
So graphs and pie-charts are good on paper but real world isn’t the same. We are off grid up here in N Idaho. I have 2 LT1s and love them to death. One hangs in the livingroom and one in the bathroom. We use them every morning and every night. Time is aprox 4-5hrs per day. We get about 5 days use before they start auto-dimming levels (means it needs charging). The one in the bathroom will go almost 7 days because we use it on a lower mode, but we charge both at same time.
So 5-7 days of real world use. If you were frugal and used at lowest setting that you could see by it might last 2 weeks.
Great to hear!
Beautiful area you live in. How do you charge your LT1s?
We live near Spirit Lake Id and charge/run on solar and gens.
It was 2f this AM and I have some cold chickens. Need to grab eggs as laid or get frozen cracked eggs.
By our lake.
Beautiful!
Lost this thread. Subbed
