Nice reply yeutterg, I ordered two to try it
Thanks for your support, and I’d love to hear your honest feedback. Cheers.
Greg
Just to satisfy my curiosity, I did some tests on the AC line in my house. I don’t have any expensive power quality measurements devices, but I used whatever I had on hand.
Checking my UPS logs, I can see that during the last couple of days the AC voltage has ranged from 218 to 230 volts.
First I measured the AC voltage vs. lumen output over 10 minutes. To me the voltage fluctuations don’t seem that bad (226.1V to 228.4V).
A typical constant current controlled bulb doesn’t react to these little voltage changes in any way and would look like this:
I tested the stability of the AC waveform at my house using the pass/fail function of my scope and making a mask around the waveform. I let it run for some time, but there was no sudden spikes all the while I experienced some visual fluctuations on the bulb. AC voltage ranged from 213V to 215V during this test.
And as can be seen from the scope screenshot, the waveform is quite clean. The THD of the AC line at my house is only about 2%.
And for testing the crest factor, I used a Uni-T DMM which can show the max/min values of an AC waveform in addition to the RMS value. With a perfect sinewave the ratio between those two or the crest factor should be sqrt(2) or about 1.41.
What I got was pretty much spot on (316V/226.2V=1.4).
I also turned off most SMPS power supplies and lights, but that didn’t make any difference to the behavior of the bulb.
Too often testing the tests takes more effort than doing the tests themselves.
I tell my customers (I am an A/V dealer) constantly that LEDs are THE place to invest. If you amortize the cost of a quality lamp ($25 per) over the life of the bulb (lets be super conservative and say 10 years) you’re looking at roughly $.20 per month per bulb.
I understand it’s a lot to lay out up front but you’ll be paying for cheap products (in the form of headaches and poor color rendering) for the life of the inferior product, which with LED technology is a long time.
That’s the problem with poor quality LEDs, you’re stuck with them for much longer.
I’m curious to check out a couple for our nightstand lamps.
I’d like to try using your emitter in a flashlight (right now we use amber emitters in our evening flashlights).
Would you sell the emitter on a 16mm or 20mm board for hobbyist use?
Watermanchris: 100% agree. Plus we have a 5-year warranty, so if the product does fail for whatever reason, it’s pretty easy to get a replacement out of us
hank: It’s actually a filament operating around 70 V, but we unfortunately don’t sell them. We have a pretty tightly integrated supply chain. You may consider breaking open a bulb and using the filaments from there, but consider using cheaper filament bulbs first to test as they are quite delicate
Greg Yeutter , Can I become your dealer?
Actually it would be the custom phosphor I’d like to get hold of.
I could dissolve it, I guess, and paint it over a blue or royal blue LED?
If you’ve patented the phosphor, what’s the patent number?
Ah I see. Patent still pending. Right now, it’s going to be difficult to pull out of the supply chain, but we will reconsider for the future.
thank you for letting me know that even with stable power in Finland, the lights have visible flicker
I hope the manufacturer fixes the problem
well… I dont mean to be snarky
however, you dont seem to have understood maukkas comments.
I suggest you re-read maukkas posts, and let us know when you have fixed your driver
clearly the problem with flicker is not limited to USA, nor to “very unstable voltage”
«It isn’t bug, it is feature» (of filament LED bulbs)
Okay, so if I’m reading all this correctly, they’re phosphor-coated filaments?
Filaments have plenty of thermal inertia that only rather drastic fluctuations should be noticeable. The driver must exhibit some pretty serious fluctuations/dropouts to visibly register. Yeah, I’d say definitely work on that.
People used to grex about “pre-flash” when flicking on moonlight/firefly mode on some lights. Having visible stutter on a lightbulb would be a pretty serious glitch.
@jon_slider It’s unclear why you think I don’t understand this discussion. I can confirm that this is a very rare issue with the US bulbs. We’ve sold 10s of thousands with mostly happy customers. Like I said, we only see visible changes in places with power that’s too noisy.
Maukka was literally the first person to test the first batch we ever shipped to Europe. It’s good to know upfront if we have a potential issue with this batch.
We will keep testing to see if it’s an isolated case or a widespread case with the European version. The prototype did not have this issue, so we are doing an investigation to see what changed from test to production.
@Lightbringer They are LED “filaments.” Similar concept to regular discrete LEDs except shaped differently, plus our custom phosphor. The stability of light output is mostly due to the driver circuit as the diodes themselves can fluctuate very rapidly to changes in input.
Europeans (EU countries + UK only): interested in helping me do a test of my bulb? I’ll send you a free Bedtime Bulb if you don’t mind helping me out with a small experiment.
I want to see if the issue that Maukka had is replicable in other regions of Europe. All I would need you to do is to screw in the bulb, observe it for a few minutes, and see if the light is constant or not. You’re free to do whatever you want with the bulb after the test.
If you are interested, please send me a private message with your name and shipping address. Also specify if you prefer the B22 Bayonet base instead of the E27 screw.
E27 Screw version: https://www.amazon.co.uk/dp/B07XWCNCDJ
B22 Bayonet version: https://www.amazon.co.uk/dp/B07XW7NHQT
Thanks,
Greg
Okay, so when you say “filament” it’s more a form-factor (similar to COB LEDs but on a string vs on a board), and not a heated filament as in incandescent bulbs.
I was curious what kind of phosphor would be thermally excited to produce light… that’s what threw me by use of the term “filament”.
So it would in fact be subject to flicker, etc., if the driver passed through voltage variations (hiccoughs) in the mains supply.
Yep, depending on how well the driver handles variations in the mains
Where could us fun loving folk buy some LED Phosphors in small quantity? Do you know any good sources?
finds a bunch of suppliers and some information about which phosphors have what color output.
E.g.:
. [link on original page]
Hmmm, I can imagine BLF getting into custom mixed phosphor creation.
Here’s the tech note page on blending phosphors: http://www.intematix.com/uploads/application%20notes/PhosphorBlendingAppNote10Jan2013.pdf
Find a source of the “underling blue LED chip” and start mixing up phosphors.
I recall when the original single-phosphor “office white” fluorescents got driven out by “triple phosphor” high color rendering fluorescent tubes.
Triple phosphor lamps had another advantage, as some phosphors have a long decay time so kept puttiing out light when the AC power 60 cycle went through its zero point or the AC power flickered briefly.
Yeah, I’m a dinosaur.
