Sorry for off-topic. Markets have been expecting coronavirus to have little impact on global economy because everyone would come back to work only a week late. This looks like wishful thinking at this point.
Woah, the Nitecore CI7 has a rotatable head to switch between 4 regular led and 4 IR leds? That’s cool! I’ve never seen that before. Just pull the head out, rotate 1/8 turn and drop back down.
Features:
3A each slot ,12A in total.
Charge/Discharge/Capacity test /Repair
Automatically select the optimum charge current.
Easily choose current you want at manual mode.
Wide & High charging current choice: 0.25A /0.5A /1A/1.5A/ 2A/ 2.5A/ 3A for eachslot.
Show charging status in real-time like voltage ,capacity,temperature,time,current.
Enough space for 21700 battery, even button top 21700, PCB 21700 .
Top surface have a button top type feature to make contact in recessed battery
It is compatible with every type of rechargeable battery.
Support 4 slots charging independently without interference.
Automatically activate and repair “0 voltage”lithium battery.
Automatically calculate battery charging time.
Automatically calculate the battery percentage.
Charging protection, over-discharge protection and protection of polar reverse,shortcircuit protection .also, it can detect a broken battery.
Temperature control protection.
Keep your battery safe, most important,your lifesafety.
Intelligent power bank 5V 1A.
Certified by FCC CE ROHS.
