Features:
3A each slot ,12A in total.
Charge/Discharge/Capacity test /Repair
Automatically select the optimum charge current.
Easily choose current you want at manual mode.
Wide & High charging current choice: 0.25A /0.5A /1A/1.5A/ 2A/ 2.5A/ 3A for eachslot.
Show charging status in real-time like voltage ,capacity,temperature,time,current.
Enough space for 21700 battery, even button top 21700, PCB 21700 .
Top surface have a button top type feature to make contact in recessed battery
It is compatible with every type of rechargeable battery.
Support 4 slots charging independently without interference.
Automatically activate and repair “0 voltage”lithium battery.
Automatically calculate battery charging time.
Automatically calculate the battery percentage.
Charging protection, over-discharge protection and protection of polar reverse,shortcircuit protection .also, it can detect a broken battery.
Temperature control protection.
Keep your battery safe, most important,your lifesafety.
Intelligent power bank 5V 1A.
Certified by FCC CE ROHS.
Great video. While I prefer USB-C charge and standard batteries, I have no issues with Olight using proprietary batteries and magnetic charger. In fact now that I own so many Olights, I became quite fond of their very convenient universal magnetic charger. Also most of their lights can use standard batteries except they cannot be charged with the magnetic charger.
Anyone wanting to try an Olight, please don’t get discouraged by negative folks scaring you about the proprietary batteries. Olight makes flashlights with by far the highest build quality and most efficient drivers in the entire industry.
