ANDURIL USER MANUAL & LIST OF LIGHTS
+1 on that Voltage cal. I'm gonna add it if it's not gonna happen. Maybe code space is getting too tight.
Is it possible to reconfigure momentary brightness setting?
It uses the last used level.
Yea, I don't see anything wrong with it since it uses the last used level.
I understand how to calibrate the temperature sensor, and how to set max temperature. But what is supposed to happen when you are running in temperature regulation and then double click to go into to turbo?
I have a new EC01 that I just calibrated and set for a max temperature of 45C (15 clicks).
From a cold start, I ramp to max, then doubleclick to turbo. The light heats up to about 50C using my IR thermometer. The output does decrease and the temperature doesn’t get any higher. Regulation looks good.
Then I doubleclick, putting the light back in turbo. The temperature rapidly climbes to 60C at which point I turn it off as it’s getting too hot to hold.
Does doubleclick bypass the temperature regulation?
No it shouldn't. But you do get to start over, so you may have a min time before it regulates again.
The Ec01 is a burner with the XHP50.2
That’s why I wanted to calibrate the thermal settings. Mine draws about 16A from a Samsung 21700 30T. It gets hot pretty fast.
i don’t see any difference from maxramp to turbo, why? (temperature limits 20 clicks and a new samsung 40t)
Thank you so much Toykeeper for the instructions. I thought I had bricked my Fireflies E07, but apparently I just got into programming mode by mistake after a few too many beers and messed it up. Your instructions got me straightened out! All Hail Toykeeper!
Yes it does, temporarily. Otherwise brightness would not change at all.
I find this a very useful feature.
Something like manual override.
Temperatures get back to normal after a while.
I prefer NarsilM myself. Config can’t be entered by mistake and you can entirely disable thermal step down for those who like manual control. I also don’t always like all the blinkies and strobes. It’s great on the LT1 Lantern but most lights it feels too much
:+1:
You guys would probably like my version of Anduril then. I got rid of the blinkies on the 3 click menu - all it does it voltage readout, temp read out, and version num blink I up'ed the max temp to 90C as well.
I would like that along with a method to simply load a user interface customized to my preferences through a USB-C charging port that also functions as a data port.
many "outsiders did not know this "feature" - so i made a video
www.youtube.com/embed/b9zfzjzlBCw
didn’t you play a major role in creating/developing this firmware?
Hello.
Doesn’t anyone know, which version of Anduril FW does Astrolux EC01 use?
Thanks!
No clue what’s on it. It’s currently on the list of license violations since they’re distributing the product without providing source code.
However, I just recently got a bit of info about it, suggesting that the OEM might be Sofirn… so hopefully I can contact them to get it resolved.
And in general, I think there needs to be a map to help people figure out what firmware ships on commercial lights. Will probably put up something about that soon, since it’s a common type of question.
im positive the ec01 is made by sofirn, the switch feels identical to my c8f… weird they would be violating your license like that, they should know better.
Not that weird - I’m pretty convinced Sofirn are using at least parts of TK’s code in the Wurkkos FC11 and others that have non-Anduril implementation of stepless ramping. The operation just seems too similar to the full Anduril operation for it to have been developed as fully independent code…
Only TK would be able to find out and reverse-engineer the driver to know for sure, but even using snippets of code should require the license terms to be met.
