Ordered some #4 #6 #7 = bye bye green
I made some flux loss test in an integrating shoe-box™ and with a smartphone luxmeter (with ceilingbounce app from Zak)
This is what I got :
nothing :106%
lens : 100%
lens +
1 : 91%
2 : 96%
5 : 95%
7 : 90%
10 : 94%
13 : 95%
14 : 94%
lee minus green
1/8 : 86 %
1/4 : 82 %
1/2 : 69 %
And some beamshots, I tried to find the worst beam I had but it’s not a really bad beam so… would have been better with a really terrible beam for demo.
beamshots with some diffusers and minus green filters - Album on Imgur (zoom on the pics because otherwise there is some color banding)
I couldn’t beamshot all diffusers because some samples were too small for this flashlight, I also had a sample 1cm wide… can’t test it on any lamp… on the other hand, #5 is supposed to be a sample, yet it’s a full sheet
I didn’t beamshot #1 either because it’s adhesive, and since I wont put an adhesive one on this flashlight… I would have to waste some #1 .
#7 is directional !! like 5 but less pronounced…
#2 seems like the weakest diffuser (but the one with the least light loss)
Minus green’s are pretty cool I’ll decide between 1/8 and 1/4 for this lamp.
edit (added #1) :
#1 :
#2 :
#5 :
#7:
#13 :
Honestly when I first started carrying thicker sheets of diffuser film I was curious about what real light loss numbers were and wanted to send them to people with integrating spheres to do real world testing . the reason I didn't was I knew it would be a pain and in the past few years almost no one has ever asked what the numbers were . I assume it's because the before and after effects are already so visually stunning that people really didn't care .Having tint shifted colors in the corona mixed back in and a smoother beam with virtually no artifacts probably makes people happy enough not to start questioning light losses .
I'm happy to see very good numbers though . The pictures are excellent and it's nice to see that clicking on them results in a much larger picture opening up in another tab .
Great work ...thank you for doing this .
Now I need to send you some bigger and better samples :)
Thanks for these measurements and beamshots!
I too noticed a slight non-uniformity in the beam with #7.
I wasn’t sure if it was due to irregularities in the frosting pattern, or if my application of the film introduced some distortion, or…
I edited with #1 in my previous post.
With a wurkkos FC11 I could beamshot the smaller samples, the beam is originally better though.
album imgur : Wurkkos FC11 + diffusers and minus green lee filters - Album on Imgur
How would you apply this one when it has no adhesive?
I just added some to a TackLife that I got. Pop the front glass, cut a disc exactly to that size but just a hair smaller if need be, and pin it against the glass with the reflector.
Obviously, it’s not gonna be a thrower anymore, but for heading into the basement/attic/barn/whatever, it’s about perfect.
^ That’s how I did it.
Excellent, thank you
I tried to remove the bezel on my SP40 but it’s way too tight, maybe they glued it
Mine was tight too, but not glued.
What worked for me was to use a large flat rubber band, like the kind that is used to bunch broccoli or other vegetables. I put the flat parts against the bezel to give my thumbs more grip to unscrew it (holding the light vertically, bezel facing me, left thumb pushing down on left side of bezel, right thumb pushing up on right side of bezel), and then it wasn’t bad. I used the same technique in the opposite direction for tightening the bezel when reassembling.
Btw, on my SP40 the bezel does not sit perfectly flush with the body of the flashlight. There is a very slight gap. Is that the case for others too? I think it was like that before adding the film, but I wondered if the added thickness could have had an effect. I’m a bit too lazy to remove the film and check for the gap again. Hopefully it doesn’t affect the water resistance.
Hi experts,
Just learn about diffusion film thanks to your discussion in Review Sofirn SP40 Can you please help for some beginner’s questions?
Q1. What a diffusion film look like? Link to photos/videos?
Q2. How to use it? Reading in a few posts above it looks like there are two solutions: adhesive on the outside or disassemble the glass and put it inside.
Q3. Does the diffusion film has any influence on the color temperature?
Q4. Reading above, for Sofirn SP40, film #7 is the most suitable. What is the reason?
1) plastic sheets of variable thinkness and patterns
2) yes, or adhesive inside, or non adhesive outside if there is something to hold it, whatever suits best each cases.
2) look at my beamshots in the previous page, some lower the CCT a bit, especially #10 but also #13 and #14, all of the others too it seems to me, but it’s very faint (even on top of an already diffused beam, so not tricked by the uniformisation of the tint)
7) #7 is a strong diffuser (like #1), good if the goal is a floody headlamp, and thin, so good to go behind the glass
How big is the sheet? Like a “Letter size” paper? Or a same dimension as a post card?
Looks like film #7 is a good choice. Just for safe, I would like to attempt an adhesive version of that file #7, can you please suggest a model?
Sizes are given in the 1st post. #1 (dcfix) is adhesive and also a strong diffuser, I just put some on a h600fw on which I replaced the lens (by a clear one because I didn’t find frosted lenses), adhesive was needed because there is no space inside even for the 0.2mm thickness of #7 (or #1), it had to be put outside.
Can’t wait to receive my filter sheets!
Great pics that deserve a re-post . They can be clicked on twice to be made bigger & then bigger yet .. Thanks for these !!
Epic !
Thanks man! Received mine in the mail today , fast shipping and good communication. Will try a beamshot comparison on my zerbalight sc700d.
PM sent to you, Boaz. Thank you.
My camera is acting up ,but here is a after and before. Didn’t think there was this big of a difference in tint, definitely on smoothing out the hotspot, but the pics tell the truth.
