[Canceled] Sofirn SP70 BLF Edition
Barry, this question was started to be discussed on my SBT90.2 concept thread already, see here:
https://budgetlightforum.com/t/-/59274/9
The SP70 host design might be okay but it would require changes in the reflector design (SMO instead of OP), its aperture incl. new centering gaskets and it takes a completely different driver as SP70 uses a 2S (2x 26650 in series) design to drive the 6V XHP70.2 LED. Personally, I recommed to follow up on contactcr's suggestion to develop an extensible host design with a sophisticated buck-boost driver, capable to handle 3p and/or 3s2p or 3s3p (via extension tubes). Thinkin' about extension tubes Sofirn has sucessfully manufactured some prototype extension tubes for Sofirn Q8 (and LT1). The final SBT90.2 light could use following specs:
Type A
Redesigned Sofirn SP36 with single SMO reflector and 3p 3V FET driver (with 3x 18650 battery design + n extension tubes to prolong runtime)
Pro: Cost-wise easy to handle, development work would be small, sales prices can be kept as low as possible
Con: Battery format will not make use of the best high drain cells (21700 size), driver efficiency could be better with buck/boost driver
Type B
Redesigned Sofirn Q8 with single SMO reflector and efficient buck-boost driver, capable to handle both 3p configuration as well as 3s1p, 3s2p, 3s3p ... by extension tubes)
The Q8 tube needs to be redesigned to use 3x 21700 instead of 4x 18650 to use the benefit of the best 20A+ high drain 21700 batteries (Samsung 30T/40T, Molicel P42A).
Most costs and efforts will be addressed to the driver development but this could pay off in the end with the launch of more high performance premium lights.
Pro: Best USP (unique selling proposition) in competition to Acebeam K30GT and a good way to start a premium line of Sofirn flashlights.
Con: Costs and development efforts would be considerable as well as the increase in its sales price.
Are there any news on the development?
I saw a BLF-Sofirn Sp70 Flashlight posted in Aliexpress store. it is already released?
All well and good but it better become available in the Amazon store. If I have to wait months for shipping I'll pass.
@Chinaheart Can you provide a link please? I did not find anything on Aliexpress…
Can you please provide a link? I cant find a BLF version of the SP70 anywhere on Aliexpress.
A while back I remember seeing an SP70 on their Aliexpress store that was labeled as “BLF” but it was just the standard SP70 with the Sofirn 6 mode/ramping UI. I don’t see it on there anymore though.
It’s the same light they have always had, they just ditched the BLF
so they wont do a blf version then?
https://sofirn.aliexpress.com/store/2933049
Hi FlashPilot... here it is
That’s just the store link
It still shows the OPR.
Had posted about that and deleted my post cause mixed up reflector types. Just in case anyone wonders what that was about.
OK, the home page shows a banner, out dated banner, but still a banner saying BLF-Sofirn SP70 which we know doesn't exist.
Really looking forward to this release
Thanks for the clarification. :+1:
I think this one might fit nicely for SBT90.2 ? what dha yee think?
Not really. You can run a 3v driver with a single 26650 and a spacer, but that’s not a lot of power and your wasting space.
You can run a buck driver and 2 batteries but I dont think there is a driver powerful enough to really push it hard.
So not a good design form for a high power 3v led.
Need some info on the SP70 driver, anyone know the input voltage range?
More specifically will it run the xhp70.2 from 4.2v or 12v?
EDIT: I found the answer to ^ this^ from Sofirn in my email: Input voltage: 5.6V-8.4V
Still wondering what type of driver it is? FET/DD w/zener diode?
Ok, my pictures of the driver are better than Sofirn's:
This is a classic FET design. Using the top pic as a reference, the large part on the left is a FET, one we are familiar with in fact. The bottom right pin of the FET is the FET gate, and you can see connected to that the 2 standard resistors our designs use for the FET gate - one is a low value inline, the other is a high resistor value going to ground.
The 5 leg part on the right is an LDO, to bring down the voltage to ~4V to run the MCU. The 3 leg part on the bottom appears to be another FET for lower power, but it appears to be not used, not connected to the MCU - I'm not sure, would have to trace the circuit myself.
I've seen these kind of dual FET, one hi power - one low power, driver designs before. In fact the Haikelite HK04 is very similar:
This uses 2 high power FET's instead of 1, and the part labeled Q7 near the FET's is the low power FET channel.
