He has a facebook group that’s super active - he’s said before that he likes to make the lights thicker so they’re stronger, so I’m not sure if he’d be interested in making a thinner one… But if he did, I’m pretty sure it would become the #1 recommended / best 14500 light. Everything about the Lan and Pineapple is pretty much perfect - moonlight, max output, mode spacing, tint, they look nice, great clip, great build quality - the ONLY thing that some people don’t like is the thickness. The Mini Dawn is supposed to have a new programmable driver - realistically, I’m gonna end up buying one regardless, but if it were thinner than the Lan (like about the body width of the Pineapple, without the wider head and tail), there would literally be nothing on the market that could touch it. I know its still in design, so hopefully it comes out thin and trim!
If you can find a used or NOS Olight S1A, now discontinued, the Reylight Pineapple AA clip fits perfectly on it.
I emailed him and he is not at all interested.
I emailed some custom light makers and they don’t want to bother either.
Ugggh.
This is so frustrating.
> it’s too thick
what is the OD and ID?
Maybe ask someone with a lathe to shave the outside of your Lan?
The customized Tool Ti is what you want.
Maybe someone is willing to mod it for you.
I changed the ugly XPL2 for a 4000k High CRI SST20, what a difference!
Size comparison here;
Could always ask lumintop to do replacement pills for the tool ti like they have in the normal tool hm kit, with the amount of aa tools that have sold I’m sure pills with better cri led options would sell well, especially for those that want to swap but still haven’t mastered soldering!
from this thread:
correct
specifically the AA models have non removable bezels. The pill is press fit from below the glass. That means modification of the LED is not possible, unless someone breaks the glass and presses the pill back out the bottom of the head.
since you cant have a drop in, and you cant solder…
consider adjusting your dream, to include paying someone to modify a light for you
I agree btw, that the stock Tool clip is not very good, it sits too low, and it can pull off. Mascaratum showed you how he solved that.
I’m waiting for this. I think I prefer the reflector optics.
If it has Anduril, dual chemistry support, and low moonlight it would be about perfect for me. Add a recessed switch and we have overreaction.
L3 Illumination L11C? I have an orange 4-mode one and is the slimmest AA light I own. Works with 14500 but modes get brighter and hotter quicker.
Bit old now but some are still available - sbflashlights
bought an orange when they went on sale ...I rushed out and jumped on it ...
then I realized all the other colors were on sale too . I love that olive
Huh? My Tool AA 2.0 Ti has a two piece head that can be opened fairly easily, and the PCB is the same as in my Tool HM kit, it’s just on a shelf not in a pill. I swapped a 219b into my Ti and it’s my favourite light to carry. No breaking glass required.
I agree your Tool comes apart
I posted in the wrong thread, so I can understand that was unclear
The OP was asking about modding an Eagletac AA, here:
They’re extremely easy to mod. Bezel screws off, parts fall out. You can even remove the pill in the d25c. Some titanium models don’t have the bezel and can’t be worked on.
I’ve been on a similar search for a while now, though I’m a bit more lenient in terms of maximum width. The Stainless Steel Amutorch 1xAA is an interesting platform to start on, maybe drop in a 15mm FET driver from mtnelectronics and an LED of your choice. I currently use a Convoy T2 w/ a bolted on solarforce T1 clip and a 17DDM with Bistro, however that’s closer to 20mm in width and you lose AA support. The Jaxman E3 starts from a similar position to the T2 in being very moddable, but is also on the wider side. The E3 does take the old Olight Baton S1 deep carry clips (can be bought from olight on ebay).
The Amutorch with 219c is very nice (i bought one from Neal last year or so)
No need for another driver, this one puts out plenty and it does get hot on turbo with 14500
The overall build of the Tool Ti is much better, but the parasitic drain is high and my led wires came off while doing runtime testing.
So hardware is top notch, electronics definitely needs improvement
No need for another driver, this one puts out plenty and it does get hot on turbo with 14500The overall build of the Tool Ti is much better, but the parasitic drain is high and my led wires came off while doing runtime testing.
The Amutorch had mediocre mode spacing and terrible PWM on the stock driver. The backlit tailcap in the Tool is the source of the “parasitic” drain no? It’s a mechanical clicky otherwise and should have no standby current.
Modified Klarus Mi7? Side switch though. Moonlight isn’t great, a bit too bright.
DQG Tiny AA - head diameter 17,5mm, lenght 67mm. No switch, its a twistie.
Also available with 90CRI LED. It works with 14500, but the output is almost the same as with the NiMHs (barely brighter) according the reviewers.
I love those little lights. Wish they weren’t so expensive. That is pretty pricey for a AA light. I’d buy a few at maybe $20. Almost $40 is out of my range for AA lights. Maybe I can catch a sale one day.
thanks for the photo comparison
are the 2nd and 3rd light from the left AA lights?
on the right is an AA with a Rotary Dial, my grail UI:
Sunwayman V10r Ti+ (16340), Sunwayman V10a (AA)
Sunwayman V10r Ti w AA adapter for V11r
