I think I will use a glue, so isn't regular (paste) glue will be better than double sided?
In addition, manufacturer recommend not using any glue nor stickers on the helmet, what do you think? Can it weakens the helmet?
It is time to start working on the circuit, I had an Idea to try print the PCB at home but most of the components are still on the way from China
Luckily I did got some drivers for other project and can use them:
Since I have to use a Nanjg 105C and a 1.4A single mode Drives, the control of the 2nd driver will be connected to Star2 (pin5 - OC0A) of the Nanjg.
The blue led will be connected to Star3 (pin3 - PB4)
And the switch to Star4 (pin2 - PB3)
Hâmmm. Someone else to be scared of. Didnât know you were into black magic.
Startin soldering, first I had to add 4 more AMCs to the 1.4A driver in order to allow maximum output of 1000 Lumens for each LED
Unfortunately it wasn't the tiniest thing I has to soldar, but first I cut the outer GND ring of the Nanjg 105C to allow easier and stronger soldering to the stars:
Finally I soldered 1806 resistor and LED to star3:
This is the first time I am soldering SMT parts by hand and it wasn't fun.
Next step is optics.....
Yessir. Those are difficult to work with. You have a certain amount of bravery to venture into that
Have to agree with Don here. Nice effort. :+1:
Busy weekend ahead, planing on finish the light
Just added the optics and soldered everything together
Glued the emitters (2*xm-l2 4200k on Copper MCPCB) to the heatsink with thermal paste:
Soldered all wires that cannot be reached after lenses are in place:
Carved the lenses (10 degrees tight Spot and 90 degrees Flood) holders, with a knife not to create dust inside the lenses:
Glued the lenses in place:
And FINALLY soldered everything together:
Sorry for posting a lot today but I had a lot of progress
I was working on the FW.
It is based on my original Caving light FW I already posted on this forum but I added some features and fix some minor bugs.
Main features are:
The improved code can be found here
But before burning my FW to the light, I had to calibrate the voltage measurements, using my BattCheck FW, heavily based on ToyKeeper's Battcheck firmware (Thank you ToyKeeper)
You can download my FW here
Now I only have to mount it to the Helmet and test it in a cave
Love your work YuvalS. Good stuff.
Just did the final adjustments, some fixes and mount it to the helmet
First I had to sew the elastic band that hold the battery box to the back of the helmet (never thought that sewing can be part of building a light)
Then follow the advice of MtnDon, pinkpanda3310, DB Custom AND G0OSE, I used 3M double sided tape to glue the GoPro mount to the helmet
And now I can finally say that this build is completed (one week ahead of due date)!
I had this Idea of building a budget profesional caving lamp forever but always had something more urgent to do so this competition was exactly the encouragement I needed to complete this project.
I tried to document every step of the build as clear as I could and shared my FW in case other people are interested in building a similar lamp.
A rough estimation I did, shows that the parts cost me about 30 USD, not including aluminum pieces, Perspex, plastic, wires etc. which I disassembled from old stuff or had at home.
An equivalent commercial caving light costs more than 600 USD and the FW is less suitable to my needs so, in my opinion, it is really represents the BLF spirit.
If you have any comments or ideas please comment and don't hesitate to ask me any questions if you are interested in building a similar light.
I like the light. Great idea and work through.
A short video I made on my caving FW,
Sorry for my english , please note that the step-down timer is 36 seconds and not 36 minutes
Love it, well done you!
Oh, and howâd that 3m tape work out, is it still attached? i was thinking after it may be a bit heavy for that tape, and thought about using strong magnetsâŚâŚâŚ. or maybe a high quality mini cam mount with sucker/windscreen mount? (not an ebay $2 one)
Any cave shots with it?
Well done
Thanks guys!
Love it, well done you! :+1: Oh, and howâd that 3m tape work out, is it still attached? i was thinking after it may be a bit heavy for that tape, and thought about using strong magnets⌠or maybe a high quality mini cam mount with sucker/windscreen mount? (not an ebay $2 one)
Thatâs a cool looking headlamp YuvalS! I like that you can see all the wires and components. Kind of reminds me of The Terminator:
Orsm build YuvalS. Iâve enjoyed following you on your trip building this head torch.
Epic build!!!
