It might be easier to understand if you look up reviews of a light such as the Jetbeam RRT-01.
But basically there is a portion of the flashlight body that you turn to access the different modes. In some designs, it can be infinitely variable so you turn the ring like a faucet and it will slowly brighten or dim depending on the direction. In other designs, the ring clicks into indents as you spin it and it has specific lumen levels like low, medium, and high. This is more like turning the knob on a pedestal fan.
Wow this is genius. And this for a light aiming to be solde for around $20? How can that be possible? I don’t see thid mechanism even on light costing $90, Armytek for example.
Are you in the US? Do you want one? Well not the exact light being talked about here but, a variable ring controlled light. I have a few extra laying around. Shoot me a US address and I will ship you one.
Waterproofness is very good, in fact many diving lights use it.
They are not really popular to make because it is structurally a bit more advanced, and more expensive, than a simple switch. I looked up the magnetic sensor that is used in the VR11R and it is almost 2 dollar for the component alone (when bought on ebay). Manufacturers must be very sure of the popularity, so the preparedness to pay a bit more, of magnetic control rings before designing a light with it, and that is what we attempt to show them with this thread.
a couple examples of rings with clicks and or a series of discrete levels includes Sunwayman M10r (4 steps), HDS Rotary (24 steps) and Spy007 (7 steps)
the last two are still available today
the original post in this thread was heading towards a 4 Step Rotary dial, along the lines of the M10r I think
Other examples of Infinitely variable include Sunwayman V10r and V11r
these are no longer in production
Im happy to hear there has been some consideration of producing a new Infinitely variable light, at some point
Is it a good idea? With wear in time, would this spin so well like a freewheel? ie. the ring moves unintentionally by the vibrations. And causing the light to flicker as a result. The other consequence could be the ring will be set in any random position each time you use it? Because the wheel will likely spin if it rests in a moving space like a car or backpack.
Beside that, this project is wonderful. Would you be OK to add a headlight version (90° angle)?
A fairly compact right angle headlamp with an infinitely variable control ring on the end would be awesome! Especially if it had a nice low low (.2 lumen) and a strong detent at off so you didnt have to lock it out when not in use.
I'm in for 4. Probably will buy more if the light lives up to expectations, especially if there's some colors other than solid black or gray available.
Infinitely variable is not a promised feature yet, but I still added you to the list as at least interested
The interest list is now at 268, and with still 153 from TLF the total is 421 flashlights.
Barry mailed me a week ago that he had missed my mail from january in which I sent a first suggestion-drawing of how the light structurally could be made, but that he passed it on to Sofirn’s engineers. I’m not sure when we will get an update under the current circumstances, I patiently wait for things to happen.
