RD new greatest power supply RD6006 DC power supply coming soon
RD6006 feedback
Very roomy body. For the cooling system is a separate plus. By the way, the fan changes the rotation speed depending on the heating. The default is off. Look for a detailed review on the КИТАЙ В ПОМОЩЬ YouTube channel.
https://www.aliexpress.com/item/4000282551930.html
RD6006 feedback
Perfect unit to build Lab PSU. Concerns: fan noise in case increasing temp. Very strange and not convinient wifi configuring and usage.
Is the fan noise so loud? you guys can leave message, we will make wifi connection better in the future
RD 6006 DIY case
here we show some DIY power supply based on RD6006, welcome to send me more!
RD6006:https://www.aliexpress.com/item/4000282551930.html
RD6006 feedback:
Everything is at the highest level! Delivery 22 days, packaging reliable, everything came in perfect condition. Thank you for the good service and for the gift.
RD6006 feedback
The unit took a tip from the reviews (it is praised), when unpacking it feels like it got a new iPhone (the quality of packaging and printing at altitude). For the block itself, it’s better to read reviews on forums or YouTube.
We have come back to work and we will ship the packages according to the order date. The logistics in China is gradually recovering. We will ship your packages as fast as we can.
We are deeply sorry for any inconvenience so caused.
RD6006 tips:
CC/CV mode depends on the load you connect. For example, if you are charging a battery, it will be CC mode first, and then CV mode when the voltage reaches the max value, the output voltage will be constant and the current decreases.
RD6006:www.aliexpress.com/item/4000282551930.html
RD6006 feedback
Great power supply. Delivery was delayed due to the virus. I get V1.26, updated to V1.28(use PC software). All is good.
RD tech,
Your #67 post above has a formatting problem. The customer feedback text line is full of non-breaking spaces ( ), this is wrong and causes the line to span far outside of the forum text box in small screen devices like mobile phones (you can see the non-breaking spaces if you edit your #67 post and switch to plain text); it's the following sentence, which I've edited and removed all non-breaking spaces. If you care please edit your post, completely remove the sentence and replace it with my edited one, that or manually removing the non-breaking spaces fixes the problem:
thank you so much, it is so kind of you
RD6006 feedback
Excellent quality! Satisfied with the purchase! Laboratory PSU ! Store and seller recommend!
RD6006 feedback:
Perfectly packaged power supply. How would I buy something from Apple;) Equipment of very high quality. I can't connect to my iPhone 8 via Wi-Fi. Correct it. I recommend the seller.
(you need to turn on the location service or consult us)
RD6006+S06D feedback
It arrived in Algeria in 25 days and it was installed successfully
RD6006 feedback
Super quick shipping. Very good quality. I've added rubber ring to prevent cable of temperature probe to fray. Superb service.
https://www.aliexpress.com/item/4000284522671.html
RD tech, now that there’s an iOS app for the RD6006 is there any chance of one for the DPS series?
IOS APP download: Search RdPower to download , support IOS8.0 and above phone
no , they have different app
RD6006 customer reviews
Packed in a box in polyethylene with bubbles. It works up to 60V. Naturally, it will not be able to deliver above the applied voltage, because it is a buck mode, there is a separate "+" jack for battery charging connection.
The items were just as described. Best packaging. Device assembly was straight forward and there was exactly correct amount of all components. With suitable power supply the device worked correctly.
RD6006W customer review
Everything is packed, very good, the body is in polystyrene foam. Thank!
the module is just super! The build quality and soldering at the highest level! Low ripple and high accuracy of the output parameters, I am delighted! Thank you seller.
