Thanks, we’re investigating.
You can get some of the Sunlike bulbs in 3500k
Sunlike8 can be mixed to 3500k Review: SunLike8 SMD SAW E27 LED bulb (4200K, CRI98)
Someone asked about REMEZ 3500k. REMEZ can be 3000k and 5700k ONLY.
I am going to produse SunLike5 with 2200k SOL leds
I believe that what is happening with the Bedtime bulb is that a large draw on the mains decreases the current to the circuit which is similar to what a dimmer does. The driver sees the decrease in current as a dimmer and decreases output. When the mains stabilizes after the in rush to the motor, the output returns to full. Lamps that don’t exhibit this behavior are likely not “dimmable”.
I don’t know if it’s possible for a dimmable lamp to not react in this way unless it could be programmed to not decrease output unless the current is decreased for >1 second. This would cause a delay when utilizing a dimmer which many users would not like.
We are finding your analysis to be mainly correct. We do believe it is possible to implement a dimmable driver that does not have this behavior, but it will likely require a different topology than what we currently use.
There is not enough space for good led driver inside filament led bulb
Not necessarily true, but it requires a different topology.
Yep, that someone was me. I discovered this thread by djozz called “SunLike 3500K 95+ CRI midpower led from Seoul Semiconductors tested”, and I said to myself “Hey, Remez builds with the same make and model of LED in 3000k, I should email Adam and see if he can source Remez in 3500k. But nope.
REMEZ is too cheap to bee good. SunLike8 is my baby what much better than REMEZ 9
Well the (8) Remez I bought from you are quite impressive now that their tint has been fixed. My rooms take 5 bulbs each, so this is what pricing look like for me:
$35 per room for Remez 7 watt
$105 per room for Sunlike 7 watt
$232 per room for Sunlike 8 watt (with more efficiency)
- Shipping
So no regrets on my Remez purchase.
- Shipping
I will waiting for you after about 12 month for new order of REMEZ (R.)
In your calculation something wrong…
So, 5pcs R.9 cost from me 5x8+6$=46$
5pcs S.8 cost from me 5x21+6$=111$ (real price for shipping for me much more, because of weight)
That’s why I ordered the 3 “spares” to put in my bathroom. I can steal from there if I have some die in the office. Even with bad luck, they are still a better value.
5pcs R.9 would be $46, but you had to cancel that order because of flicker issues on 120v. So R.7 was my only option. And yea, there is a less efficient S.8 option for $111.
Are there any more UK users in here? I would appreciate help from a few more people to establish statistical significance (for the UK only).
The deal is:
- We send you a Bedtime Bulb (either E27 or B22 base) for free
- You observe it for a few minutes to see whether the light is steady or has any fluctuations
- It’s yours to keep afterwards
If you are open to helping me with this and are in the UK, please send me a PM.
Thanks,
Greg
I have now used and observed the Bedtime Bulb in three locations in southern germany and wasn’t able to notice any kind of fluctuation.
@yeutterg, if you still need more testers in the UK, just post your free bulb offer over on the BLF Deal Alert thread. THAT will get you some PM’s.
Thanks!
I have now used and observed the Bedtime Bulb for good few minutes and wasn’t able to notice any kind of fluctuation:
Video clip: https://i.imgur.com/tTQC1ze.mp4
I really appreciate the warm feeling I got when using this bulb
I received one this morning, and had it on for a few hours this evening. Absolutely no fluctuations noticible to me.
