I’m waiting for this. I think I prefer the reflector optics.
If it has Anduril, dual chemistry support, and low moonlight it would be about perfect for me. Add a recessed switch and we have overreaction.
L3 Illumination L11C? I have an orange 4-mode one and is the slimmest AA light I own. Works with 14500 but modes get brighter and hotter quicker.
Bit old now but some are still available - sbflashlights
bought an orange when they went on sale ...I rushed out and jumped on it ...
then I realized all the other colors were on sale too . I love that olive
Huh? My Tool AA 2.0 Ti has a two piece head that can be opened fairly easily, and the PCB is the same as in my Tool HM kit, it’s just on a shelf not in a pill. I swapped a 219b into my Ti and it’s my favourite light to carry. No breaking glass required.
I agree your Tool comes apart
I posted in the wrong thread, so I can understand that was unclear
The OP was asking about modding an Eagletac AA, here:
They’re extremely easy to mod. Bezel screws off, parts fall out. You can even remove the pill in the d25c. Some titanium models don’t have the bezel and can’t be worked on.
I’ve been on a similar search for a while now, though I’m a bit more lenient in terms of maximum width. The Stainless Steel Amutorch 1xAA is an interesting platform to start on, maybe drop in a 15mm FET driver from mtnelectronics and an LED of your choice. I currently use a Convoy T2 w/ a bolted on solarforce T1 clip and a 17DDM with Bistro, however that’s closer to 20mm in width and you lose AA support. The Jaxman E3 starts from a similar position to the T2 in being very moddable, but is also on the wider side. The E3 does take the old Olight Baton S1 deep carry clips (can be bought from olight on ebay).
The Amutorch with 219c is very nice (i bought one from Neal last year or so)
No need for another driver, this one puts out plenty and it does get hot on turbo with 14500
The overall build of the Tool Ti is much better, but the parasitic drain is high and my led wires came off while doing runtime testing.
So hardware is top notch, electronics definitely needs improvement
No need for another driver, this one puts out plenty and it does get hot on turbo with 14500The overall build of the Tool Ti is much better, but the parasitic drain is high and my led wires came off while doing runtime testing.
The Amutorch had mediocre mode spacing and terrible PWM on the stock driver. The backlit tailcap in the Tool is the source of the “parasitic” drain no? It’s a mechanical clicky otherwise and should have no standby current.
Modified Klarus Mi7? Side switch though. Moonlight isn’t great, a bit too bright.
DQG Tiny AA - head diameter 17,5mm, lenght 67mm. No switch, its a twistie.
Also available with 90CRI LED. It works with 14500, but the output is almost the same as with the NiMHs (barely brighter) according the reviewers.
I love those little lights. Wish they weren’t so expensive. That is pretty pricey for a AA light. I’d buy a few at maybe $20. Almost $40 is out of my range for AA lights. Maybe I can catch a sale one day.
thanks for the photo comparison
are the 2nd and 3rd light from the left AA lights?
on the right is an AA with a Rotary Dial, my grail UI:
Sunwayman V10r Ti+ (16340), Sunwayman V10a (AA)
Sunwayman V10r Ti w AA adapter for V11r
They’re all AA/14500 lights except for the Astrolux, that’s AAA
I don’t actually recognize the second light in the line-up. The third is the Amutorch S3 AA in SS. No longer made unfortunately. It’s been my favorite AA, despite the low PWM, imperfect switch, and worst of all no mode memory.
That’s the Enogear AA, much appreciated over many BLF members
Hyperion from Sigma Customs?
