✌ FREEME - ASTROLUX MF01S 15000lm Flashlight Group Buy - ENDED
1539 posts / 0 new
bexamous
Last seen: 11 months 2 days ago
Does MF01-S work with the 8×18650 tube? I don’t have tube, but does it put out 9v? I assume it puts the two sets of 4 in series.. the MF01 non-S input voltage has a range up to 9v so that’d make sense. MF01-S doesn’t have any input range given?
JasonWW
JasonWW's picture
Last seen: 14 hours 49 min ago
This light is 6v (8.4v).
An 8 cell battery tube would need to maintain 6v.
ghost face
ghost face's picture
Last seen: 2 years 9 months ago
The existing Astrolux extender works in parallel not series with MF01S just like with original MF01. You will need to buy additional one end cap and have two loose battery cages since new MF01S changed design with integrated battery holder.
are you alone in the house?
Kecsotam
Last seen: 2 years 10 months ago
Does an expanded tube help with heat dissipation?
Or, with 8 batteries, does the lamp adjust in high / turbo mode just as fast?
JasonWW
JasonWW's picture
The vast majority of the heat is at the far end of the head, above the switch level. So the battery tube heat dissipation is very small. I doubt you will see much heat related difference with a longer battery tube. Any difference will be tiny and you might not notice.
Turbo stepdown should not change.
Depending on batteries, you might see brighter Turbo output which means it could heat up faster.
I think the main goal of using 8 cells is just longer runtime. All run times double, except where heat might cause it to ramp down.
olles
I have two MF01S (4000K and 5000K) using the astrolux extender tube (about 20€) and they work nicely! The original MF01 worsk with it as well and the MF04 ditto.
No Problems whatsoever.
The main advantage is longer runtime. In real world I don’t see an output advantage (i.e. more light on turbo) but turbo can be maintained a little longer…
But be aware, this then is a heavy flashlight and no beauty since the tube is nearly as thick as the emitter end Wink
bexamous
Cool just extender tube, extra caddy, and tailcap in.. hooked it all up and yeah works just great. Yeah its mostly about runtime.. I’m pretty sure output is a bit higher as well. I can’t really see a difference, so its not huge deal, but just based off heat its driving leds harder. I had setup ceiling to be at point where light just was slightly warm in hand, was like level 100/150 or something. Switching to extender tube same level is now noticabely warmer, so more amps must be flowing due to smaller voltage drop with twice batteries in parallel.
https://imgur.com/mV2zuHb.jpg
prodal
My Mf01s came without the physical reverse polarity protection rings.
Did they change the design? Does anybody else have a Mf01s without it?
In this vietnamese youtube review of the Mf01s it seems to be the same:
youtube link
rom
Last seen: 1 year 11 months ago
Mine came also without reverse polarity protection rings.
Was delivered early december. So it seems they changed it quite a while ago.
prodal
Thanks for checking.
I bought four Samsung 30Q button top because I thought it would come with the protection. Would have taken flat tops if I knew before.
rom
Well, I’m happy they work both, so I can use my Sony button top or Samsung flat top.
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 4 months 1 week ago
Mine was an early MF01S and it has the protection rings.
Thats not good that the newer do not have it. That was the best polarity protection rings on the market, because they works also with all flat top batteries. E.g. from Samsung, which has the contact lower than the heatshrinktube around the flat top.
freeme
freeme's picture
Last seen: 1 day 3 hours ago
I will find out from them next week.
prodal wrote:
My Mf01s came without the physical reverse polarity protection rings. Did they change the design? Does anybody else have a Mf01s without it? !https://i.postimg.cc/SsLyZ3Yx/IMG-20200129-102320.jpg! !https://i.postimg.cc/xdzjmc0H/IMG-20200129-102357.jpg! In this vietnamese youtube review of the Mf01s it seems to be the same: "youtube link":https://www.youtube.com/watch?v=8aeJzytgdIQ&feature=youtu.be&t=167[/quote]
1thedeals.comyoutubeAstroluxNealsgadgetsolight
ghost face
My MF01S was purchased after the first round of colors was long sold out. I bought purple when the colored became restocked in Beginning of December so mine is very newer. I use flattops VTC5A. Mine has two rings down inside battery tubes on positive posts, but none on the tailcap’s end. I watched Flashaholics video and his had two on the tailcaps positive posts. It seems Astrolux did this inconsistency and should send ones missed. Every time I read threads on this forum I find more issues with their stuff.
rom
I dont see the problem, everybody buying this light should be able to insert 4 batteries correctly. Otherwise this light is too dangerous anyway.
Make sure for instance all 4 batteries are fully charged to the same level when you insert them, otherwise it could get really nasty…
JasonWW
JasonWW's picture
People expect to get what they paid for. Surely you understand what it’s like to buy something and parts are missing. It’s irritating.
Денис Иванов
my flashlight stopped working in smooth mode, only in steps, switching to smooth mode and it stops working or blinks until you disconnect your head from the case. Correspondence with the store where I bought it until I solved my problem … maybe someone already encountered a similar problem?
I tried to reset it, but nothing comes out, even the reset is not done.
JasonWW
JasonWW's picture
Денис Иванов wrote:
My flashlight stopped working in smooth mode, only in steps, switching to smooth mode and it stops working or blinks until you disconnect your head from the case. Correspondence with the store where I bought it until I solved my problem … maybe someone already encountered a similar problem?
I’ve never heard of this. Was it blinking out the voltage level?
What was the the stores solution?
Денис Иванов
it behaves differently for me, now the smooth mode does not work, it used to not work at all, and even earlier there was a smooth mode, but only with incomprehensible jumps (trembled). If you briefly live your life Smile
and it all ends with a hang … he just starts blinking and does not respond to any actions other than blackout.
the video shows this hovering and not working smooth mode. When turned off, 3 clicks shows the charge, and when turned on 3 clicks on smooth mode as you can see, it immediately turns it off.
As for the store … the store is still delaying the solution to my problem: either they have a new year or a lot of calls, now they say that they solve my problem with the supplier.
https://youtu.be/Gy8pr7nBoLA
JasonWW
JasonWW's picture
The behavior in the video is something I’ve not seen. I would say the driver is messed up and needs replacing. If you can’t replace a driver, they would need to send a replacement head.
Денис Иванов
Thank you, my guesses were justified, I just thought maybe it wasn’t him, but now I understand that he’s really rejected, I read there was already a problem with the driver and just like you say the store replaced its head, but in my situation the store pulls with the decision, I will wait for them to decide. Thanks again
Денис Иванов
that the strangest thing was that he came without a defect, but after not using it for a long time, he began to die slowly, after each use his behavior was getting worse and worse, then completely stopped working, then after lying down a bit I tried to turn it on and it started to work, but it hangs periodically I repeat, the smooth mode stopped working. As soon as I wait for the store’s solution, I will definitely write it off.
AbnInfantry
Last seen: 1 week 5 days ago
The seriously defective Astrolux MF01S Banggood sent me last December exhibited similar, and worse, behavior. Banggood Customer Service refused to honor any part of the “guarantee” Banggood touts on its website. I mailed the worthless MF01S back to Banggood on January 6. PayPal and Chase Bank then refused to give me a refund because USPS First Class and Priority Mail tracking numbers aren’t scanned inside China. After I filed a complaint with the Consumer Financial Protection Bureau, Chase Bank reversed their decision yesterday and issued me a full refund.
Fwhomeboy
Last seen: 2 years 7 months ago
AbnInfantry wrote:
Good for you!!!
The New Guy
JasonWW
JasonWW's picture
So you only lost the $60 shipping cost?
AbnInfantry
I lost the shipping cost, but it was $23.50, not $60. That was USPS First-Class Package International Service with a tracking number (a tracking number that China Post refuses to scan). I could have paid more for Priority Mail but that tracking number wouldn’t be scanned in China either. When I mailed the package at my local post office, I told them I needed a tracking number. They gave me a receipt with a tracking number, but it stopped being scanned once the package reached China. As I subsequently discovered, the cheapest way to ship a MF01S from the USA to China, with a tracking number scanned by China Post all the way to the destination, would cost $77.50 by USPS Express Mail. I don’t see much point in spending $77.50 in non-reimbursed postage to get a refund of $80. It galls me that a Chinese vendor can spend $2 on postage and USPS will scan that package all the way to its final destination, but a person in the USA can spend over twenty times that much for postage to China and China Post refuses to scan the tracking number.
I don’t see what use PayPal’s touted “protection” is for consumers in the USA or Europe when ordering typical budget flashlights from Chinese vendors. In the case of a defective product you’re required to return to the merchant, it costs more (often far more) postage to return a budget flashlight via Express Mail (or FedEx or UPS) than you’d receive in a refund. I also discovered it’s an ordeal trying to open, and maintain, a dispute for a purchase made via PayPal’s “guest checkout.” Every time I needed to contact PayPal, whether online or by phone, it was a 2- to 4-hour wait before I was connected to a “specialist” who handles “guest checkout” disputes, even after I created a PayPal account. And then PayPal repeatedly sent me emails requiring me to do things which were physically impossible with a “guest checkout” purchase. Then it was another multi-hour wait to talk with the right “specialist” who’d tell me to disregard certain emails, but not other emails, as if I knew which were which without contacting them. It took another multi-hour wait to get PayPal to comprehend that I was the buyer, not the seller, despite having explained everything previously in great detail.
I finally gave up on PayPal since they wouldn’t issue a refund because the tracking number wasn’t scanned inside China then opened a dispute with Chase Bank, issuer of my Visa card. They refused to give me a refund until I filed complaints with three federal agencies. Then Chase Bank “reconsidered” the matter and gave me a “courtesy” refund.
Денис Иванов
I myself don’t understand why the store is so delaying my problem? It’s not the first purchase in this store for more than 10 purchases, once there was a refund and it was fast (the goods there were ~ $ 20). because they lose customers like that … completely don’t understand them.
AbnInfantry
What I “don’t understand” is why so many folks on BLF concoct excuses for [insert name of Chinese merchant here] simply because they personally haven’t had any problem with that company. I didn’t have a problem with Banggood … until I did. But I never questioned the veracity of other people who had experienced such problems.
I’d rather have a root canal than deal with Banggood Customer Service again. One of the things they require when opening a dispute is a picture of their shipping label. Every package I’ve received from Banggood was simply a thin sheet of plastic with a label affixed. I’m pretty sure most customers throw that plastic wrapper away when they open it.
In addition to pictures of the flashlight, shipping label, SKU code, and batteries used, they wanted a video proving there’s a problem. I provided them with five videos, videos they apparently never bothered to watch.
Even though the MF01S they sent me was hopelessly defective and constantly malfunctioned even when the light hadn’t been used in hours, Banggood CS wanted me to configure the temperature. I usually couldn’t even get the side switch to turn the light off (for three hours the only way to turn the light off was either to partially unscrew the head or unscrew the tail cap until the 18650 cells were released). How could I possibly get such a defective switch to configure the temperature?
They wanted me to do a “factory reset” as explained in the user manual. Nowhere in the user manual that came with my MF01S is there any mention of a “factory reset” procedure. After reading posts by Toykeeper (inventor of the Anduril firmware), I performed numerous factory resets to no avail. A factory reset just returns a flashlight to its default settings. It doesn’t magically repair a defective switch or circuit board.
Banggood CS told me to take my MF01S to a local repair shop to get an estimate for fixing it … but the shop wasn’t allowed to open the flashlight as doing so “voids the warranty.” I don’t know about major cities in China, but I couldn’t find any local repair shop here in South Dakota that handles Chinese-made LED flashlights … let alone one that gives repair estimates without being allowed to seriously examine the flashlight.
When I asked Banggood for a return mailing address and a refund, they stopped responding to my messages and emails. Banggood completely failed to honor any part of its published “guarantee.” Even though Banggood has a facility in California that stocked MF01S flashlights, PayPal required me to ship my defective MF01S to an address they provided in China. If I’d been allowed to mail my MF01S to Banggood’s warehouse in the Los Angeles area, postage would have cost much less and the USPS tracking number would be scanned all the way.
Tom E
Tom E's picture
I'm in the category of dozens of BG purchases over the years. Unfortunately so called "budget" lights of the past were like under $35, roughly, while now they go for $100+. For $35, I'd take the risk, even if I got a box of rocks once in a while, since I'm still saving big $$$ over alternatives and buying enough to minimize loss's. Astrolux represents a true risky proposition, specially the MF01S because:
  • big $$$, even discounted
  • it's a house brand, not a real company, therefore all service/support is via the retailer, no fallback options
  • it's complicated - lots of LED's, complex driver, lots of things to go wrong
  • rush to market - might be true of all lights, specially Astrolux, but quality/testing does suffer
  • it is super appealing: great look, great performance, great design, still a great deal (if it works of course)
 We really need a better way to hold the suppliers accountable. PP is failing to do that, from the sound of it, though I've won PP disputes before, usually because the seller fails to respond to PP's requests.
Syncmasterklop
Syncmasterklop's picture
Last seen: 7 months 1 week ago
Interested in the group buy coupon.
