Ok freebies are over
They raised all denominations, so now you get something like 50% off from $4… downto around 20% off $64.
Small coupons below $4 still have only 1$ overhead
Mmmkay, let's see if we can come up with how this name hiding thing works. My name is set as Salvador Barqueros in my AE member profile, this is why I said I should appear as S***r B***s in the lists.
All I can say in this respect is most I've got in a round is €0.87, and can't recall having tapped in your links in the first place. I also don't know into how many games we can chip in each round, Serlite thinks only one but, seriously?
I would like to better determine how this thing works. Please provide as much information as possible from now on, if you will of course: where do you tap and in which order, the names in your list, etc. Thanks.
Thanks kat. Wow, you’ve been putting a lot of effort into squeezing every last drop out of this promotion…
And yep Barkuti, you’ve pretty much guessed how they’re obfuscating names - first and last letter of each part of the name (if it’s an initial, they use the same letter), separated by asterisks.
It looks like the first and last name are swapped though, since CC is the last name I provided. So you’d probably be Bs S*r if you showed up on someone’s list.
Coupon chart? Are you writing the game rules, or is it some left-wing of yours? LMAO!
So you're telling us that the values you are given have nothing to do with who enters or chips in your round? And what determines the credit you obtain by tapping repeatedly over the target?
For existing users, if you click past half of the bar you get $0.98, otherwise you get $0.32
For new users, it’s $3.99 and $2.78
Combinations of these coupons give you a fatter coupon.
Until yesterday, all coupons had a minimum purchase price of just $1 over the coupon value (except $6.93/$7 which had 7 cents).
But from today they raised the minimum purchase price on all coupon combinations over $4.08.
It’s still worth using them because you still get a nice discount anyway… but I was getting used to buying $10 stuff with $1 so now it’s just not that interesting for me
